Flexural Toughness of Fiber-Reinforced Concrete Using
检测样品
其他
检测项目
关联设备
共4种
The requirements of ASTM C1550-10a for determining flexural toughness of fiber
reinforced concrete (FRC) create several challenges for most standard test systems in
service today. Specifically:
?Size of the specimen: With a diameter of 800 mm (31.5 in) most existing load testing
frames do not have the test space width to accomodate this.
英斯特朗为您提供《Flexural Toughness of Fiber-Reinforced Concrete Using》,该方案主要用于其他中null检测,参考标准《暂无》,《Flexural Toughness of Fiber-Reinforced Concrete Using》用到的仪器有英斯特朗DX系列液压万能材料试验机、英斯特朗HDX系列大载荷液压万能材料试验机、英斯特朗MDX系列大载荷液压万能材料试验机、英斯特朗1000HDX大载荷液压万能材料试验系统。
我要纠错
