巴西犬吻蝠中在一个速度范围内运动学和空气动力学变化检测方案(粒子图像测速)
检测样品
其他
检测项目
在一个速度范围内运动学和空气动力学变化
关联设备
共1种
To date, wake measurements using particle image velocimetry (PIV) of bats in flight have
studied only three bat species, all fruit and nectar feeders. In this study, we present the
first wake structure analysis for an insectivorous bat. Tadarida brasiliensis, the Brazilian
free-tailed bat, is an aerial hunter that annually migrates long distances and also differs strikingly
from the previously investigated species morphologically. We compare the
aerodynamics of T. brasiliensis with those of other, frugivorous bats and with common
swifts, Apus apus, a bird with wing morphology, kinematics and flight ecology similar to
that of these bats. The comparison reveals that, for the range of speeds evaluated, the cyclical
pattern of aerodynamic forces associated with a wingbeat shows more similarities between T.
brasiliensis and A. apus than between T. brasiliensis and other frugivorous bats.
北京欧兰科技发展有限公司为您提供《巴西犬吻蝠中在一个速度范围内运动学和空气动力学变化检测方案(粒子图像测速)》,该方案主要用于其他中在一个速度范围内运动学和空气动力学变化检测,参考标准《暂无》,《巴西犬吻蝠中在一个速度范围内运动学和空气动力学变化检测方案(粒子图像测速)》用到的仪器有德国LaVision PIV/PLIF粒子成像测速场仪。
我要纠错
