Journal of Physics: Conference Series 45 (2006) 19-26Institute of Physics PublishingSecond International Conference on Optical and Laser Diagnostics (ICOLAD 2005) 20 19◎ 2006 IOP Publishing Ltd doi:10.1088/1742-6596/45/1/003 PIV, high-speed PLIF and chemiluminescence imaging fornear-spark-plug investigations in IC engines C M Fajardo, J D Smith, V Sick Department of Mechanical Engineering, The University of Michigan, Ann Arbor, MI,USA vsick@umich.edu Abstract. Measurements of the local flow and mixture condition near the spark plug of inter-nal combustion engines are important to characterize their influence on ignition and combus-tion performance. This is especially true for direct-injection engines where limited time isavailable for mixture formation and optimum stratification of the fuel/air mixture to achievebest performance. Transient processes need to be visualized in an optically challenging envi-ronment. The application of digital Particle Image Velocimetry (PIV) for flow field measure-ments along with crank angle-resolved planar laser induced fluorescence (PLIF) and chemilu-minescence imaging is discussed in the context ofinvestigations of a highly stratified spray-guided direct-injection engine. Flow fields were captured in a firing optical single-cylinder en-gine to study the interaction of the fast spray and the underlying in-cylinder tumble flow. Theimpingement of the fuel spray on the spark plug electrodes and subsequent dispersion of thefuel cloud was filmed at a rate of 12kHz with a new PLIF technique using a diode-pumpedNd:YAG laser. Subsequent flame development and combustion progress could be followed viahigh-speed imaging of OH chemiluminescence. This approach was also combined with dou-ble-pulse PLIF imaging of fuel distributions. 1. Introduction The spark-ignition direct-injection (SIDI) engine provides an alternative to port fuel injected (PFTengines, currently in widespread use [1]. Most of the advantages of SIDI engines rely on stratifiedcharge operation, a mode suitable for part load (i.e. city driving conditions). Here, interactions of ahigh-momentum fuel spray plume and the spark plug promote a rich mixture near the spark plug,while the overall combustion chamber burns fuel-lean. As a result, it is possible to decrease fuel con-sumption and increase efficiency, while meeting the stringent emission standards of the near future.Achieving the fuel consumption and efficiency benefits of SIDI engines, which rely on optimized in-jection and burning strategies, are two important development goals. Attaining consistently reliableperformance and acceptable pollutant emission levels are equally essential objectives. Both theequivalence ratio distribution and flow field characteristics near the spark plug near the time of igni-tion strongly influence the quality of individual burning cycles. For this reason, an understanding oftheir effects on ignition stability is of utmost importance in the SIDI engine development process. Thispaper describes several imaging techniques and their use in the investigation of spray-guided SIDIengine operation with a particular focus on near-spark-plug events. 2. Imaging of velocity, fuel distribution, and flame propagation Particle Image Velocimetry (PIV), Planar Laser Induced Fluorescence (PLIF) and OHchemilumines-cence experiments were conducted in a single-cylinder SIDI engine. Optical access is made possibleby a quartz window placed in the extended (Bowditch) piston, as well as through the quartz cylinderliner and pent roof windows. More details of the engine are given by Fissenewert et al. [2] and Smithand Sick [3]. The generic setup, shown in figure 1, was used for all the experiments, while the hard-ware was appropriately selected for each case, as specified in the table given in figure 1 and subse-quent sections. Figure 1 Schematic setup for PIV,LIF, and OH* chemiluminescence experiments. Relevant hardwarespecifications for each experiment are listed in the table on the right. Further description of the indi-vidual experimental setups is given in the following sections. 2.1. Optical engine operation The single-cylinder engine was fueled with iso-octane for all experiments. For PLIF applications, dif-ferent tracers were added as will be described below. Fuel was injected through an eight-hole injectorwith an end-of-injection timing of 40 crank angle degrees (CAD) before top dead center (BTDC). Ig-nition started at 34 °BTDC. The engine was operated in a skip-fired mode, one in three cycles fired forPIV experiments, and continuously fired otherwise. Optional intake air dilution with nitrogen to simu-late exhaust gas re-circulation was available as well [3]. 2.2. Particle Image Velocimetry Laser Doppler Velocimetry (LDV) has been previously applied to obtain single and two-point meas-urements in premixed internal combustion engines [4, 5]. The development of PIV as a robust opticaldiagnostic technique allows the recording of instantaneous, two-dimensional, velocity field data fromwhich relevant flow field quantities (e.g. strain rates and vorticity) can be calculated [6, 7]. These pa-rameters can provide valuable information beyond the more traditional considerations of ensembleaverage velocities and RMS fluctuations. Two-dimensional velocity data have been obtained in mo-tored SIDI [8] and fired PFI engines using PIV [9-11]. While the impact of the flow field on ignitionand engine performance in spark( 1ignition engines has been recognized, instantaneous, two-dimensional velocity data near the spark plug at the time of ignition in fired SIDI engines have beennon existent until now. This can be attributed to the harsh environment that the experimentalist mustovercome to obtain reliable velocity data under such conditions. In this work, PIV was used to obtain velocity data around the spark plug near the time of ignition ina fired SIDI engine. The flow was seeded with 1 um silicone oil droplets. A pair of frequency-doubledNd:YAG lasers (New Wave Minilase) provided 13 mJ pulse each. Using a telescope arrangement, a 1mm thick light sheet was created to illuminate the flow. An image pair was recorded per cycle everythree cycles, on a 1376 x 1040 pixel CCD camera (FlowMaster Intense, LaVision). A bandpass filter (532 nm) was attached to the camera lens to minimize interference. LaVision Davis 6.2 was used forsynchronization and data processing. Many experimental issues were anticipated to challenge the application of PIV near top dead centerunder firing conditions. The major noise contributions were expected to come from scatter off the pis-ton surface, cylinder walls, and engine head, as well as from the spark luminosity. As a result of lateinjection, Mie scattering from the remaining spray droplets could overwhelm the signal from the seed-ing particles [12]. A sufficient dynamic velocity range was also needed to resolve flow and sprayspeeds. As top dead center is approached after the ignition event, a temperature rise above the dropletboiling point prevents maintaining homogeneous seeding, compromising the validity of the calculatedvelocity fields, and ultimately placing a limit on the number of crank angles after ignition over whichreliable data can be acquired. The bandpass filter was effective in minimizing signal contributions from the spark luminosity.The noise contribution from piston and cylinder surface scatter was greatly reduced by subtractingbackground images recorded prior to seeding the flow. The spray velocity, initially estimated at 20m/s, was resolvable with the dynamic velocity range of the present setup. The limit on the maximumnumber of recorded images was not determined by optical access obstruction due to oil deposition onthe cylinder walls, but was rather set by the maximum operating temperature of the quartz liner. Figure 2 Instantaneous velocity fields obtained near TDC compression in a spray-guided SIDI engineThe left column shows images taken without fuel injection and ignition. The right column shows im-ages recorded under firing conditions. End-of-injection is at 40 °BTDC and ignition starts at 34°BTDC. Examples of individual velocity fields at different crank angles are shown in figure 2. In each case,a set of fifty images was recorded while motoring the engine before activating the injection and igni-tion drivers to assess the seeding density and homogeneity level in the absence of effects from thespray residual and spark luminosity. During the same engine run, isooctane was then injected and theengine fired. Fifty images were recorded under firing conditions. Figure 2 shows results at 33, 31, and29 °BTDC. Here, the flow fields have been superimposed onto the background to provide a geometricreference for the velocity fields. The white stripe dividing each image is due to the presence of grafoillinings between the quartz cylinder and cylinder head. The left column in figure 2 shows instantaneous fields in the absence of ignition and combustion,whereas the right-column images, recorded under firing conditions, show how clockwise charge mo-tion is disturbed by the residual spray momentum, especially at 33 °BTDC. Based on high-speedchemiluminescence data, the outlook for obtaining additional flow field information at later crank an-gles is promising. Further work will focus on separating spray and gas velocities and examining thoseflow field quantities relevant to combustion stability. 2.3. High-speed planar laser induced fluorescence imaging ofbiacetyl Planar laser induced fluorescence imaging of fuel distributions in internal combustion engines has be-come one of the most widely used laser-based imaging techniques [13]. Typically, a non-fluorescingfuel is doped with a fluorescing tracer, e. g. 3-pentanone or toluene. Mostly, excitation is accom-plished with KrF excimer lasers (248 nm) or frequency-quadrupled Nd:YAG lasers (266 nm). Duringthe development of a high-speed version of fuel PLIF imaging, excitation at 355 nm from a frequency-tripled Nd:YAG laser was considered [14]. Excimer lasers are available with pulse repetition rates of ~2 kHz and pulse energies of 10-20mJ. However, such systems are very large and costly. On the otherhand, high-repetition rate Nd:YAG lasers are now available at moderate cost and size; however, pulseenergies at 266 nm are in the uJ-range, which is not enough for imaging in engines. Therefore, absorp-tion and fluorescence properties of biacetyl were investigated in more detail for its use as a fuel tracerin engines [15] using excitation at 355 nm. Biacetyl had been used in the past for engine experiments[16] but had not been further pursued as an alternative to other tracers. The iso-octane fuel was doped with 10 vol.-% of biacetyl as a fluorescence tracer. The excitationsource was a frequency tripled Nd:YAG laser (Quantronix Hawk) which produced nominal pulse en-ergies of 0.41 mJ at 12 kHz. At this repetition rate, the pulse width is approximately 100 ns. The cir-cular beam (approximate 0.6 mm diameter at outlet) was directed at a 45° mirror which reflects 355nm light while transmitting 532 nm light (AR-coating on backside). After the mirror, the light wasdirected through sheet-forming optics (Rodenstock) to create a light sheet with a cross section of ap-proximately 35 mm x 0.5 mm near the spark plug in the engine. The imaging system involves a high-speed CMOS camera (Vision Research Phantom V7.1) which is capable of capturing 4800 fps at full800x600 pixel resolution. When an engine is running at 2000 RPM, the frame rate must be set to12000 frames per second to achieve crank angle resolution. This reduces the image size to 386x386pixels. The camera uses a memory gating function which allows for recording only during certain pe-riods of the engine cycle. By utilizing this, the portions of the cycle that are of interest (e. g. injection,vaporization and combustion during the compression and early expansion stroke) can be recorded,while the remainder of the cycle is excluded. This allows for many more consecutive cycles to be re-corded; generally 300 to 400 per experimental run. To increase signal levels, a lens-coupled image intensifier (LaVision HS-IRO) was used. Fluores-cence signals were focused onto the intensifier with a Nikkon 105 mm (f#=1.2) lens. The transmissionof this lens decreases rapidly below 400 nm. A WG 385 filter (Schott) helped to efficiently suppressthe recording of Mie scattering and scattered laser light from surfaces. The image sequence shown in figure 3 was taken in the motored engine. The plume of one of theeight fuel jets is captured when hitting the spark plug electrodes to be split in two orthogonally propa-gating jets. Comparing the PLIF images with the velocity fields shown in figure 2, it is noticed that at29°BTDC almost all liquid droplets have evaporated and that the measured signal is predominantlydue to gas phase biacetyl. Images were corrected for light sheet inhomogeneity but not for changes inabsorption and fluorescence quantum yield. The strong fuel stratification that remains until very late is consistent with prior observations on flame propagation made with OH*-chemiluminescence imaging,see section below and [3]. Figure 3 Biacetyl PLIF imaging sequence recorded at 12 kHz which equals 1 CAD resolution at 2000RPM, in a motored spray-guided SIDI engine. The intensity scale (right) provides relative signal in-formation. Numbers given in the images are CAD BTDC timing stamps. 2.4. Double-pulse planar laser induced fluorescence of toluene and high-speed imaging ofOHEspecially when investigating cause and effect of ignition stability, it is desirable to obtain informationabout fuel concentration distribution, spark behavior, and flame initiation and propagation within indi- vidual cycles. This can be accomplished with a combination of PLIF of toluene and chemilumines-cence imaging. Two KrF excimer lasers (Lambda Physik Compex 110, 248 nm) were synchronized tothe engine crank angle encoder in such a manner that they fired with a time separation of1 CAD. Thelaser repetition rate can be high enough to fire once every subsequent engine cycle. Thus, two fueldistribution images can be obtained per engine cycle. Figure 4 Combined imaging of PLIF of toluene (34 and 33 °BTDC), spark plasma emissions (30-24°BTDC), and OH chemiluminescence (25°BTDC-15 °ATDC) allows crank angle resolved studiesat 12 kHz frame rate. The fluorescence signals of toluene were filtered with a narrow bandpass filter [17] centeredaround 300 nm. Signals were collected with a UV transparent lens (Halle, f=100 mm) and recordedwith an image-intensified CMOS camera system (Vision research Phantom 7.1 and LaVision HS-IRO). The spark event itself can also be monitored with the same setup since the plasma emissionsfrom the spark contain a band near 300 nm originating from OH radicals [18]. Lastly, flame initiation and propagation can be monitored well via OH chemiluminescence imaging at high image frame rates[19]. Again, the filter setup chosen for toluene fluorescence imaging accommodates the detection ofthese emissions as well. At camera frame rates of 12 kHz, one image per CAD can be recorded forseveral hundred consecutive cycles (see also section 2.2 for more details). Signal intensities of LIF andchemiluminescence can be adjusted via suitable selection of laser pulse energy and intensifier gatetiming to match the dynamic range of the camera. The image sequence shown in figure 4 illustrates the fuel distribution just prior to ignition followedby a long period (~10 CAD) of only emissions from the spark event before at 25 °BTDC the first in-dication of a growing flame is noticed. Note that in contrast to the example shown in the previous sec-tion, the fuel jet here is not split upon impingement on the spark electrode, illustrating the need forcrank angle resolved imaging rather than phase-averaged scanning of engine cycles. 3. Conclusions A brief overview was given on some imaging techniques that are useful for studies of in-cylinder mix-ing, ignition and combustion. Particular examples were discussed illustrating measurements in an op-tical single-cylinder spark-ignition engine that was operated in the spray-guided direct-injection re-gime. Particle image velocimetry was implemented to measure velocity fields around the spark plugin a firing engine. The use of a diode-pumped frequency-tripled Nd:YAG laser, in combination with aCMOS camera and high-speed image intensifier, allowed measurements of fuel distributions at ratesof 12 kHz, corresponding to 1 CAD at 2000 RPM. Finally, the combination of imaging of LIF of tolu-ene, plasma emission, and OH chemiluminescence with a single camera provides a useful tool forstudies of cause and effect of cyclic variability on engine performance, such as power fluctuation orignition instabilities. 4. Acknowledgements This work was sponsored by General Motors Corporation through the General Motors-University ofMichigan Collaborative Research Laboratory on Engine Systems Research. JDS is grateful to the Col-lege of Engineering for a Graduate Student Instructor appointment. The authors are also indebted toJames F. Driscoll and Steven L. Ceccio at The University of Michigan for the loan of the Nd:YAGlaser. References ( 1. Zhao F, Lai M-C, Harrington D L. 1999 Automotive Spark-Ignited Direct-Injection GasolineEngines. Progress in Energy and Combustion Science;25(5) 437-562. ) ( 2. Fissenewert U, Sick V, Pucher H. 2005 Characterization of combustion and NO formation in a spray-guided g asoline direct-injection engine using chemiluminescence imaging, NO-PLIF, and fast NO exhaust gas analysis. SAE Paper 2005-01-2089. ) ( 3. Smith J D, S ick V . 2005 H i gh-Speed F u el T r acer Fluorescence a nd O H Radical Chemiluminescence Imaging In a Spar k -Ignition Dire c t-Injection Engi n e. Applied Optic s accepted for publication. ) ( 4.I R ask R B. 1979 Laser Doppler anemometer measurements in an internal combustion engine.SAE Paper 790094. ) ( 5. Arcoumanis C, Hull D R, Whitelaw J. 1997 Optimizing local charge stratification in a lean- burn spark ignition engine. P roceedings of the Institution of Mechanical Engineers Part D-Journal ofAutomobile Engineering;211(2) 1 45-154. ) ( 6. R affel M, W illert C E , Kompenhans J. Particle Image Velocimetry: a practical g u ide. 1 e d.Berlin: Springer Verlag; 1 998. ) ( 7. Reuss D L, Kuo T, K h alighi B , H a worth D, Ro s alik M. 1995 Par t icle Im a ge Vel o cimetryMeasurements i n a H i gh-Swirl E n gine Us e d for Evaluation of Com p utational Flu i d ) Dynamics Calculations. SAE Technical Paper Series 952381. 8. Richter M, Axelsson B, Alden M, Josefsson G. 1999 Investigation of the fuel distributionand the in-cylinder flow field in a stratified charge engine using laser techniques andcomparison with CFD-modelling. SAE Paper 1999-01-3540. 9. Reuss D L, Rosalik M. PIV measurements during combustion in a reciprocating internalcombustion engine. In: Laser Techniques Applied to Fluid Mechanics; 2000;Lisbon? 2000.p. 441-456. 10.Hildenbrand F, Schulz C, Sick V, Josefsson G, Magnusson I, Andersson O, et al. 1998 Laserspectroscopic investigation of flow fields and NO-formation in a realistic SI engine. SAETransactions;107(Journal of Engines, Section 3) 205-214. 11.Josefsson G, Magnusson I, Hildenbrand F, Schulz C, Sick V. 1998 Multidimensional laserdiagnostic and numerical analysis of NO formation in a gasoline engine. Proc. Combust.Inst.;27 2085-2092. 12.Driscoll K D, Sick V, Gray C. 2003 Simultaneous Air/Fuel-Phase PIV Measurements in aDense Fuel Spray. Exp. Fluids;35(1) 112-115. 13.Schulz C, Sick V. 2005 Tracer-LIF Diagnostics: Quantitative Measurement of fuelconcentration, temperature and fuel/air ratio in practical combustion systems. Prog. EnergyCombust. Science;31 75-121. 14.Smith J D, Sick V. 2005 Crank-Angle Resolved Imaging of Biacetyl Laser-InducedFluorescence in an Optical Internal Combustion Engine. Applied Physics B;submitted. 15.Wermuth N, Sick V. 2005 Absorption and fluorescence data of acetone, 3-pentanone,biacetyl, and toluene at engine-specific combinations of temperature and pressure. SAEPaper2005-01-2090. 16.Baritaud T, Heinze T.1992 Gasoline distribution measurements with PLIF in a SI engine.SAE Paper 922355. 17.Frieden D, Sick V. 2003 Investigation of the fuel injection, mixing and combustionprocesses in an SIDI engine using quasi-3D LIF imaging. SAE Paper 2003-01-0068. ( 18.Fansler T D, Drake M C , S t ojkovic B D, Ro s alik M E . 2 002 Local Fuel Concentration,Ignition and C ombustion in a Str a tified Ch a rge Spark Igni t ed Direct Injec t ion Engine: Spectroscopic, Imaging and Pressure-Based Measurements. International Journal of Engine Research;4(2) 61-87. ) ( 19.Stojkovic B D, Fansler T D, Drake M C , Sick V . 2 005 High-Speed I m aging of O H * andSoot Temperature and Concentration i n a S t r atified-Charge D i rect-Injection G asoline Engine. Proc. Combust. Inst.;30 2657-2665. )
关闭还剩6页未读,是否继续阅读?
北京欧兰科技发展有限公司为您提供《内燃机中速度场,浓度场,发光现象检测方案(粒子图像测速)》,该方案主要用于其他中速度场,浓度场,发光现象检测,参考标准《暂无》,《内燃机中速度场,浓度场,发光现象检测方案(粒子图像测速)》用到的仪器有德国LaVision PIV/PLIF粒子成像测速场仪、汽车发动机多参量测试系统、时间分辨平面激光诱导荧光测量系统。
