OXFORDINSTRUMENT SThe Business ofScience材料成分和结构 Metals alloys and ceramics have a place in almost all of globalmanufacturing. Whether it is the turbine blades in a jet engine, theceramic brake pads on a sports car or the steel cables for asuspension bridge, understanding the composition and structureof these materials is critical in understanding their properties.Using electron microscopy it is possible to characterise boththese properties. Understanding the distribution and compositionof nanoscale precipitates in Ni-based superalloys is crucial to understanding their performance under extreme temperatures. Using energy dispersive x-rayspectrometry (EDS) in the transmission electron microscope (TEM) allows -resolutionanalysis of these materials to determine the chemistry of these precipitates. Our X-MaxN100TLE EDS is the perfect solution for this; the sensitivity allows analysis to be performedquickly and accurately whilst remaining sensitive to trace elements that may arise fromcontamination during the manufacturing process. In the scanning electron microscope(SEM), electronbackscatter diffraction canbe useddtto characterisestructural properties such as grain size and orientation aswell as stresses and strains within the . Our SymmetryEBSD is the perfect solution for any materials challenge,as the world’s first CMOS based EBSD camera it combinesspeed and sensitivity to acquire accurate results quickly. This speed and sensitivity are enabling -speed characterisation oflarge 3D volumes using slice and view techniques in the focusedion beam (FIB) ensuring that the structure and composition isunderstood not just in isiosloatliaotnion but inthe context of thesurrounding. For larger volumes still, x-ray computed tomography is the mostwidely used technique, these systems require -performance x-ray sources and detectors to ensure the highest quality data is collected. Our x-ray sources areused in tools to verify chemical composition of bulk materials by x-ray fluorence in primary and secondary (recycle) markets, as well as in x-ray diffractometers for precise crystallographicanalysis. X-ray imaging techniques of absorption or are the basis of measuring thicknessesand defects in composite and metal structures. @Oxford Instruments Metals alloys and ceramics have a place in almost all of global manufacturing. Whether it is the turbine blades in a jet engine, the ceramic brake pads on a sports car or the steel cables for a suspension bridge, understanding the composition and structure of these materials is critical in understanding their properties. Using electron microscopy it is possible to characterise both these properties. Understanding the distribution and composition of nanoscale precipitates in Ni-based superalloys is crucial to understanding their performance under extreme temperatures. Using energy dispersive x-ray spectrometry (EDS) in the transmission electron microscope (TEM) allows -resolution analysis of these materials to determine the chemistry of these precipitates. Our X-MaxN 100TLE EDS is the perfect solution for this; the sensitivity allows analysis to be performed quickly and accurately whilst remaining sensitive to trace elements that may arise from contamination during the manufacturing process.
关闭产品配置单
牛津仪器科技(上海)有限公司为您提供《材料中成分和结构检测方案(扫描探针)》,该方案主要用于其他中理化分析检测,参考标准《暂无》,《材料中成分和结构检测方案(扫描探针)》用到的仪器有牛津仪器高分子原子力显微镜Cypher ES、牛津仪器X-MaxTEM大面积硅漂移探测器、牛津仪器5000系列封装式X射线管、牛津仪器相机Andor Mechelle 5000、EBSD探测器Symmetry S3 牛津仪器。
