果汁中维生素检测方案
检测样品 果蔬汁类及其饮料
检测项目 营养成分
关联设备 共0种 下载方案
方案详情
应用日本京都电子公司(KEM) AT-510+C272自动电位滴定仪测定饮料中维他命C的含量En 的应用资料实例。
No.TIF-06302 KEM Application Note Kyoto Electronics Oxidation-Reduction titration No.NZ22-06278 Vitamin C in soft drink -Abstract- According to JAS for determination of vitamin C, indophenol is titrated with testsample. This method requires complex process by exchanging titration solution foreach sample. By our method, the sample is titrated with indophenol of which factoris predetermined so that the concentration can be easily obtained. -Equipment- Main unit : Automatic potentiometric titrator AT-510 Detector : Standard preamplifier STD-510 Combination Pt electrode C-272 #429-0012 -Reagent- Titration solution : indophenol solution 一Method- (1)To 200mL beaker, About 3g sample was added. (2) Added pure water to make it total 100mL, and added 5 drops acetic acid. (3)Titrated with indophenol solution to determine concentration. -Calculation- Concentration(%):(EP1-BL1)xC1xK1/SIZE EP1:volume(mL) BL1: blank (mL)=0 SIZE: sample size (mL)C1: concentration conversion (mg/mL)=0.2712K1: unit conversion coefficient=0.1 -Ambient condition- Room temperature :22.5℃ Humidity : 47%Weather : cloudy -Literature- JAS Japan Agricultural Standard (Bulletin No.1226 September 29 1990) Tel:021-66581985,63172460 Fax: 021-66581986 周峰13916388882 zhou-feng1027@163.com -Results- Run Size (g) Vol. (mL) Conc.(%) 1 st2nd3rd 3.01083.04853.0213 6.58206.66836.6220 0.05930.05930.0594 Statistics MeanSD RSD 0.0594%0.0001% 0.1354% -Comment- Http://www.shxf17.com Yttp://www.shxfcom上海旭风科学仪器有限公司 上海市闸北区荣路 Y海旭风科学仪器有限公司 上海市闸北区荣路 el: Fax: 周峰 zhou-fengcom
关闭
  • 1/2
  • 2/2
产品配置单
上海旭风科学仪器有限公司为您提供《果汁中维生素检测方案 》,该方案主要用于果蔬汁类及其饮料中营养成分检测,参考标准《暂无》,《果汁中维生素检测方案 》用到的仪器有null。
我要纠错
相关方案
