Volatile Organic Compounds Analysis in Drinking Water with Headspace GC/MSD Using Hydrogen Carrier Gas and HydroInert Source
检测样品
饮用水
检测项目
VOCs
关联设备
共1种
下载方案
Abstract
An Agilent 8890/5977C GC/MSD system coupled with an Agilent 8697 headspace sampler was successfully used with hydrogen carrier gas for the analysis of volatile
organic compounds (VOCs) in drinking water. Recent concerns with the price and availability of helium have led laboratories to look for alternative carrier gases for
their GC/MS methods. For GC/MS, hydrogen is the best alternative to helium, and offers potential advantages in terms of chromatographic speed and resolution.
However, hydrogen is not an inert gas, and may cause chemical reactions in the mass spectrometer electron ionization (EI) source. This can lead to disturbed ion
ratios in the mass spectrum, spectral infidelity, peak tailing, and nonlinear calibration for some analytes. Therefore, a new EI source for GC/MS and GC/MS/MS was developed, and optimized for use with hydrogen carrier gas. The new source, named HydroInert, was used in the system evaluated here. In addition to the new source, the chromatographic conditions were optimized to provide separation of 80 volatile compounds in 7 minutes. Standards and samples were analyzed in both scan and
SIM data acquisition modes. For the scan data, spectra were deconvoluted with MassHunter Unknowns Analysis software and searched against NIST 20 to assess
the spectral fidelity. In both modes, quantitative calibration was performed for the 80 compounds over the range of 0.05 to 25 μg/L. As demonstrated in this note, the system gives excellent results for the analysis of VOCs in drinking water.
IntroductionOne of the analyses commonly used to ensure that the quality of drinking water is the measurement of volatile organic compounds (VOCs). These compounds can appear in drinking water by contamination from numerous sources, including industrial and commercial operations. Another common source is when VOCs are formed by the addition of chlorine (used to disinfect the water), and react with natural organic matter in the source water. Regulations governing the allowable concentration of VOCs in drinking water vary by country andregion, but are typically in the low μg/L (ppb) range. Due to the large number of potential contaminants, and the need to measure them at such low levels, GC/MS systems are commonlyused. GC/MS offers both the sensitivity and selectivity required to identify and quantify VOCs. Purge and trap1 and static headspace2,3 are two commonly used automated sampling techniques that extract the VOC analytes from water samples and inject them into the GC/MS. This application note describes a system configured to perform static headspace/GC/MS analysis of VOCs in drinking water, optimized for using hydrogen as the carrier gas.
关闭
1/13
2/13
安捷伦科技(中国)有限公司为您提供《Volatile Organic Compounds Analysis in Drinking Water with Headspace GC/MSD Using Hydrogen Carrier Gas and HydroInert Source》,该方案主要用于饮用水中VOCs检测,参考标准《暂无》,《Volatile Organic Compounds Analysis in Drinking Water with Headspace GC/MSD Using Hydrogen Carrier Gas and HydroInert Source》用到的仪器有 Agilent 5977C GC/MSD。
我要纠错
