HITACHI High Performance Liquid ChromatographPrimaideHITACHI 1310 Column Owr Simultaneous Analysis of Dyes by HPLC-DAD Food dyes, when added to food or drinks, play an importantrole of enhancing palatability. Food dyes are largelydivided into natural dyes and synthetic dyes. An analysis example for six synthetic dyes is introduced here.Six dyes analyzed here have maximum UV absorption at different wavelengths and therefore, DAD (diode arraydetector) was used to analyze them simultaneously. By using DAD, a chromatogram can be extracted at theoptimal wavelength for each dye. As a spectrum of a standard sample can be compared with that of a target component for confirmation, moreaccurate quantitative analysis is possible. [Contour indication (50 mg/L each)] [Analytical conditions] Column : HITACHI LaChrom C18 (3 um) Flow rate : 1.0 mL/min 4.6 mm I.D.×150 mm Column temp. : 40°C Eluent : (A) 10 mmol/L ammonium acetate /CH,CN=95/5 Detection : DAD 254 nm, 480 nm, 530 nm, 620 nm (B) 10 mmol/L ammonium acetate / CH,CN=50/50 Injection vol. : 10 uL *Gradient (0 min) B2%→(21 min) B 100%→(27 min) B 100% Primaide 叫 Simultaneous Analysis of Dyes by HPLC-DAD (lConfirmation of Spectrum Y5(Sunset Yellow) B1(Brilliant Blue FCF) (Chromatogram Extracted at Optimal Wavelength Six dyes analyzed here have different maximumUV absorption wavelengths. Therefore, DADwas used for the analysis and a chromatogramwas extracted at the optimal wavelength for eachdye.By using DAD, components having differentoptimal wavelengths can be analyzedsimultaneously. [Extraction chromatogram (50 mg/L each)] i|Linearity e.x B1(Brilliant Blue FCF) R106(Acid Red 52) B1(Brilliant Blue FCF)/620 nm mg/L All of the calibration curves (all components in the range from 0.5 to 50 mg/L) exhibited high linearity, with r2=0.999 or more ( System c onfiguration : Primaide 1110 Pump, 1210 Auto Sampler, 1310 Column Oven, 1430 DAD ) ( NOTE: Thes e data are an ex a mple of m easurement; the i ndividual values cannot be guaranteed. ) Hitachi High-Technologies Corporation AS/LC(PM)-age. The system is for research use only, and is not intended for any animal or human therapeutic or diagnostic use.AS/LC(PM)-age.()
关闭产品配置单
日立科学仪器(北京)有限公司为您提供《色素标准样中色素检测方案(液相色谱仪)》,该方案主要用于其他食品中过敏原检测,参考标准《暂无》,《色素标准样中色素检测方案(液相色谱仪)》用到的仪器有null。
