边界层,湍流中速度矢量场检测方案(粒子图像测速)
检测样品
其他
检测项目
速度矢量场
关联设备
共4种
A flat plate boundary layer flow was generated at the open test section of the circuit type 1m- wind tunnel of
the DLR, Gottingen, at a free stream velocity of U亣 = 7 m/s with zero pressure gradients. A transparent and
smooth surface glass plate is utilized to provide optical access from its bottom and a good flow quality. The
plate has an elliptic leading edge to prevent flow separation. Four tripping wires, one with 1.5 mm diameter
and three with 1 mm diameter were positioned with 1 mm x-distance close to the surface at (Rex). . 290
along the whole span-wise elongation of the plate. This bypass transition of the flow results in the
development of a turbulent boundary layer flow. In a box of about 34 x 18 x 35 mm3 in x-y and z-directions
around (Rex). . 450 tracer particles has been illuminated by laser light pulses at 4 kHz with 21 mJ each in
order to achieve PIV recordings without using the frame straddling method. The light source was a Nd:YAG
laser from Lee Laser inc. Two highly reflective dielectric mirrors aligned in the x-y-direction are installed
nearly parallel and close to the surface of the flat plate on opposite sides of the measurement region. The
collimated laser beam undergoes multiple reflections between the two mirrors passing through the
measurement volume approximately 15 times before exiting (see sketch left). This arrangement resulted in
a light amplification with a factor ~5 with respect to a single pass system. The specific illumination
arrangement has the advantage that all viewing directions collect scattered light both in forward and
backward directions, which provided the level of light needed for imaging particles in the whole volume.
北京欧兰科技发展有限公司为您提供《边界层,湍流中速度矢量场检测方案(粒子图像测速)》,该方案主要用于其他中速度矢量场检测,参考标准《暂无》,《边界层,湍流中速度矢量场检测方案(粒子图像测速)》用到的仪器有体视层析粒子成像测速系统(Tomo-PIV)、自适应粒子成像测速场仪(PIV)、德国LaVision PIV/PLIF粒子成像测速场仪、时间分辨粒子成像测速系统(TR-PIV)。
我要纠错
