X65管道钢在油/水乳液中的电化学腐蚀
检测样品
钢材
检测项目
可靠性能
关联设备
共1种
The electrochemical corrosion behavior of X65 pipeline steel in the
simulated oil/water emulsion was investigated under controlled
hydrodynamic and electrochemical conditions by rotating disk electrode technique.
Results demonstrated that mass-transfer of
oxygen plays a significant role in the cathodic process of steel in
both oil-free and oil-containing solutions. Electrode rotation
accelerates the oxygen diffusion and thus the cathodic reduction.
The higher limiting diffusive current density measured in
oil-containing solution is due to the elevated solubility of oxygen
in oil/water emulsion. The anodic current density decreases with the
increase of electrode rotating speed, which is attributed to the
accelerated oxygen diffusion and reduction, enhancing the steel
oxidation. Addition of oil decreases the anodic dissolution of steel
due to the formation of a layer of oily phase on steel surface,
increasing the reaction activation energy. The steel electrode
becomes more active at the elevated temperature, indicating that the
enhanced formation of oxide scale is not sufficiently enough to
offset the effect resulting from the enhanced anodic dissolution
reaction kinetics. The corrosion reaction mechanism is changed upon oil addition,
and the interfacial reaction is activation-controlled,
rather than mass-transfer controlled. When sand particles are added
in oil/water emulsion, there is a significant increase of corrosion of the steel.
The presence of sands in the flowing slurry would
impact and damage the oxide film and oily film formed on the steel
surface, exposing the bare steel to the corrosive solution.
DSR产品理念顺应数字化潮流,采用当下先进的数字控制芯片技术,有效地减小了体积,提高了信号抗干扰能力。DSR采用数字编码器电机控制,通过反馈实际值与期望值来进行比较,并进行误差补偿和调整,以实现精确的运动控制。能够准确地控制电机的位置、速度和方向,实现精确控制。DSR数字信号技术抗干扰能力保障实验不受环境信噪干扰,性能稳定,更适合中国实验室操作习惯。
关闭
理化(香港)有限公司为您提供《X65管道钢在油/水乳液中的电化学腐蚀》,该方案主要用于钢材中可靠性能检测,参考标准《暂无》,《X65管道钢在油/水乳液中的电化学腐蚀》用到的仪器有DSR数字型旋转圆盘圆盘电极(RRDE)_电催化仪器_武汉电弛。
我要纠错
