矿物油中水分含量检测方案
检测样品
油品
检测项目
水分含量
关联设备
共0种
Water in mineral oil can be determined by direct titration method with Coulometric Karl Fischer titrator AQ-2200 (high-end) or AQ-300 (compact). However, the mineral oils will be suspended in the anode solution when directly injected, resulting in short life of the anode solution and long period for stable background. Using the EV-2000L Oil Evaporator allows only water to be carried into the cell to obtain accurate results with less maintenance.
上海天美科学仪器有限公司为您提供《矿物油中水分含量检测方案 》,该方案主要用于油品中水分含量检测,参考标准《暂无》,《矿物油中水分含量检测方案 》用到的仪器有null。
我要纠错
