食品中甜味剂、防腐剂和咖啡因检测方案(液相色谱仪)
检测样品
其他食品
检测项目
过敏原
关联设备
共1种
The Agilent 1290 Infi nity II LC was used to analyze additives such as sweeteners, preservatives, and caffeine in various food products, beverages, and consumer toothpaste. The developed method facilitates accurate and sensitive determination of nine additives using a diode array detector (DAD) and an evaporative light scattering detector (ELSD) placed in series. After the DAD, a valve was installed to remove nonretained solutes in reversed-phase LC, which could increase the noise level of the ELSD. Total analysis time, including re-equilibration, was below 10 minutes with minimal sample preparation. Method performance was evaluated with standard solutions as well as with a series of real samples.
安捷伦科技(中国)有限公司为您提供《食品中甜味剂、防腐剂和咖啡因检测方案(液相色谱仪)》,该方案主要用于其他食品中过敏原检测,参考标准《暂无》,《食品中甜味剂、防腐剂和咖啡因检测方案(液相色谱仪)》用到的仪器有Agilent 1290 Infinity II 液相色谱系统。
我要纠错
