The Agilent 7700x/7800 ICP-MS combines the simplicity of a single collision cell mode (helium mode) for polyatomic interference removal with the superior matrix tolerance of its unique High Matrix Introduction (HMI) system. Octopole Reaction System (ORS) cell technology provides higher sensitivity and more effective interference removal than ever before in complex, high matrix samples, eliminating the need for reactive cell gases in routine analysis. Helium mode on the ORS is so effective that interference correction equations can also be eliminated. These two factors redefine ease of use in ICP-MS, removing two of the most common causes of errors in multi-element analysis of complex samples. A challenging 15-hour sequence of high matrix soils, waters, seawaters and sediments was analyzed according to US Environmental Protection Agency (EPA) Method 6020A. The Agilent 7700x ICP-MS delivered excellent recovery of certified values for six standard reference materials, with no quality control failures throughout the entire sequence.
关闭产品配置单
安捷伦科技(中国)有限公司为您提供《高基质样品中简单、可靠分析检测方案(等离子体质谱)》,该方案主要用于环境水(除海水)中(类)金属及其化合物检测,参考标准《暂无》,《高基质样品中简单、可靠分析检测方案(等离子体质谱)》用到的仪器有Agilent 8900 ICP-MS/MS。
