用微射流处理乳液样品实验 试验名称:微射流均质机处理乳液 样品:乳液仪器:微射流均质机 微射流处理压力:2000bar , 2400bar 样品经微射流处理前: Sample Name: 1204-1-13 SOP Name: manseings.nano File Name: 20191209ats.dls Dispersant Name: Wate Record Number: 33 Material RI: 1.52 DDispersant RI: 1330WViscosity(cP): 08872 Material Absorbtion: 0.100 Measurement Date and Time: 2019年12月9日14:52:07 Temperature("Cj: 25.0 Duration Used (s): 80 Count Rate (kcpsj: 173.6 Measurement Position {mm): 4.55 Cell Description: Disposablesizing cuvette Attenuator: 10 Size (d.nm): % Intensity: StDev (d.nm] Z-Average(d.nm): 1313 Peak 1 3955 58 1086 Pdl: 0.630 Peak 2: 420 271 Intercept: 0.791 Peak 3: 0000 00 0.000 Result quality: Good Size Distribulion by Intensity Record 3: 1204-1-13 微射流2000bar处理 : S5ample Name: 1204-1-3 2 SOP Hame: mansellings.nanoFile Name: 220191209ats dt:Record Number: 5Material Rl: 1.52 Disispersant Name: Watar DispersantRl: 1.330 Viscosity (cP): 0.8872 Materiaal/Absorbtion:0.100 Measurement Date and Time: 2019年12月9日15:06:47 14TemperaturePC): 25.0Count Rate(kcps): 292.0Cell Description: Duration Used (s): 60Measurement Position (mm): 4.65 : Disposable sizing cuvetle Allenuator: 10Size {d.nmj: ss Intensitijty: St Dev (d.nm):zZ-Average (d.nm):1190 Peak11: 599.8 50.5 179.4Pdl::0.99 Peak 2: 987 39.5 515.7Intercept: 0.848 Peak J 000 0.0 0.000Result quality:Refer to quality reportSize Distribution by Intensity 100.1 10 100 1000 100008S1ize (d.nm)Record5:1204-1-32 微射流2400bar处理后: Sample Name: 1204-2-1 SOP Name: rmansetlings.nanoFile Name: 120191209ats.dt:JSRec0ord Number: 1Material Rl: 1.45 Dispersant Name: Wate DispersantRl: 1.330 Viscosity (cP): 0.8872 Material Absorbtion: 0.00 1 Measurement Date and Time:2019年12月9日1529:38 Temperature (C): 25.0Count Rate (kcps): 249.5CellDescription: Disposable sizing cuvette Duration Used (s): 70 Measurement Position (mm): 4.65 Attenuator: 10 Size (d.nmj: %Intensity: St Dev (d.nmj: Z-Average (d.nm): 3272 Peak 011: 2012 82.1Peak 2: 11.69 17.90.1.000 0. 1858 Pdl: 1.000Intercept: 0.640 Peak 3Result quality: Refer to quality report 1.498 0.000 微射流处理样品效果图: 韩国日新微射流均质机,处理样品,超高压微射流2400bar,样品达到纳米级别。 用微射流处理乳液样品实验试验名称:微射流均质机处理乳液样品:乳液仪器:微射流均质机微射流处理压力:2000bar,2400bar样品经微射流处理前:微射流2000bar处理:微射流2400bar处理后:微射流处理样品效果图:韩国日新微射流均质机,处理样品,超高压微射流2400bar,样品达到纳米级别。
关闭产品配置单
苏州纳洛泰仪器有限公司为您提供《乳液中粒径检测方案(均质器)》,该方案主要用于其他中理化性质检测,参考标准《暂无》,《乳液中粒径检测方案(均质器)》用到的仪器有微射流均质机Autoclave日新 Nano dispersion NH500、微射流均质机(NLM100)、百特激光粒度分析仪BT-9300S。
