血红蛋白中振动圆二色光谱检测方案(圆二色光谱仪)
检测样品
其他
检测项目
振动圆二色光谱
关联设备
共1种
下载方案
The functionalities of chiral compounds have been studied for the development of advanced molecules for many applications. The study of chiral compounds has spread to several fields such as natural products, pharmaceuticals and other functional molecules, and it can be pointed out that among those studies, the structural analysis of chiral compounds is a very important topic. X-ray Diffraction (XRD), Nuclear Magnetic Resonance (NMR) and Electronic Circular Dichroism (ECD) using UV/Vis light are employed as primary methods for the structural analysis of chiral compounds. In this paper, the measurement of chiral compounds by Vibrational Circular Dichroism (VCD) using infrared light will be
outlined.
AApplication NoteDate:April 12, 2011 260-PO-0224 Measurement of Vibrational Circular Dichroism spectrausing the FVS-6000 It is generally understood that chiral compounds have different bioactivities depending upon the absoluteconfiguration of each compound. Some familiar examples include glutamic acid and thalidomide. L-glutamic acid demonstrates the“Umami”taste*1, while D-glutamic acid has a bitter taste, similarly, the Rform of thalidomide is a sedative, but the S form has teratogenic activity. Thus, the separation and studyof chiral compounds is critical for many reasons. The functionalities of chiral compounds have been studied for the development of advanced moleculesfor many applications. The study of chiral compounds has spread to several fields such as naturalproducts, pharmaceuticals and other functional molecules, and it can be pointed out that among thosestudies, the structural analysis of chiral compounds is a very important topic. X-ray Diffraction (XRD),Nuclear Magnetic Resonance (NMR) and Electronic Circular Dichroism (ECD) using UV/Vis light areemployed as primary methods for the structural analysis of chiral compounds. In this paper, themeasurement of chiral compounds by Vibrational Circular Dichroism (VCD) using infrared light will beoutlined. VCD is a method to measure the difference of absorbance intensity between left-hand and right-handcircularly polarized light as shown in Figure 1. It is an advantage of VCD that this method can be appliedto almost all organic compounds in the same way as infrared (IR) spectroscopy. In addition, bycomparing the measurement results with calculated results by ab-initio molecular orbital calculations, theabsolute configuration of the sample can be determined. However, since the peak intensity of VCDspectra are 1,000 -10,000 times weaker than that of standard IR spectra, spectroscopic instrumentswith high sensitivity and stability with very small baseline fluctuations are required. The FVS-6000 VCDsystem has a high sensitivity detector, suitable optical filter technology and a thermostatted PhotoElastic Modulator (PEM) to accurately measure the weak VCD peaks. The measurement results oftypical chiral compounds and hemoglobin as a model protein using the FVS-6000 are reported. *1 Umami taste is the fifth taste sensation in addition to sweet, acid, salty and bitter taste. Figure 2: External view of the FVS-6000 Figure 1:Principles of VCD spectroscopy Figures 3 through 6 illustrate the measurement results for alpha-pinene; 1,1-Bi-2-naphthol; proline andhemoglobin, respectively. Both IR and VCD spectra can be obtained by the FVS-6000. The identification ofthe absolute configuration of chiral compounds can be determined from both the IR and the VCD spectraas well as the analysis of the molecular structure. Figure 3 demonstrates the IR and VCD spectra of alpha-pinene which is a typical standard sample tovalidate a VCD instrument system. IR spectra of the R- and S- form of alpha-pinene are completelyoverlapped, while their VCD spectra are symmetric, clearly identifying each alpha-pinene enantiomer.Since the peak shapes of the VCD spectra obtained illustrate typical alpha-pinene spectra, it is confirmedthat high quality VCD spectra can be measured by the FVS-6000. Figure 4 outlines measurement results for 1,1-Bi-2-naphthol which is used as a ligand for transition-metalcatalyzed asymmetric synthesis and is a precursor for chiral ligands such as BINAP. The small peaks dueto the anisotropy factor 'g value'(VCD peak/IR peak) around 1600 and 1500 cm-1attributed to the benzenering are clearly shown. These results demonstrate that the FVS-6000 is a very effective system forevaluation of chiral compounds which have similar structures. Figure 5 illustrates the measurement results of proline which is one of the amino acids. Good,symmetricalVCD spectra were obtained for the D- and L-forms. Since amino acids demonstrate different bioactivitiesbetween the D- and L-forms, studies regarding structure and bioactivity are increasingly popular. Liquidsamples can be easily measured by VCD instrumentation so the structural analysis of amino acids can beperformed similar to physiological conditions. Figure 6 contains the measurement results for hemoglobin. Hemoglobin is known as a spherical modelprotein which contains rich alpha-helix structures, and in addition, its VCD spectrum shape is very differentfrom that of concanavalin A, which contains a rich beta-sheet structure. The addition of VCD spectral results to information obtained from ECD and IR spectra can provide muchmore accurate secondary structure analysis of proteins in solvents. We also believe that VCD can also bea powerful tool for the analysis of DNAand chiral polymers other than proteins. In this paper, the standard performance and measurement results of typical chiral compounds using theFVS-6000 were reported and we believe the FVS-6000 can be an essential and indispensable tool foranalysis of chiral compounds. CCH3 cut from the spectral figures. Figure 3: Spectra of alpha-pinene(neat, 50 pm pathlength BaF,liquid cell) Figure 4: Spectra of 1,1'-Bi-2-naphthol(solvent: CHCl3, concentration: 0.162 M,50 pm pathlength BaF, liquid cell) hemoglobin L-proline Figure 5: Spectra of proline(solvent: D,O, concentration: 0.9 M,25 pm pathlength CaF2 liquid cell) Figure 6: Spectra of hemoglobin (solvent: DO, concentration: 50 mg/mL,, 25 um pathlength CaF2 liquid cell) copyrightOJASCO CorporationJASCO INTERNATIONAL CO., LTD.- Sennin-cho -chome, Hachioji, Tokyo JapanTel:+ Fax: + The functionalities of chiral compounds have been studied for the development of advanced molecules for many applications. The study of chiral compounds has spread to several fields such as natural products, pharmaceuticals and other functional molecules, and it can be pointed out that among those studies, the structural analysis of chiral compounds is a very important topic. X-ray Diffraction (XRD), Nuclear Magnetic Resonance (NMR) and Electronic Circular Dichroism (ECD) using UV/Vis light are employed as primary methods for the structural analysis of chiral compounds. In this paper, the measurement of chiral compounds by Vibrational Circular Dichroism (VCD) using infrared light will be outlined.
关闭
1/3
2/3
JASCO 公司为您提供《血红蛋白中振动圆二色光谱检测方案(圆二色光谱仪)》,该方案主要用于其他中振动圆二色光谱检测,参考标准《暂无》,《血红蛋白中振动圆二色光谱检测方案(圆二色光谱仪)》用到的仪器有JASCO 日本分光 振动圆二色光谱仪 FVS-6000。
我要纠错
