High Throughput Imagingin Low Light Applications Speed Sensitivity All-in-one solutions Next generation imaging For applications with imaging challenges,we offer a wide range of TDI solutions. NDIC solutions HAMAMATSUPHOTONISOURBUSINESS high-Throughput Imagingin Low Light Applications New Generation of TDI Solves Three Main Issues All at Once Time Delay Integration (TDI) is an imaging technology that improves the sensitivity by enabling alonger exposure compared to the speed of moving objects. Standard linear sensor cameras createimages of moving objects; however, the exposure time is limited by the readout speed of thecamera. Standard digital CCD cameras can control exposure time; however, generated images aresmeared if objects are moving faster compared to the exposure time. TDI solves these problemsutilizing special sensors and readout method. Speed SensitivitylResolutionAll-in-one solutions Optical technology/ We offer a wide range of TDI solutions. lsk us any high-throughput imaging challenges. Variety of superior scan features from the expertise of Hamamatsu sensor technology Scanning Camera Perfectly seamless imageacquisition with high sensitivityand high speed Object motion This leads to fast and sensitive scanning. When charges are readout from a CCD, the CCDvertically transfers the charges line by line. If thecharge transferring speed and the object movingspeedl are matched perfectly, it enables theexposure time for the moving object to be as longas the charge transferring time of the verticalstages in the CCD. This method is called TDI, thetechnology that captures the image of a movingobject with high speed and high sensitivity. Line scanning makes scanning faster Theimage is scanned line by line. Fast scanning and 1D composition Higher throughput New fields. Until now, TDI technology has only been used in a limited range of fields. Hamamatsu provides we offer individual cameras as well as core scanning technology packages TDI Cameras We offer cameras with a variety of features,such as high speed, high sensitivity,and variety of bandwidth ranges. Hamamatsu offers a wide lineup of TDI cameras. Hamamatsu produces cameras for various needs,from high-speed,high-sensitivity cameras that are ideal for producing images of weak fluorescence,to cameras with high-resolution and low-noise characteristics, to cameras that support a variety ofbandwidth ranges from ultraviolet to X-ray. For everyone with image-processing concerns that include related devices. TDI Engine >>> To meet your unique needs,we offer core scanningtechnology packages. The TDI engine is the core technology that maximizes the TDIcamera's high-performance potential and makes high-speed,high-sensitivity, high-resolution scanning possible. Startingfrom the TDI camera, we also provide the modules necessaryto build a customer’s own unique system. Core technology in a TDl engine Example of TDI Engine configuration TDI camera (select an appropriate camera) Sample-stage design(design and create a stage that matchesthe sample shape) Motorized XYZ stage control(including the stage control software) Optimal illuminationand optical technology Development ofimage-acquisition andanalysis software Provision of a TDI-centered module TDI| System (Giga-pix Scanner) We provide high-performancescanning systems through OEMpartnerships. We can enhance TDI engines with additional features toproduce TDI systems. In addition to the core scanningtechnology of the TDI engine, TDI systems include acombination of machinery to transfer slides to the scanningarea, body design, and utilities that have been optimized for aspecific application. We provide these TDI systems to ourcustomers for use with their brand names through OEMpartnerships. Example of Giga-pixel Scanner System (for use with glass slides) Provision of high-performancescanning systems The best solution in a wide range of applications is offered. TDI是一种特殊的图像采集方式,广泛应用于DNA测序、工业检测中的机器视觉。TDI成像适合需要记录随时间变化的线性过程的应用,或者被成像主体的长宽比非常不对称的情况。其在弱光扫描应用中非常有用,在这种情况下典型的线扫描相机无法生成有用的图像。解决方案主要针对TDI相机在基因测序、工业无尘环境监测等生物以及工业方面的应用进行了说明介绍。
关闭还剩4页未读,是否继续阅读?
滨松光子学商贸(中国)有限公司为您提供《生物组织、尘埃中DNA检查、工业无尘环境检测方案(CCD相机)》,该方案主要用于其他中DNA检查、工业无尘环境检测,参考标准《暂无》,《生物组织、尘埃中DNA检查、工业无尘环境检测方案(CCD相机)》用到的仪器有滨松 TDI相机 C10000-801。
