检测样品 土壤
检测项目 (类)金属及其化合物
钻石会员
3278 篇解决方案
Laboratories testing soils using Atomic Absorption Spectroscopy (AAS) face pressure due to the number of elements to be measured and large numbers of amples. It is not uncommon to measure from 4 to 10 different elements in each soil sample. Conventional flame AAS systems can only detect one element per one sample aspiration, which means multiple aspirations are needed for multi-element testing. It is time-consuming and laborious when there are a large number of elements and samples waiting for analysis.The Agilent 240FS is a high performance flame atomic absorption spectrometer. It combines four lamps with the Agilent Fast Sequential (FS) mode which doubles sample throughout and dramatically reduces running costs. Fast Sequential mode operates all four lamps simultaneously. A fast lamp selection mirror and high speed wavelength drive are used to switch between the lamp and wavelength required to measure each element. The Hammer gas control system initiates instantaneous changes to the gas flows, ensuring each element is analyzed under optimal conditions. This results in much higher analytical efficiency, lower operating cost, minimized sample consumption, as well as reduced reagent and handling costs.
关闭产品配置单
安捷伦科技(中国)有限公司为您提供《Determination of Cr, Cu, Ni and Zn in Soils Using Fast Sequential Mode》,该方案主要用于土壤中(类)金属及其化合物检测,参考标准《暂无》,《Determination of Cr, Cu, Ni and Zn in Soils Using Fast Sequential Mode》用到的仪器有Agilent DUO AA 原子吸收光谱仪。
