北京豫维科技有限公司联系人:水先生电话:18911849923PTCA(PART B: CHEM. ANAL.)理化检验-化学分册2011年第47卷 北京豫维科技有限公司联系人:水先生电话:18911849923马萍等:顶空气相色谱-质谱法测定大型玩具中芳香烃化合物理化检验-化学分册 工作简报 顶空气相色谱-质谱法测定大型玩具中芳香烃化合物 马 萍,高 骏,吕小红,鲍 俊 (宁波市产品质量监督检验研究院国家文教用品质量监督检验中心,宁波315600) 摘 要:提出了顶空气相色谱-质谱法测定大型玩具中苯、甲苯、乙苯、间(对)二甲苯、邻二甲苯、萘、蒽等7种挥发性芳香烃残留量的方法。选择顶空平衡温度和时间分别为90℃和40 min,用RTX-5色谱柱分离,电子轰击离子源检测。7种芳香烃化合物在一定的质量浓度范围内与其峰面积呈线性关系,方法的检出限(3S/N)在0.02~0.04 mg·kg-之间。在3个添加水平上做回收试验,加标回收率在90.0%~106.8%之间,相对标准偏差(n=7)在0.3%~5.3%之间。 关键词:顶空气相色谱-质谱法;芳香烃;大型玩具 中图分类号:0657.63 文献标志码:A 文章编号:1001-4020(2011)11-1286-03 Head Space-GC-MS Determination of Aromatic Hydrocarbons in Large-Toys MA Ping, GAO Jun, LU Xiao-hong, BAO Jun (National Supervision and Inspection Center of Stationery and Education Products Quality, Ningbo MunicipalResearch Institute of Quality Superuision and Inspection of Products, Ningbo 315600, China) Abstract: Head space-GC-MS was applied to the determination of 7 aromatic hydrocarbons (i.e., benzene,toluene, ethylbenzene, o-xylene, m-xylene, p-xylene, naphthalene and anthracene) in large-toys. The equilibriumtemperature and time of head space were selected at 90 ℃ for 40 min. The analyte were separated on RTX-5 columnand EI source was used in MS. Linear relationships between values of peak area and mass concentration of the 7aromatic hydrocarbons were kept in definite ranges. Detection limits (3S/N) found were ranged from 0. 02 to0.04 mg·kg. Tests for recovery were performed by addition of mixed standard of the 7 aromatic hydrocarbons at3 concentration levels, results of recovery found were in the range of 90.0%-106.8% with RSD's (n=7) in therange of 0.3%-5.3%. Keywords: Head space-GC-MS; Aromatic hydrocarbons; Large-toys 大型玩具的大部分组件由塑料橡胶、纺织品和皮革制成。塑料橡胶可能在挤塑成型过程中与脱模剂接触,引入了芳香烃类化合物;纺织品、皮革制作过程中因使用染料也引入了芳香烃类化合物。而大部分芳香烃类化合物是强致癌物质,损伤生殖系统,易导致皮肤癌、肺癌等疾病,儿童在玩耍时接触到塑 ( 收稿日期:2011-03-15 ) ( 基金项目:国家质量监督检验检疫总局公益性行业科研专项 (2009424063-03) ) ( 作者简介:马萍(1981一),女,黑龙江大庆人,博士,工程师,主要研究方向为玩具/文具的检测技术研究。 ) 胶、纺织品、皮革制成的部件,对健康有很大的影响。 在发达国家,大型玩具进入时间较早,它的安全已倍受关注,在我国其是作为新型的玩具品种出现,缺乏市场监管,相应标准缺失严重。目前有关芳香烃的检测多集中在大气环境和水等领域,在玩具领域少见芳香胺类化合物的检测,欧盟 EN 71 玩具安全标准对初级芳香胺的检测方法有规定,目前该标准还存在一些不够完善的地方,所列受检物质不适用于大型玩具产品。因此填补国内大型玩具检测标准空白,建立大型玩具中芳香烃类化合物的测定方法是十分必要和迫切的。目前常用的芳香烃前处 理方法有静态顶空法、吹扫捕集法、固相微萃取法[2-5]等,完全可以满足较低含量挥发性有机物的要求。本工作用顶空气相色谱-质谱法测定大型玩具中芳香烃化合物的残留量,其中包括苯、甲苯、乙苯、间(对)二甲苯、邻二甲苯、萘和蔥的含量。 试验部分 1.1 仪器与试剂 QP 2010型岛津气相色谱质谱仪, combi PAL顶空自动进样器。 苯、甲苯、乙苯、间(对)二甲苯、邻二甲苯混合标准溶液:100mg·L-1。 萘标准溶液:200mg·L。 蒽标准溶液:200mg·L-1。 二氯甲烷为色谱纯。 1.2 仪器工作条件 顶空进样条件:平衡温度90℃,平衡时间40 min,顶空进样针温度100℃,进样量1mL,用高纯氦气推动和清洗顶空针,清洗时间为2 min,顶空用氦气压力为0.8 Pa。 色谱条件:RTX-5(5%二联苯聚氧硅烷-95%二甲基聚氧硅烷)色谱柱(0.25 mm×30 m,1.4 um),载气流量1.47 mL·min,进样口温度235℃,进样量1 mL,不分流进样。柱程序升温:初始温度70℃,保持5 min,以10℃·min速率升温至250℃,保持5 min。 质谱条件:电子轰击(EI)离子源,电子能量70 eV,离子源温度230℃,接口温度250℃,溶剂切除时间2.8 min。 1.3 试验方法 取大型玩具聚合物材质类样品,液氮密封粉碎样品至1 mm×1 mm 左右,称取混合碎片样品1g,置于顶空瓶内密封,按仪器工作条件进行测定。 2 结果与讨论 2.1 顶空条件的选择 固定顶空平衡时间为30 min,考察平衡温度在70℃~140℃范围内对目标化合物的影响。结果表明:7种芳香烃化合物由于沸点不同,各自最佳平衡温度亦不同,在90℃时,7种物质均有较好的响应值,试验选择90℃为平衡温度。 固定平衡温度90℃,考察平衡时间在20~60 min范围内对目标化合物的影响。结果表明:当 平衡时间为20 min 时,除萘外,其他6种芳香烃化合物均有较好的响应值,将平衡时间延长至40 min时,包括萘在内7种芳香烃化合物均有较强的响应。试验选择40 min 作为平衡时间。 2.2 色谱行为 芳香烃混合标准品及加标空白玩具样品的色谱图见图1。苯、甲苯、乙苯、间(对)二甲苯、邻二甲苯、萘、蒽的保留时间依次为3.810,6.662,9.158,9.483,10.069,16.158,25.075 min。 间(对)二甲苯 (a) 芳香烃混合标准品 (b) 加标空白玩具样品 图1 7种芳香烃混合标准品(a)和加标空白玩具样品(b)的色谱图 Fig. 1 Chromatograms of mixed standard of the 7 VOC's (a) andblank sample of toys with addition of mixed standard (b) 2.3 标准曲线及检出限 分别移取一定量的100 mg·L-的苯、甲苯、乙苯、间(对)二甲苯、邻二甲苯混合标准溶液,200 mg·L-1的、蔥标准溶液,用二氯甲烷稀释配成0,2,5,10,15,20,40mg·L-1的芳香烃混合标准溶液。 按色谱条件对混合标准溶液系列进行测定,以7种芳香烃化合物的质量浓度为横坐标,峰面积为纵坐标绘制标准曲线,其线性范围、线性回归方程、相关系数和7种芳香烃化合物的检出限(3S/N)见表1. 2.4 回收试验 在大型玩具空白样品中分别加入3个不同浓度 表1线性范围、线性回归方程、相关系数和检出限 Tab. 1 Linearity ranges, linear regression equations, correlation coefficients and detection limits 化合物 线性范围 线性回归方程 相关系数 检出限 p/(mg·L-1) w/(mg·kg) 苯 2~20 y=2.593×106x-4.104×104 0.999 8 0.04 甲苯 2~20 y=2.448×106x-2.655×104 0.9991 0.02 乙苯 2~20 y=2.628×106x-4.251×104 0.999 5 0.02 间(对)二甲苯 4~40 v=2.100×106x-7.567×104 0.999 5 0.02 邻二甲苯 2~20 y=2.115×106x-3.838×104 0.9993 0.02 萘 2~20 y=1.764×106x+2.076×104 0.9996 0.04 蒽 2~20 y=8. 699×10x-6.142×104 0.9999 0.04 水平的芳香烃混合标准溶液,按试验方法对加标玩 具样品进行回收试验,结果见表2。 表2回收试验和精密度试验结果(n=7) Tab. 2 Results of tests for recovery and precision 化合物 加标量 回收率 RSD 化合物 加标量 回收率 RSD w/(mg·kg) /% /% w/(mg·kg) /% /% 苯 2 100.0 0.3 邻二甲苯 2 105.0 0.8 5 95.7 0.7 5 95.7 0.7 10 97.1 1.6 10 92.1 2.4 甲苯 2 98.6 1.6 萘 2 91,7 1.3 5 94.3 2.1 5 96.4 2.6 10 90.0 4.0 10 106.8 4.2 乙苯 2 105.0 0.5 蒽 2 102.3 3.3 5 91.3 0.8 5 96.7 3.7 10 97.9 2.2 10 92.3 5.3 间(对)二甲苯 4 101.4 0.6 10 99.3 1.2 20 95.4 5.0 2.5 样品分析 按试验方法对10份聚合物材质类大型玩具样 品进行测定,其中4份大型玩具样品未检出芳香烃,6份大型玩具样品检出芳香烃,结果见表3. 表3样品分析结果 Tab. 3 Analytical results of samples 样品 测定值w/(mg·kg-) 苯 甲苯 乙苯 间(对)二甲苯 邻二甲苯 萘 蒽 1 0.09 0.07 0.11 0.05 2 0.05 0.03 0.05 0.02 3 — 0.03 0.04 0.05 0.06 4 0.17 0.09 二 二 5 0.06 一 一 6 0.18 0.24 0.21 0.30 0.13 本工作建立了 HS-GC-MS 测定大型玩具中7种芳香烃的方法,样品前处理简单,易操作,方法的线性范围宽、精密度好、准确度高、快速灵敏,适用 于大型玩具中苯、甲苯、乙苯、间(对)二甲苯、邻二甲苯、、蒽等残留量的测定。 (下转第1292页) 环氧乙烷加合数大于5的 MEE 产品在室温下存放时,往往容易发生分层现象,加热时分层现象消失,由于下层存在少量的高加合数产品,其凝固点较高,这是导致产品发生分层现象的主要原因。其次,产品中存在的副产物二酯、残留的催化剂以及相对分子质量较大的副产物聚乙二醇,均是导致产品发生分层现象的因素。因此,使用前,非离子储罐需要进行循环,装产品则可直接进行使用。也可采用配制为800g·L-水溶液作为最终产品来解决分层问题。从产品的性质及应用性能方面考虑,在生产过程中为控制和提高产品的纯度、减少副产物含量改进催化剂的窄分布催化性能等方面的研究工作,仍需近一步开展。 产品自身组分是导致聚羟乙基脂肪酸甲酯发生分层现象的原因。高环氧乙烷加合数组分、副产物二酯、催化剂残留以及大分子量的聚乙二醇均会引起产品的分层。 本工作建立了测定 MEE 产品中副产物二酯的分析方法。样品经水解处理后,收集所得亲水基部分做HNMR分析,测定副产物二酯的含量。 ( 参考文献: ) ( [1] H AMA I, SASAMOTO H, TAMURA T, et al. Skincompatibility and ecotoxicity of ethoxylated fatty meth yl ester nonionics J ]. J ournal of Surfactants a n d De-tergents, 1998, 1 (1):9 3 -97. ) ( 2] 罗毅,孙永强,田春花,等.脂肪酸甲酯乙氧基化物的物化性能研究[J].日用化学工业,2001,31(5):5-7. ) ( [3] 勋费尔特N.非离子表面活性剂的制造、性能和分析 [M].北京:轻工业出版社,1990:510,844-845. ) ( 4] 王军.新型非离子表面活性剂脂肪酸甲酯乙氧基化物[J].精细化工,1998,15(增刊):156-161. ) )K02-0-K2-0 (上接第1288页) ( 参考文献: ) ( [1 ] 吕庆,张庆,康苏媛,等.顶空气相色谱-质谱法测定玩具中的10种挥发性有机物[J].色谱,2010,28(8): 800-804. ) ( 21 吕庆,张庆,康苏媛,等.顶空气相色谱-质谱法测定涂料中的5种挥发性有机物[J].分析测试学报,2011,30 (2):171-175. ) ( 3] 彭敏,周亚民,彭小兰.吹扫捕集-气相色谱-质谱联用测 ) ( 57 B EHLER, AN S GER, FOLGE, et al. Pro c ess for pre-paring alkoxylated 1 fatty acid a alkyl e sters: US, 6008392[P].1999-12-28. ) ( [6 HAMA I,O K AMOTO T, H IDAI E, et al. D i rect ethoxylation of fatty methyl ester ove r Al-Mg compos- i te oxide c atalyst [J]. Journal of t he American Oi l Chemists Society, 1 997,74(1):19-28. ) ( 17 HAMA I, SASAMOTO H, OKAMOTO T. Influence of c atalyst s tructure o n d i rect ethoxylation of fatty methyl esters over Al-Mg composite oxide catalyst[J]. J ournal of the American Oil Chemists Society, 1 997: 74(7):817-822 ) ( [ 8] 马利静,周卯星,冯瑜.脂肪酸甲酯乙氧基化物的气相 色谱分析[J].色谱,2004,22(1):84- 8 6. ) ( 97 朱力,刘裕婷,杨大鹏.石墨炉原子吸收光谱法测定饮用水中的铝[J].中国卫生检验杂志,2006(6):687- 688. ) ( [10] 严方,高文苗,罗文,等.原子吸收法测定催化剂中镧 含量[J].中国测试,2009,1:81-83. ) ( [117 李得志,孙永强,杨秀全,等.蓖麻油脂肪酸甲酯乙氧基化物中环氧乙烷分布检测[J].日用化学工业, 2005,35(5):327-330. ) ( [12] LITTAU, CHERYL ANN, WIMMER, et al. De- tergents, cleaning compositions an d disinfectants comprising chlorine-active substances a nd fatty acid alkyl ester ethoxylates: US, 6303564[P].2001-10- 16. ) ( [13] C OX M F. Ef f ect of al k yl c a rbon chain l e ngth andethylene o xide content on the performance of l in e ar alcohol ethoxylates [J]. Journal o f the A merican Oil Chemists Society, 1989,66(3):367-374. ) ( [14] 赵国玺,朱步瑶.表面活性剂作用原理[M].北京:轻 工业出版社,2003:38-48. ) 【2)2 ( 定水中挥发性芳烃化合化[J].中国卫生工程学,2008, .7(6):359-362. ) ( 4 张玉玲,张兰英,阿布巴卡尔·达布雷.吹扫-捕集技术在GC法测定地下水中苯系物的条件研究[J].吉林大 学学报:地球科学版,2003,33(2):255-256. ) ( [5] 高丽荣,卢志刚,朱海鸥,等.纺织品中军发性有机物的测定[J].南京工业大学学报:自然科学版,2010,32 (5):94-98. ) ·网址:www. yuweichina.com 邮箱watercom 提出了顶空气相色谱-质谱法测定大型玩具中苯、甲苯、乙苯、间(对)二甲苯、邻二甲苯、萘、蒽等7种挥发性芳香烃残留量的方法。选择顶空平衡温度和时间分别为90℃和40min,用RTX-5色谱柱分离,电子轰击离子源检测。7种芳香烃化合物在一定的质量浓度范围内与其峰面积呈线性关系,方法的检出限(3S/N)在0.02~0.04mg.kg-1之间。在3个添加水平上做回收试验,加标回收率在90.0%~106.8%之间,相对标准偏差(n=7)在0.3%~5.3%之间。
关闭还剩2页未读,是否继续阅读?
北京豫维科技有限公司为您提供《玩具中芳香烃化合物检测方案(毛细管柱)》,该方案主要用于玩具中芳香烃化合物检测,参考标准《暂无》,《玩具中芳香烃化合物检测方案(毛细管柱)》用到的仪器有null。
