Part of Thermo Fisher ScientificSP70763_E 07/13S Thermo Scientific Dionex Chromeleon 7.2Chromatography Data System Designed for MS Product Spotlight Thermo ScientificDionexChromeleon" 7.2 Chromatography Data System (CDS) is the first CDSthat supports Mass Spectrometry (MS) instrument control and data processing with all main front-endseparation techniques (GC, IC, LC) in an enterprise (client/server) environment. Chromeleon 7.2 CDSdelivers full control with native drivers for the Thermo Scientific ISQ Single Quadrupole GC-MSsystem and Thermo ScientificTSQ 8000 Triple Quadrupole GC-MS/MS system, including tuningand instrument calibration. Thermo Scientific ISQ GC-MS system Thermo Scientific TSQ 8000 GC-MS system Chromeleon 7.2 CDS contains the necessary MS-specific dataviews, data processing, and reporting capabilities to streamline yourchromatography and MS quantitation workflows in one application: New display of the Total lon Chromatogram (TIC) andMass Spectra. Thermo Scientific Dionex Chromeleon 7.2Chromatography Data SystemDesigned for MS 从 New component-centric views withsimultaneous visualizationof both quantitation and confirmation ions(injections in rows, components in columns) New MS Quantitation channel providingan overlaid view of all Extracted IonChromatograms (EICs) with simple manualextractions of EICs MS Quantitation channel. Graphic creation of EIC. Thermo Scientific Dionex Chromeleon 7.2Chromatography Data System Designed for MS Use NIST libraries for spectral library screeningand ad-hoc library searches. Also, directlyimport from predefined compound databases(e.g. Thermo Scientific"TraceFinder software)and NIST library searches into your componenttables NIST Library searching. Compound data import. Thermo Scientific Dionex Chromeleon 7.2Chromatography Data System Designed for MS TK Prak ane TC 1 274716519523 52 PCB418PCBPC8433PC8#52PC845PCa#702005PC84136PC8#153PCBH1SSPCO4170 0281 527.05410491 ne. a na 注 生2761 7050 34.324 nz n1210 690334 3455 na 1624 57.673 44314 na 13 直0777 n n 23 539 11.5161025 rua na s.a 2276 na 5050t 923X na 15H2 8.23303 M153 97440945 a 0291 1644 里生 na 17372代 代温 na na 汽 14923建 Ha 13150 New MS-based reporting objects andconsolidated report tables catering formultiple traces and large data sets, allowusers to quickly and easily evaluation andreport MS data. Integration table setup for all channels. No.TIC Peak NameTIC Area counts*minTIC Areacounts*min Highest Response Channel Highest Response 15611274799165198233 252 PCB#18 PCB#28 PCB#33 PCB#52PCB#95PCB#70 PCB#156 PCB#126 PCB#153 PCB#188 PCB#170 0.2812.7611.2101.6240.7721.0252.2763.3030.946 0.391 1.644 127.094 34.32469.03457.67811516 1.025 99.332 14.594 0.946 14.933 13.110 TIC F01 TIC F02TIC_F01TIC_F03TIC F06TICTIC_F06TIC_F05TIC TIC F10 TIC F10 Integration table setup for highest response channels. The Chromeleon 7.2 CDS enterprisesupport for MS gives you the ability tocontrol, process and report MS data fromremote PC's or even from another building,another site, or even in another country!The sharing of data has never been so easy! Chromeleon 7.2 CDS包含必要的MS特定数据视图,数据处理和报告功能来简化您的色谱和MS定量工作流程
关闭还剩2页未读,是否继续阅读?
赛默飞色谱与质谱为您提供《待测物质中待测物质检测方案(工作站及软件)》,该方案主要用于其他中待测物质检测,参考标准《暂无》,《待测物质中待测物质检测方案(工作站及软件)》用到的仪器有Chromeleon® 变色龙7色谱数据系统。
