Aurora Instruments Ltd.Application Notice AA-2For more details, please contact:Aurora Instruments Ltd.1001 East Pender St., Vancouver B.C.Canada, V6A 1W2 Application Procedure for Analyzing Copper in Urine Sample Preparation Procedure: 1. Thaw the urine samples at room temperature for 15-20 minutes. 2. Homogenize the samples by slowly vortexing. 3. Centrifuge at 14400 rpm for 2-3 minutes. 4. Dilute the urine samples with pure deionized water in a 1:3 ratio into a microplate (For example,80pL urine +240uL water). 5. Homogenize the diluted samples by mixing them on a microplate mixer for 2-3 minutes. Standard Preparation: The standards for the calibration curve are to be made up from a known concentration of NIST#2670 elevated concentration Reference Standards. Standard No. NIST standard volume (uL) Watervolume (uL) Concentration (ppb) 1 2.5 317.5 2.9 2 5.0 315 5.8 3 10 310 11.6 4 20 300 23.2 5 30 290 34.8 Operating Conditions: Instrumentation: Aurora Al 1100/2100 GFAAS. Parameter of settings: Injection Volume-20pL AURORA INSTRUMENTS AI 1100/2100 Method Name Urine Element Name Cu Instrument Mode Absorbance Display Mode Corrected Manual Band Pass 0.7nm Lamp 1 Current 3.0 mA Lamp 2 Current 0.0 mA Wavelength 327.36nm PMT Voltage 301.0V Preheat Steps 0 Cooling Time 60s Inject Speed 5 Furnace Profile Steps 8 Cont. on back Step finaltemp ramptime holdtime GasFlow PlasmaON CollectData Integrate 1 50 0.00 1.00 1.50 Off Off Off 2 130 12.00 1.00 1.50 Off Off Off 3 300 6.00 1.00 1.50 Off Off Off 4 850 10.00 2.00 1.50 Off Off Off 5 850 0.00 4.00 1.50 Off On Off 6 2300 0.00 1.00 0.50 Off On Off 7 30 0.00 3.00 1.50 Off On Off 8 30 0.00 18.00 1.50 Off Off Off Tel: (604) 215-8700Fax: (604)215-9700 ( Web site: h ttp://www.aurora-instr.com ) E-mail: aurora@intergate.bc.ca
关闭产品配置单
加拿大欧罗拉生物科技有限公司为您提供《尿液中铜元素的分析》,该方案主要用于尿液中null检测,参考标准《暂无》,《尿液中铜元素的分析》用到的仪器有欧罗拉火焰/石墨炉原子吸收光谱仪AI1200。
