30nsTECHUS toll free 800-443-4227·phone 610-941-0132·www.instechlabs.com nstech’s clear animal enclosures are ideal for tetheredrodents, as they have no sharp corners where the tether can.catch or tangle. Originally designed for short-term microdial-ysis experiments, the tanks can be ordered pre-machined toaccommodate feeders and water bottles in order to house ani-mals for longer periods. The floor areas of the two modelsexceed USDA regulations and NRC guidelines for the largestsingly-housed rats and mice. The feeders and water bottles mount outside the tank to avoidinterference with the tether. The feeder pellet opening is approx-imately 13x20mm. Use the 6-inch MCLA lever arm with the larger rat tank and the3.5-inch SMCLA arm with the small mouse tank. Part No. Description Unit MTANK Clear animal enclosure, 15in high ea MTANK/W Clear enclosure, 15inH drilled for MWATER ea MTANK/F Clear enclosure, 15inH drilled for MFEEDER ea MTANK/WF Clear enclosure, 15inH drilled for MWATER & MFEEDER ea STANK Clear animal enclosure, 8.5in high ea STANK/W Clear enclosure, 8.5inH drilled for CM/W50 ea STANK/F Clear enclosure, 8.5inH drilled for MFEEDER ea STANK/WF Clear enclosure, 8.5inH drilled for CM/W50 & MFEEDER ea MTOP Slotted cover for MTANK ea MFEEDER Feeder for MTANK or STANK ea MWATER Water bottle for MTANK ea SSCREEN Bottom screen for STANK ea STOP Slotted cover for STANK ea CM/W50 50ml water bottle for STANK ea www.instechlabs.com/Infusion/accessories/clearenclosures.php SPECIFICATIONS MTANK STANK Height 15in (38cm) 8.5in (22cm) Diameter 10.5in (27cm) 5.5in (14cm) Floor area 87in²(570cm²) 24in²(150cm) Material polycarbonate polycarbonate '"Guide for the Care and Use of Laboratory Animals."National Academy Press. 1996.
关闭产品配置单
香港友诚生物科技有限公司为您提供《清醒活动装置enclosures》,该方案主要用于其他中null检测,参考标准《暂无》,《清醒活动装置enclosures》用到的仪器有小动物行为活动记录系统。
