NTEKPage 2 of 49Report No NTEK-2014DG0529460E TEST RESULT CERTIFICATION Applicant's name... Shenzhen 3nh Technology Co., Ltd. Address. 4/F. Block 8. Nangang Second Industry Zone,Xili, NanshanDistrict, Shenzhen, Guangdong. China Manufacturer's Name Shenzhen 3nh Technology Co., Ltd. Product description Product name SPECTROPHOTOMETER Model and/or type reference:NNS800,NS810.NS820 Standards. EN 61326-1:2013 This device described above has been tested by NTEK, and the test results show that theequipment under test (EUT) is in compliance with the 2004/108/EC requirements. And it isapplicable only to the tested sample identified in the report This report shall not be reproduced except in full, without the written approval of NTEK, thisdocurent may be altered or revised by NTEK. personal only, and shall be noted in the revision ofthe document. Date of Test. Date (s) of performance of tests 29 May 2014 ~04 Jun 2014Date of Issue..... 04 Jun 2014 Test Result.... 我司对于客户的需求 提供不同的解决方案 如市面上的产品不能满足要求 可按客户的需求定制 调试 可上门检测需求,技术人员免费指导。还有相机分辨率 鱼眼镜头测试 套餐可定制。
关闭产品配置单
广东三恩时科技有限公司为您提供《废水中重金属检测方案(色差仪)》,该方案主要用于废水中重金属检测,参考标准《暂无》,《废水中重金属检测方案(色差仪)》用到的仪器有3nh三恩时NS808交通路标分光测色仪、TILO天友利T60B英式标准对色灯箱纺织印刷。
