UPH Series Ultrapure Water System Product Description UPH series standard ultrapure water system features compact structure and complete functions and can directly purify tap water into ultrapure water with conductivity as high as 18.2 MΩ.cm and is applicable for standard laboratory with heavy water consumption. System Power IndicatorRO Button UP ButtonOnline conductivity display Full Tank IndicatorUltraviolet Slacking Button Pump Working IndicatorUltraviolet Slacking Indicator System Washing IndicatorOnline Conductivity DisplayRO Indicator UP Indicator10′ water quality pre-processor20L Pressurized Pure Water Bucket Fundamental Features Film touch-pin switch control, with Liquid Crystal Display (LCD)PLC Automated Control, low-water-pressure alarming, auto-halt protection at water cutoff/blackout/filled water tankAll Chinese instruction at normal working status, including system boot, system protection, system water making, system settingOnline monitoring of RO pure water conductivity, online monitoring of water temperatureOnline monitoring of UP ultra-pure water resistivity, online monitoring of water temperature Recycling time of Ultra-purification system Water fetching at time and quantity control (1-99 mins, 1.5-1.8 liters/min)Water-fetching at the quality control (1-18.25MΩ.cm )predefined water fetching Monitored printing through RS232 Output port Technical Indexes Types UPH-I 5/10/20/40/ 60/80/100L UPT- Ⅱ 5/10/20/40/ 60/80/100L UPT- Ⅲ 5/10/20/40/ 60/80/100L UPT- Ⅳ 5/10/20/40/ 60/80/100L Input Water Source Total soluble solid content TDS<200ppm, water pressure>1kg/cm 2 Power Supply AC220V/50Hz AC220V/50Hz AC220V/50Hz AC220V/50Hz Volume of Water Manufactured 5/10/20/40/ 60/80/100L /H 5/10/20/40/ 60/80/100L/H 5/10/20/40/ 60/80/100L/ H 5/10/20/40/ 60/80/100L/ H RO Output Conductivity 2~10μs/cm 2~10μs/cm 2~10μs/cm 2~10μs/cm UP Output Conductivity 18.2MΩ.CM 18.2MΩ.CM 18.2MΩ.CM 18.2MΩ.CM TOC - - 3-10ppb 3-10ppb Pyrogens Not filtered Not filtered <0.01Eu/ml <0.01Eu/ml Bacteria <1cfu/mL <1cfu/mL <1cfu/mL <1cfu/mLGranule (>0.2μm) <1/mL <1/mL <1/mL <1/mL Main Dimension (mm) 520×350×350 520×350×350 520×350×350 520×350×350 Weight 35kg 35kg 40kg 40kg Power 50w 50w 50w 50w Instructions to Order 1. In case of input water TDS>300ppm, fully or semi automatic water softener optional with additional charges 2. 40L / 80L / 120L pure water bucket optional as per water consumption of clients
关闭产品配置单
四川优普超纯科技有限公司为您提供《优普UPH中UPH英文技术资料检测方案(纯水器)》,该方案主要用于优普UPH中UPH英文技术资料检测,参考标准《暂无》,《优普UPH中UPH英文技术资料检测方案(纯水器)》用到的仪器有null。
