鹰爪虾中质构检测方案(质构分析仪)
检测样品
水产品
检测项目
营养成分
关联设备
共2种
下载方案
目的为了研究冰温贮藏对鹰爪虾的保鲜效果及品质的变化情况,以期为海捕虾的贮藏保鲜提供理论参考依据。对于冰温组的虾样,每间隔2 d测定其各项指标;对于冷藏组的虾样,每隔1d测定其各项指标。
包装工程PACKAGINGENGINEERING第41卷 第17期2020年9月·46· 第41卷 第17期秦求思等:冰温贮藏对鹰爪虾鲜度及蛋白质特性的影响·47· 冰温贮藏对鹰爪虾鲜度及蛋白质特性的影响 秦求思1,李思敏,孟粉,董烨,毛海萍,张益奇1.2,戴志远1.2 (1.浙江工商大学海洋食品研究院,杭州310012;2.浙江省水产品加工技术研究联合重点实验室,杭州310012) 摘要:目的为了研究冰温贮藏对鹰爪虾的保鲜效果及品质的变化情况,以期为海捕虾的贮藏保鲜提供理论参考依据。方法以鹰爪虾为研究对象,对预冷后在冰温和冷藏条件条贮藏后其 pH 值、新鲜度(K值)、挥发性盐基氮(TVB-N)值、菌落总数(TVC)、质构及蛋白质特性变化(如巯基含量、肌动球蛋白含量和钙激活三磷酸腺苷(Ca-ATPase)酶活性)等情况进行分析。对于冰温组的虾样,每间隔2d测定其各项指标;对于冷藏组的虾样,每隔1d测定其各项指标。结果与冷藏组相比较发现,鹰爪虾在冰温贮藏过程中能够延缓 pH 值、TVB-N值、K值升高,抑制微生物的生长、TVC 值的升高,延缓肌动球蛋白含量、巯基含量的降低,抑制 Ca²+-ATPase 酶的失活,能有效地延长鹰爪虾的贮藏货架期。结论鹰爪虾在冷藏和冰温贮藏下的货架期分别为5d和10d,货架期延长了约5d,因此冰温贮藏更易于海捕虾的贮藏。 关键词:冰温贮藏;鹰爪虾;货架期;鲜度指标;蛋白质特性 中图分类号:TS254.4 文献标识码:A 文章编号:1001-3563(2020)17-0046-09 DOI:10.19554/j.cnki.1001-3563.2020.17.007 Effect of Ice-temperature Storage on Freshness Index and Protein Propertiesof White-hair Rough Shrimps QIN Qiu-si', LI Si-min', MENG Fen', DONG Ye', MAO Hai-ping', ZHANG Yi-qil, DAI Zhi-yuanl2 (1.Institute of Sea Food, Zhejiang Gongshang University, Hangzhou 310012, China;2.State Key Laboratory of Aquatic Products Processing of Zhejiang Province, Hangzhou 310012, China) ABSTRACT: The work aims to research the effect of ice-temperature storage on the preservation and quality changes ofwhite-hair rough shrimps to provide a theoretical reference for the storage and preservation of shrimps. White-hair roughshrimps (trachypenaeus curvirostris) were selected as subjects to analyze the changes in pH, freshness (K-value), totalvolatile basic nitrogen (TVB-N), total viable count (TVC), texture and protein properties such as sulfhydryl group (SH)actomyosin, and the deactivation of calcium activated adenosine triphosphate (Ca -ATPase) under ice-temperature andrefrigerated conditions after precooling. The shrimp samples of the ice-temperature group were measured every 2 days,and the shrimp samples of refrigerated group were measured every 1 day. Compared with the samples of the refrigeratedgroup, the results showed that trachypenaeus curvirostris stored in ice-temperature could delay the increase of pH, TVB-Nand K value as well as TVC, inhibit the growth of microorganisms and microorganisms, effectively delay the decrease of ( 收稿日期:20 2 0-05-01 ) ( 基金项目:浙江省重点研发计划(2019C02086) ) ( 作者简介:秦求思(1996 一 ),男,浙江工商大学硕士生, 主 攻水产品加工与贮藏。 ) ( 通信作者: 戴 志远(1958一),男,研究员,主要研究方向为水产品加工与贮藏 。 ) actomyosin, SH and inhibit Ca-ATPase inactivation, thus it could effectively prolong the shelf life of the shrimps. Theshelf life of trachypenaeus curvirostris in refrigerated storage and ice-temperature storage is 5 days and 10 days respec-tively and the shelf life of shrimps is significantly prolonged by about another 5 days. So ice-temperature storage make itis easier to store shrimps. KEY WORDS: ice-temperature storage; white-hair rough shrimp; shelf life; freshness index; protein properties 鹰爪虾(Trachypenaeus Curvirostris ) 俗尔厚壳虾、鸡爪虾、沙虾,隶属对虾科、鹰爪虾属,虾体较粗短,甲壳很厚。鹰爪虾出肉率高,肉质脆嫩鲜美,是中国产量较高的一种海捕虾类,主要产于黄海海域。中国目前海捕虾类以鲜销品为主要产品形式,但其头部和胸部酶活性很高,微生物种类多,很适宜腐败微生物的生长繁殖,虾体很容易腐败变质,这在一定程度上阻碍了海捕虾的销售售流通[2。冰温贮藏是将食品贮藏在0℃到冰点之间的冰温带,不仅能够缓解微生物腐败作用,延长水产品的保质期,而且机体内的理化指标无显著劣化,还能避免冻藏带来的虾类肉质结构的破坏③。另外,在冰温贮藏方面,大多数学者主要研究鱼类及其制品贮藏变化,如潘卓等4研究结果表明,与冷藏相比,在冰温保鲜条件下生食大西洋鲑的货架期可延长3d。洪慧、杨华、朱丹实等5一刀,也发现与冷藏相比较,冰温条件对水产品的保鲜更加有利。周果等发现冰温处理梭子蟹,其鲜度的变化速率均较冷藏、冰藏缓慢,货架期延长了1~2d。经研究9-10发现,在冰温条件下贮藏会延缓虾的黑变、抑制微生物繁殖,以及降低致腐能力和鲜度指标。文中拟研究冰温贮藏条件下鹰爪虾的鲜度变化指标和蛋白质的变化情况,通过对研究海捕虾鲜度的变化情况,可以为海捕虾鲜度评价和货架期评定体系的建立和完善提供一定的实验基础;同时,发现海捕虾蛋白指标与鲜度指标之间存在着密切的联系,有助于进一步揭示海捕虾在冰温贮藏过程中的腐败变化情况,推动虾类产品物流过程中保鲜技术的提升及销售市场的开拓。 1 实验 1.1 材料 主要材料:海捕鹰爪虾购于舟山市沈家门码头,系舟山海域的海捕虾。鹰爪虾从浙江省舟山市沈家门农贸市场采购,用碎冰保存新鲜的虾后立即运往实验室。选取头尾连接紧密、身体完整、大小均一的新鲜鹰爪虾,体长为(7±0.77)cm,每只质量为(5±0.68)g。 1.2 仪器 主要设备: HETTICH 420R 冷冻离心机,德国HETTICH 公司; UV-2100 紫外分光光度计,美国Thermo 公司; Waters 2695 高效液相色谱,沃特世科 技(上海)有限公司; Sunfire C18 柱, 美国 Waters公司; LHS-100CH 恒温培养箱,德国 BINDER 公司;Ultra-Turrax T-18 basic 均质机,德国 IKA公司;TMS-PRO质构仪,美国FTC 公司; PB-10pH计,散多利斯科学仪器有限公司。 1.3 样品的处理 将选取的虾用蒸馏水冲洗干净,随后用无菌纸吸去虾体表面的水分,先放在-30℃的冰箱预冷,再参照文献[11--12],采用冻结法,为了保证测量温度结果的可比性和一致性,将温度记录仪由鹰爪虾的尾部往头部方向探入,并将探头固定在虾的第1腹节处,然后放入-30℃的冰箱内,每隔1 min 读取温度并记录,连续记录60 min。当温度至至0℃以下并在一定的温度内小幅度波动时,将该温度视为鹰爪虾的冰点温度。测量鹰爪虾的冰点温度为-1℃,冰温区间为-1~0℃。鹰爪虾分别放在冰温和冷藏条件下,冰温组的虾样,每隔2d测定各项指标;冷藏组的虾样,每隔1d测定各项指标。 1.4 实验方法 1.4.1 pH的测定 pH值的测定参照 Arashisar3]的方法。将虾肉用组织捣碎机捣碎,称取2g虾肉于烧杯中,加入适量煮沸后冷却的中性蒸馏水,振摇后用均质机充分均质,静置30 min,然后用离心机(8000 r/min) 离心20 min,过滤,取滤液用 pH 计测定,重复3次实验。 1.4.2 新鲜度的测定 新鲜度(K值)的测定根据 Yokoyama 等114]的方法,并进行了修改。首先准确称取搅碎后的虾肉2g于50 mL 离心管中,加入体积分数为10%的高氯酸溶液5mL,充分均质后,以转速为 8000 r/min, 在4℃下离心10 min, 转移上层清液至另外的新管中。在沉淀部分里再加入体积分数为5%的高氯酸溶液5mL,重复提取2次并离心,合并上清液。用氢氧化钾溶液调整合并上清液的 pH 值至6.4,放入冷藏室(4℃)中静置30 min, 然后过滤,将滤液转移至50 mL容量瓶中,再用超纯水定容至50mL,用孔径0.22 um的无机滤膜过滤,进行液相色谱测定,整个过程在0~4℃下操作。 高效液相色谱(HPLC)的条件:色谱柱 SunfireC18, 250 mmx4.6 mm (i.d.), 流动相为 0.005 mol/L 磷酸氢二钾和 0.05 mol/L 磷酸二氢钾(体积比为1:1)混合液,将 pH 值调至6.4,液相流速为 0.8 mL/min,柱温为35℃,紫外检测波长为254 nm, 进样量为 10uL。根据标准品的保留时间定性,采用外标法进行定量。K值计算公式如下: 式中: bATP, bADP, bAMP, bIMP, bHxR, bHx分别表示三磷酸腺苷、二磷酸腺苷、腺苷酸、肌苷酸、次黄嘌呤核苷、次黄嘌呤的质量摩尔浓度(umol/g),湿基。 1.4.3 挥发性盐基氮的测定 按照 GB 5009. 228—2016的半微量定氮法测定挥发性盐基氮(TVB-N)值5],结果以 mg/kg 表示。 1.4.4 菌落总数的测定 参照 GB 4789. 2—2016中的倾注平板法进行菌落总数(TVC)[16]的测定。 1.4.5 质构的测定 将虾从冰箱中取出,放在漏网中流水解冻10 min, 除去不同的温度解冻带来的影响。根据张帅1的方法进行修改,对鹰爪虾在贮藏过程中质构的变化进行测定。采用TMS-PRO质构仪,取鹰爪虾靠近头部的第2腹节的肌肉进行压缩质地多面剖析(TPA),平行实验3次。 设定参数:探头为P/50球形不锈钢,直径为5 mm;测试速度为60 mm/s;压缩变形量为50%;触发力为 0.1N。设计程序按照图形计算弹性、咀嚼性、胶黏性和硬度等参数。 1.4.6 肌动球蛋白的提取 参考万建荣等1181的方法进行修改,取2g左右搅碎的虾肉,加入其4倍容量的冷却缓冲液 A(3.38mmol/L NaH2PO4, 15.5 mmol/L NazHPO4, pH7.5),充分搅拌洗涤后于 3000 r/min 下离心10 min,重复此操作7次。在洗净的虾肉中加入其3倍容量的缓冲液B(0.45 mmol/L KC1, 3.38 mmol/L KHPO4, 15.5mmol/L NazHPO4, pH7.5)经常搅拌提取 20 h。将提取液于8000 r/min 下离心15 min, 将上清液缓慢倒入盛有10倍体积冷却水的离心管中,调节 pH 值至6.5~6.6。在4℃下放置30 min, 于6000 r/min 下离心10 min, 收集沉淀,加入3 mol/L KCl溶液, 将KCl溶液浓度最终调节到0.6 mol/L,用0.6 mmol/L KCl(其中含有 20 mmol/L tris-Maleic,pH7.0),透析12h。肌动球蛋白质量浓度采用双缩脲法进行测定。 1.4.7 总巯基的测定 根据Zang FL等119]的方法进行修改,取1mL肌 动球蛋白,加加9mL稀释液(包括50mmol/L磷酸缓冲液, pH 7.0; 8 mol/L 尿素;10 mmol/L EDTA;0.6 mol/L KCl),稀释后充分混匀取 4mL,加入0.4 mL 质量分数为 0.1%的 DTNA, 40℃水浴反应25 min, 在412 nm 处测量吸光值。用等体积的稀释液取代样品,作空白对照。总巯基(SH)含量用公式计算: 式中:A为吸光度值; D为稀释倍数;C为肌动球蛋白含量(mg/g)。 1.4.8 钙激活三磷酸腺苷酶活性测定 参照赵巧灵等20]的方法测定钙激活三磷酸腺苷酶(Ca*-ATPase)活性。 1.5 数据处理 每次测定至少设置3次平行实验,采用 Origin软件作图及进行方差分析,测定结果以均值+标准差表示,以P<0.05为显著。 2 结果与分析 2.1 鹰爪虾鲜度指标的变化情况 2.1.1 pH的变化情况 如图 1a所示,随着贮藏时间的延长,鹰爪虾的pH值都整体呈上升趋势,由于微生物产生的代谢产物积累,改变了虾体组成结构,加速虾发生腐败,此过程中微生物的活动受到虾体 pH 环境的影响,微生物在碱性环境下生长繁殖速度下降,使得 pH 值缓慢上升211。冷藏条件下鹰爪虾在贮藏6d后, pH值从 7.76升高至8.74。在冰温贮藏条件下,鹰爪虾pH值的变化在贮藏12d后达到8.67, pH值变化幅度要小于冷藏中pH值的变化。在贮藏过程中pH值先显著上升后趋于平稳,这与吴习宇等221研究冰温气调贮藏生鲜鲢鱼片 pH 值的变化趋于一致。鹰爪虾在冰温条件下 pH的变化情况明显比冷藏条件下变化得更加缓慢,说明在冰温条件下鹰爪虾的品质比冷藏条件下好。 2.1.2 新鲜度的变化情况 新鲜度(K值)的判定是以核苷酸的分解产物作为指标[23]。鹰爪虾在贮藏过程中K 值的变化情况见图1b。鹰爪虾的初始K值为3%,随着贮藏时间的延长,K值呈现明显的上升趋势,且与对照组比较,各样品组在贮藏期间存在显著性差异(P<0.05)。一般将40%作为评价虾类货架期新鲜度的界限[24]。鹰爪虾在冷藏2d时,K值≤20%,处于一级鲜度;在冷藏4d时,20%40%,到达货架期终点。鹰爪虾在冰温贮藏4d时,K值≤20%,处于一级鲜度;在冰 温贮藏6d时,20%40%,到达货架期终点。鹰爪虾在冷藏条件下鲜度下降速度要远快于冰温贮藏,因此得出海捕虾在冰温条件下比冷藏条件下更易于贮藏。 结构的破坏程度,生成碱性物质,进而使得 TVB-N值降低。 2.1.4 菌落总数的变化情况 2.1.3 挥发性盐基氮的变化情况 挥发性盐基氮值和K 值都可以作为判断水产品腐败程度的鲜度指标。由图1c 可知,鹰爪虾的初始挥发性盐基氮值为 66 mg/kg。这与 Okpala 等125的研究结果一致。水产品卫生标准261规定 30 mg/kg 为TVB-N腐败临界值,在冷藏期间,鹰爪虾在第5天时 TVB-N值达到了 300 mg/kg 的可食用上限。在冰温贮藏条件下,在第12天时 TVB-N值超过了不可食用上限。从图1c中可以看出,在相同贮藏时间下,冰温条件下鹰爪虾的 TVB-N值显著低于冷藏组(P<0.05),说明冰温处理的海捕虾能更好地延长其货架期。周倩倩等127研究发现 TVB-N增长速度与温度的变化有关,低温能减轻水产品贮藏过程中蛋白质 一般来说,对虾细菌总数(CFU/g)≤10°时为一级鲜度,细菌总数(CFU/g)≤5x10时为二级鲜度,细菌总数达到10°时,通常虾已腐败不能食用,此时断定为货架期终点[281。如图 1d所示,鹰爪虾的初始菌落总数为3.51 1g CFU/g,经预冷后与新鲜虾相比较低,说明低温能抑制菌落的生长繁殖。冷藏贮藏时,鹰爪虾在第5天时 TVC 值超过了6 lg CFU/g,结合K 值和 TVB-N值的测定结果,认为鹰爪虾的货架期约为5 d。在冰温条件下,鹰爪虾在第10天时TVC 超过了6 1gCFU/g, 结合K值和TVB-N值的测定结果,认人在冰温条件下鹰爪虾货架期约为10d,贮藏期延长了约1倍。实验表明,冰温条件对细菌的生长繁殖起到了一定的抑制作用,减少了鹰爪虾细菌的存活量,有效延长了保鲜期。文中研究与边涛等1291的研究结果也相似,发现在-1~0℃冰温条件下鲜虾 注:不同字母(a-f)为同组之间不同贮藏时间的显著(P<0.05)差异性分析,A,B为不同组相同贮藏时间的显著(P<0.05)差异性分析 图1 冰温与冷藏期间鹰爪虾 pH值、K 值、TVB-N值和菌落总数的变化 Fig.1 Change in pH, K value, TVB-N value and TVC of white-hair rough shrimpduring ice-temperature and refrigerated storage 能有效地抑制细菌繁殖,延缓腐败变质,从而有效延长了货架期,比普通冷藏能延长4~5d. 2.2 鹰爪虾蛋白质指标的变化情况 2.2.1 质构的变化情况 鹰爪虾在贮藏期间质构变化情况见表1一2。虾肉质构参数与蛋白质有着密切关系,虾肉的主要成分是蛋白质,蛋白质的含量和质量会直接影响虾的口感和品质[30]。质构参数的改变可能是因为微生物大量繁殖,在利用部分蛋白质的同时,产生了外源性蛋白酶,其对肌肉蛋白进行水解311,也可能是因为虾体内自身含有的内源性蛋白酶在鹰爪虾死后对自身蛋白质进行降解32。从表2中得出冰温组贮藏12d后,硬度、弹性、胶黏性、咀嚼性分别下降了43.82%,39.66%,64.52%,74.46%,而冷藏组在贮藏6d后,硬度、弹性、胶黏性、咀嚼性分别下降了 40.79%,55.86%,66.00%,82.70%。发现随着贮藏时间的延长,虾肉质 构参数均显著降低(P<0.05),其中冷藏组比冰温组的降低更为显著(P<0.05),且胶黏性和咀嚼性变化最大。总体来看,不管是贮存时长还是质构参数的降低,冰温组都要优于冷藏组。表明质构参数的改变能较好地反应虾死后的变化,这与鲜度指标的测定结果一致。 2.2.2 肌动球蛋白的变化情况 肌动球蛋白质量分数的下降可能由于贮藏过程中虾类死后僵直,缺乏 ATP 的供给,使得肌动球蛋白不可逆地被分解,加之虾类肌肉蛋白质变性,使得肌动球蛋白等肌原纤维蛋白溶解性下降,从而使得肌动球蛋白的质量分数降低33]。鹰爪虾在冰温下肌动球蛋白含量的变化见图2a。在4℃贮藏条件下,虾肉中肌动球蛋白质(初值为68.47 mg/g)呈现明显的下降趋势,鹰爪虾在达到货架期终点时,即贮藏第5天时肌动球蛋白质的含量为 28.66 mg/g,所含肌动球蛋白含量的下降率为58.14%;在冰温条件下,鹰爪 表 1 鹰爪虾各质构参数在冷藏过程中的变化情况 Tab.1 Change in texture parameter of white-hair rough shrimp during refrigerated storage 时间/d 硬度/N 弹性/mm 胶黏性/N 咀嚼性/mJ 贮藏前 4.29±0.45° 1.79±0.25° 1.00±0.05 2.89±0.26° 1 3.75±0.11° 1.70±0.17° 0.91±0.07 2.23±0.48 2 3.07±0.28° 1.47±0.13° 0.84±0.04ab 1.95±0.04° 3 2.80±0.41° 1.28±0.13° 0.83±0.06ab 1.90±0.36° 4 2.77±0.12° 1.20±0.14° 0.54±0.01° 1.21±0.23° 5 2.70±0.21 0.98±0.21 0.36±0.02 0.58±0.40° 6 2.54±0.44de 0.79±0.27° 0.34±0.03° 0.50±0.21* 注:不同的字母(a—e)表示同一行中的显著(P<0.05)差异 表2鹰爪虾各质构参数在冰温过程中的变化情况 Tab.2 Change in texture parameter of white-hair rough shrimp during ice-temperature storage 时间/d 硬度/N 弹性/mm 胶黏性/N 咀嚼性/mJ 贮藏前 4.29±0.45° 1.79±0.25° 1.55±0.13° 2.78±0.13° 2 3.79±0.43b 1.54±0.16° 0.94±0.26° 1.44±0.41° 4 3.20±0.47° 1.35±0.28bc 0.90±0.28° 1.30±0.27 6 3.07±0.12° 1.30±0.12bc 0.89±0.56° 1.23±0.47° 8 2.76±0.25° 1.29±0.11° 0.89±0.24° 1.20±0.46° 10 2.51±0.52° 1.20±0.14° 0.73±0.32° 0.97±0.27° 12 2.41±0.88d 1.08±0.17° 0.55±0.15° 0.71±0.35° 注:不同的字母(a—f)表示同一行中的显著(P<0.05)差异 注:不同字母(a-f)为同组之间不同贮藏时间的显著(P<0.05)差异性分析, A, B为不同组相同贮藏时间的显著(P<0.05)差异性分析 图2 冰温与冷藏期间鹰爪虾肌动球蛋白、总巯基和Ca-ATPase 活性的变化 Fig.2 Change in active sulfhydryl content of myofibrillarprotein, sulfhydryl content and Ca -ATPase activity ofwhite-hair rough shrimp during ice-temperature andrefrigerated storage 虾的货架期为10d,在贮藏第10天时虾内所含肌动球蛋白的含量降至35.58 mg/g,冰温条件下鹰爪虾肌动球蛋白含量的下降幅度和速度更小。孙蕾蕾等1341研究发现,肌动球蛋白在贮藏过程中随着时间推移, 呈现下降的趋势,且前期下降趋势显著高于后期,这与文中的研究一致。 2.2.3 总基的变化情况 肌肉蛋白质中 SH 会影响 ATPase 活性,参与肌肉的收缩,同时 SH 与蛋白质变性和聚合有着密切关系,肌动球蛋白巯基的变化见图2b。结果发现,在4℃的贮藏过程中,当鹰爪虾到达货架期终点时,其内的巯基含量下降到 8.81 mol/g, 5d下降率达 23.92%。在冰温的贮藏过程中,当鹰爪虾到达货架期终点时,其内的巯基含量下降到 8.91 mol/g, 10 d下降率为23.06%。随着冷藏时间的延长,冰温组与冷藏组之间存在显著差异(P<0.05)。李学鹏等B35]研究3种温度贮藏中国对虾蛋白质变化中也发现在-2℃条件下,肌动球蛋白巯基含量降低最慢,使得肌动球蛋白的变性越慢。文中研究结果表明,整个贮藏期间鹰爪虾的巯基含量均在下降,且冰温条件下降速度要明显比冷藏条件下慢约1倍,与李学鹏等35)研究结果一致。 2.2.4 Ca*-ATPase 活性的变化情况 鹰爪虾在冰温下的 ATP酶活性变化情况见图2c。随着贮藏时间的延长,鹰爪虾在不同贮藏条件下的ATP 酶活性呈降低趋势,因为在冰温条件下 ATP 酶活性受到温度的制约,导致降低速度较冷藏条件下缓慢,而 ATP 酶活性下降可能是因为低温下肌球蛋白头部区域发生缓慢变性或者相互聚集1361,也可能是因为巯基氧化形成二硫键导致分子聚合在2种贮藏条件下鹰爪虾 Ca -ATPase 活性降低均比较显著(P<0.05),且在贮藏时间相同的情况下,2种贮藏条件之间差异性显著(P<0.05)。贮藏末期,2种贮藏条件下鹰爪虾 Ca -ATPase 活性分别降低到 0.031umol/(mg'min)和 0.038 umol/(mgmin)。说明冰温条件下能够大大延缓鹰爪虾体内 ATP 酶的失活,从而保持了其品质。金枝等381研究了预冷温度对冰温罗非鱼片品质的影响,表明冰温前不同温度预处理后再冰温贮藏,预处理组与对照组鱼片 Ca²-ATPase 酶活性均随着贮藏时间的推移呈下降趋势。 2.3 鹰爪虾鲜度及蛋白质变化的相关性分析 从表3—4可以看出,对鹰爪虾在冰温和冷藏条件下K值、菌落总数、TVB-N值、肌动球蛋白含量、总巯基含量、Ca-ATPase 活性之间的相关性分析发现,各项鲜度指标之间、相关蛋白质变化之间均表现出显著的正相关性,鲜度指标和蛋白质变化的指标之间也显示出显著的负相关性。研究说明,在对鹰爪虾鲜度的评判中发现,鲜度指标与蛋白质指标之间存在着密切的联系,鹰爪虾在贮藏过程中不但鲜度指标会有所变化,蛋白质组成和结构也会随之变化,蛋白质的变化情况在日后也可能作为虾类贮藏保鲜过程中用以判断虾新鲜度的指标。 表3 鹰爪虾在冷藏下鲜度指标和蛋白质变化的相关性分析 Tab.3 Correlation analysis of freshness index and protein change of white-hair rough shrimp in refrigerated storage 相关性 K值 TVB-N值 菌落总数TVC 肌动球蛋白含量 总巯基含量 Ca²+-ATPase 活性 K值 0.9972* 0.9814** -0.9483** -0.9464** -0.9391** TVB-N 0.9972* 0.9664** -0.9268* -0.9264** -0.9208** 菌落总数 0.9814* 0.9664** -0.9870** -0.9806** -0.9753** 肌动球蛋白含量 -0.9483* -0.9268** -0.9870** 0.9962** 0.9939** 巯基含量 -0.9464** -0.9264** -0.9806** 0.9962** — 0.9923* Ca+-ATPase -0.9391** -0.9208** -0.9753** 0.9939** 0.9923** 注:“**”表示极显著(P<0.01),“*”表示显著(P<0.05) 表4鹰爪虾在冰温下鲜度指标和蛋白变化的相关性分析 Tab.4 Correlation analysis of freshness index and protein change of white-hair rough shrimp in ice-temperature storage 相关性 K值 TVB-N值 菌落总数 肌动球蛋白含量 总巯基含量 Ca²+-ATPase 活性 K值 — 0.9953* 0.9926** -0.9581** -0.9616** -0.9660** TVB-N值 0.9953* 0.98749** -0.9477** -0.9582** -0.9588** 菌落总数 0.9926* 0.9875** 二 -0.9261** -0.9341* -0.9384** 肌动球蛋白含量 -0.9581* -0.9477* -0.9261** 0.9957** 0.9976** 巯基含量 -0.9616** -0.9586* -0.9341** 0.9957** — 0.9989** Ca-ATPase -0.9660** -0.9588** -0.9384** 0.9976** 0.9989** 注:“**”表示极显著(P<0.01),“*”表示显著(P<0.05) 4 结语 从实验数据来看,各项指标下所得出的鹰爪虾货架期趋于一致。根据鲜度指标与蛋白质相关指标得出,鹰爪虾在冷藏与冰温贮藏的货架期分别为5d和10d,延长了约1倍。实验表明,鲜虾理化特性的改变,说明冰温条件下不仅能降低鹰爪虾的 pH 值、挥发性盐基氮值、K值,还对细菌的生长繁殖起到了一定的抑制作用,减少了细菌的存活率,有效延长了保鲜期,且还能较好地延迟鹰爪虾虾体内总巯基含量的降低、延缓其蛋白质组成和结构的变化,从而保持海捕虾良好的贮藏品质。文中研究结果表明,鲜度指标和蛋白质指标的变化相关性较高,说明蛋白指标与鲜度指标之间存在着密切的联系,在以后的实验中值得作为判断水产品新鲜度的辅助依据。由此可见,冰温贮藏可有效提高海捕虾的捕捞后的贮藏品质,具有很广阔的应用前景。 ( 参考文献: ) ( 1] 张树德,宋 爱 勤. 鹰 爪虾及其渔业[J].生物学通报, 1992(11) : 12一 1 4. ZHANG Sh u -de, SONG Ai-qin. Tal o ns Shrimp and ItsF i shery[J]. Bulletin of Biology, 1992(1 1) : 1 2 1 4 . ) ( [21 陈飞东.虾保鲜冰制备工艺的研究及其应用[D].杭州: 浙 江 工商 大学,2007:2-4. CHEN Fe i -dong. Study on Pr e paration and Applicationof Fresh Ice for Prawn[ D ]. Hangzhou: Zhejiang G o ng-shang University, 2007:2- 4 . ) ( [3] 陈胜军,陶飞燕,潘创,等.虾产品低温贮藏保鲜技术研究进展[J].中国渔业质量与标准 , 2020,10(1): 68—75.CHEN S h eng-jun, T AO F e i-yan, P AN Chuang, et a lResearch Progress on Low T emperature S torage andPreservation T echnology o f S h r imp Products[J]. Fi-shery Q uality a nd Standard i n C h i na, 2 0 20,10(1):68 — 75. ) ( [41 潘卓,林洪.冰温保鲜和冷藏保鲜对生食大西洋鲑品质影响的比较研究[J].食品安全质量检测学报, 2019,10(8):2232—2239. PAN Zhuo, LIN H o ng. C o mparative Research o n theEffect of C o ntrolled F r eezing-point Storage P reserva-tion and Cold S torage P r eservation on t h e Q u ality ofRaw Salmo S a lar[J]. Journal of Food Safety and Qual- ity,2019, 10(8):2232—2239. ) ( 5] 洪惠,朱思潮,罗永康,等.鳙在冷藏和微冻贮 藏 下品质 变 化规律的研究[J] . 南方水 产 科学, 2011 , 7(6):7—12.HONG H u i, Z H U Si-chao, LU O Yong-kang, et al. Quality C h anges o f Bighead Carp (Aristichthys N obi-lis) during Chilled and P a rtial Fr eezing S t orage[J ] . ) ( South China Fisherie s Science,2011,7(6): 7—12. ) ( [6] 杨华,张建斌,吴晓,等.冰温贮藏对鲢 、 草、鲤鱼糜制品品质的影响[].食品科学,2016,37(12):273—278. YANG H u a, Z H ANG Jian-bin, WU Xiao, et al. Effectof I ce-temperature Storage on P roperties of SilverCarp, Grass Carp and Common Carp Su r imi[J]. F o od Science,2016,37(12):273—278. ) ( [71 朱丹实,王立娜,吴晓菲,等.冰温及冷藏对鲤鱼水分迁移及质构的影响[J].中国食品学报,2017,1(10): 152—158.ZHU D a n-shi, WANG Li- n a, WU Xiao-fei, et al. Ef - fects of the Ic e Storag e and Cold Storage on Migration of Moisture a nd T e xture Changes of Carp[J]. Journal of Chinese Institute of Food S cience a n d Te c hnology,2017, 1 (10):152一 1 58. ) ( [8] 周果,崔燕,杨文鸽,等.冰温贮藏对梭子蟹品质影响及其货架期模型的建立[].核农学报,2017, 31(4):719— 7 25.ZHOU Guo, CUI Yan, Y A NG Wen-ge, et al. Impact of Controlled F reezing-point S torage on t h e P o r tunusTrituberculatus Quality and M odel Construction of ItsShelf-life[J]. Journal of Nuclear Agricultural Sciences, 2017,31(4):719—725. ) ( [9] 谢丽丹,李蕾蕾,王素英,等.冰温贮藏中南美白对虾特定腐败菌的分离鉴定及其腐败能力分析[J]. 食 品工业 科 技,2016,37(5): 171一17 6 . XIE L i-dan, L I L ei-lei, WANG S u -ying,et a l . I s ola- tion, Identificatio n and Spoilage Ability Analysis onthe Particular Spoilag e Bacteria of Penaeus Vannameiin the Ice Temperature Storage[J]. Science and Tech-nology of Food Industry, 2016,37(5):171一176. ) ( [101 吕艳芳,蔡路昀,李颖畅,等.冰温下复合保鲜剂和焦亚硫酸钠对南美白对虾防黑变保鲜效果比较[J]. 中 国食 品学报,2017,17(7):129—136. LYU Y a n-fang, CA I Lu-yun, LI Ying-chang, et a l . TheC o mparison b etween C ompound Preservatives and So- dium M etabisulfite T reatment o n t h e A n ti-melanosis E f fect of Penaeus Vannamei under Ice-temperature[J]. Journal of Chinese I nstitute of Food Science a nd Technology, 2017 , 17(7) : 129—136. ) ( 1111 雷志方,谢晶.水产品冰温保鲜技术研究现状[]. 广东农业科学,2014,41(19):112一117. L E I Z hi-fang, XIE J i ng. Current S i tuation o f Con - trolled Freezing-point Technology o n A q u atic Prod-ucts[J]. Guangdong A g riculture S c ience, 2014, 41(19):112—117. ) ( 121 葛庆联,唐修 君 ,樊艳凤, 等 .冰温贮藏对冷鲜鸡品 质 的影响[J].中 国 家禽,2018,40(19):41一44. GE Qing-lian, TANG Xi u -jun, FAN Yan-feng, et al . Effects of I ce T emperature Storage o n Q u ality ofChilled C h icken[J]. China Poultry, 2018, 40(19) : 41一 44. ) ( [131 ARASHISAR S, HISAR O, KAYB M, e t a l . E f fect ofModified Atmosphere and Vacuum P ackaging on Mi- ) ( crobiological and Chemical Properties of Rainbow T rout(Oncorynchus M y kiss) Fill e ts[J]. Int e rnationalJournal of Food Microbiology, 2004, 9 7(2): 209—21 4 . ) ( [14] YOKOYAMA Y, SAKAGUCHI M, K A WAI F, et al.C h anges i n Concentration of ATP-relate d Compoundsin V arious Tissues of O y ster du r ing Ice St o rage[J]. Nippon S uisan Gakkaishi, 1992,58(11):2125—2136. ) ( 「151 GB 5009.228—2016,食品安全国家标准食品中挥发性盐基氮的测定[S]. GB 5 009.228一2016, N a tional S t andards f or F oodSafety Determination of V olatile Base N itrogen i nFoods[S1. ) ( [16] ] GB 4789.22016,食品安全国家标准食品微生物学检验菌落总数测定[S]. GB 4789.2—2016, Na t ional Standard for Food Safety Determination o f Total Number of Bacterial Colonies in Food M icrobiology Test[S]. ) ( 1171 张帅.凡纳对虾4℃冷藏条件下新鲜度表征蛋白的研究[D].杭州:浙江工商 大 学,2013:15. ZHANG Shuai. St u dies on Indicator of Fr e shness fo r Pacific White S hrimp (Litopenaeus V a nnamei) Co n tri-bute to Postmortem Changes Stored under VacuumPacking at 4℃[D]. H angzhou: Z hejiang Gongshang University, 2013: 15 . ) ( 1181 万建荣,洪玉菁,奚印慈,等.水产食品化学分析手册[M] . 上海:上海科学技术出版社, 1993: 1 45- 147.WAN Jian-rong, HONG Yu - jing, XI Yi n -ci, et a l .Handbook of Chemical Analysis of Aquatic Food [M].Shanghai: Shanghai Science and Technology P r ess,1993:145—147. ) ( 1191 ZHANG F L,YONG-Le LIU,JIANYU, e t al. Opti-mization of Conditions f or Extracting Muscle P roteinfrom G rass C a r p using Response S u rface Methodolo- gy]. Advanced Materials R esearch, 2 014, 1004: 837—840. ) ( [201 赵巧灵.金枪鱼在冷藏过程中鲜度变化及差异蛋白质组学研究[D].杭州:浙江工商大学,20 1 5: 77. ZHAO Qi a o-ling. Freshness V a riation and D i f ferentialProteome Analysis of TUNA ( Thunnus O b esus)duringRefrigerated Storage[D]. Hangzhou: Zhejiang G o ng- shang U niversity, 2015: 77. ) ( [211 SUNDARARAJAN S, PRUDENTE A,BANKSTON JD, et al. Evaluation of Green Tea Extract as a GlazingMaterial f or Shrimp F rozen by C r yogenic Fre e zing[J].Journal of Food Science, 2011,76(7) : 511—518. ) ( 1221 吴习宇,赵国华,李建光,等.冰温气调贮藏生鲜鲢鱼片的保鲜效果[J].包装工程,2014,35(13): 24—30. WU X i -yu, ZHAO Guo-hua, LI J ia n -guang, et al. Ef- fect of C o ntrolled Freezing-point Storage Combined with Modified A tmosphere Packaging on Fr e sh-keep-ing o f S ilver C a r p Fil l ets. Packaging E n g i neering, 2014, 3 5(13): 24—30. ) ( [231 SAITO T, ARAR K,MATUYOSHI M . A New Method ) ( for Estimating t he F reshness of Fish [J ] . B ull J ap S oc Sci Fish , 1959, 24(9):749—750. ) ( [241 励建荣,李婷婷,李学鹏 . 水产品鲜度品质评价方法研究进展[J].北京工商大学学报(自然科学版),2010, 28(6) : 1-8. LI J ian-rong, LI Ting-ting, L I Xue-peng. A dvances i n Methods for E valuating Freshness of Aquatic P rod- ucts[J]. Journal of Beijing Technology and B u sinessUniversity(Nature Science), 2010, 28(6): 1-8. ) ( 251 OKPALA C O R , CHOO W S, et al. Qu a lity and Shelf Life Assessment of Pacific White Shrimp(Litopenaeus vannamei)Freshly H arvested and S tored o n I c e[J]. LWT-food S cience and Technology, 2014, S 55(1 ) : 110—116. ) ( 1261 周倩倩,谢晶.不同温度贮藏过程中海鲈鱼品质变化和货架期预测模型的建立[J].上海海洋大学学报, 2020,29(3):457—466. ZHOU Qian-qian, X I E Jing. Changes of Quality Cha- racteristics and Establishment of Shelf-life M odel f r om Sea B ass during S t orage at D i fferent T e mperatures[J]. Journal of S hanghai O cean Un i versity, 2020, 29(3): 457—466. ) ( [271 GB 10136—20 1 5,食品安全国家标准 i 动物性水产 制品[S]. GB 1013 6 —2015, National F o od Safety S t andard f o rAnimal Aquatic Product[S]. ) ( [281 SHENGMIN LU. Effects of Bactericides and ModifiedAtmosphere Packing on S h elf-life of Chinese Shrimp(Fenneropenaeus Chinensis)[J]. LWT-Fo o d Sci T e c h- nol,2009,42(1):286—291. ) ( 1291 边涛,赵艳,张虹,等.凡纳滨对虾在不同冷藏条件下的品质变化研究[J].水产 科 学,2009,28(9): 493—497.BIAN T ao, ZHAO Yan, ZHANG Hong, et al. Changesin Quality of White Leg Shrimp Litopenaeus VannameiStored u nder Different Cooling Con d itions[J]. F i she-ries Science, 2009, 28(9):493—497. ) ( [301 戚勃,杨贤庆,李来好,等.琼胶寡糖对冻虾仁 和 罗非鱼片品质的影响[J].南方水产科学,2012, 8(6):73—79. QI Bo, YANG Xian-qing, LI L a i-hao, et a l. Effect ofAgar-oligosaccharide o n Quality of Frozen Shrimp andTilapia Fillets[J]. South China F isheries Science,2012, 8(6): 73 —7 9. ) ( [31] 王 凤玉,曹荣,赵玲, 等 .秋刀鱼-20℃ 、 -30℃和 - 5 0 ℃冻藏过程中品质变化[].食品研究与 开 发, 2015,36(21):7—11. WANG Feng-yu, CAO Rong,ZH A O Ling, et al. Effect ) ( of T emperature on the Q uality o f Cololabis S aira d ur-ing -20 ℃, - 30℃ an d -5 0 ℃ Frozen Sto r age[J].Food Research and Development, 2015,36(21):7一11. ) ( [321 林婉玲,杨贤庆,王锦旭,等.浸渍冻结对凡纳滨对虾冻藏过程中肌肉组织的影响[J].现代食品科技, 2015,31(6):183—189. LIN W an-ling, Y ANG Xi a n-qing, WANG Jin-xu, et al.Effect of Immersion Chilling and Freezing on M uscle Structure of Litopenaeus Vannamei during Frozen Sto- rage[J]. Modern Food Science and T e chnology, 2 0 15, 31(6):183—189. ) ( [331] c OWUSU-ANSAH YJ, HULTIN H O. Di f fe r ential In - solubilizatio n o f Red Hake M uscle P roteins d uringFrozen Storage[J] . Journa l of Food Scionce, 1992, 57(2):265—266. ) ( [341 孙蕾蕾,黄卉,李来好,等.冰藏罗非鱼片能量代谢酶与品质的相关性分析[J].食品工业科技,2015. 36(11): 70-73. SUN L e i-lei, H UANG Hui , LI Lai - hao, et a l. Correla-tion Analysis of Enzymes Associated with Energy Me-tabolism a nd Q u ality o f Ti l apia Fillets d u ring IcedStorage[J]. Science and Technology of F o od Industry, 2015, 3 6(11): 70—73. ) [351 李学鹏,陈杨,王金厢,等.中国对虾冷藏过程中肌 ( 肉组织结构与蛋白质生化性质的变化[J] . 中国食品 学 报,2014,14(5): 72一7 9 . LI Xue-peng, CHEN Y a ng, W A NG Jin-xiang, et al.Changes in M uscle Structure and Biochemical C harac-teristic s o f Muscle Protein s i n Chinese Shrimp (FenneropenaeusChinensis ) dduring Refrigerated S to-rage[J]. Journal of Chinese I nstitute of Food S cienceand T echnology, 2014,14(5): 7 2—79 . ) ( [361 JIANG S T, HWANG D C , C H E N C S. E ff e ct of Sto-rage Temperature o n the F ormation of Disulfides andDenaturation of Milkfish Actomyosin(Chanos C ha- nos)[ J] . Journal of Food Scionce, 1998, 53(5): 1 333一 1335. ) ( [371 XIONG G Q, C H ENG W, YE L X, e t al. Eff e cts ofKonjac G lucomannan on Ph y sicochemical Pr o pertiesof Myofibrillar Protein and Surimi G els f rom G r assC a rp ( Ctenopharyngodon Id e lla)[J]. Food C h e m istry. 2009, 116(2):413—418. ) ( [38] 金枝,关志强,李敏.预冷温度对冰温罗非 鱼 片品质 的影响[J]. 食 品与机械,2019,35(9):135一140. JIN Zhi. GUA N 2 Zhi-qi a ng,LI M in. E E f fect t of Pre-cooling Conditions on F r esh-keeping to Ice-temperature Tilapia Fillets[J]. Food and Machinery, 2019,35(9):135—140. ) 数据 摘要:目的为了研究冰温贮藏对鹰爪虾的保鲜效果及品质的变化情况,以期为海捕虾的贮藏保鲜提供理论参考依据。检测样品:鹰爪虾检测设备:质构仪检测方法:以鹰爪虾为研究对象,对预冷后在冰温和冷藏条件下贮藏后其pH值、新鲜度(K值)、挥发性盐基氮(TVB-N)值、菌落总数(TVC)、质构及蛋白质特性变化(如巯基含量、肌动球蛋白含量和钙激活三磷酸腺苷(Ca2+-ATPase)酶活性)等情况进行分析。对于冰温组的虾样,每间隔2 d测定其各项指标;对于冷藏组的虾样,每隔1d测定其各项指标。实验结果:与冷藏组相比较发现,鹰爪虾在冰温贮藏过程中能够延缓pH值、TVB-N值、K值升高,抑制微生物的生长、TVC值的升高,延缓肌动球蛋白含量、巯基含量的降低,抑制Ca2+-ATPase酶的失活,能有效地延长鹰爪虾的贮藏货架期。结论鹰爪虾在冷藏和冰温贮藏下的货架期分别为5 d和10 d,货架期延长了约5 d,因此冰温贮藏更易于海捕虾的贮藏。
关闭
1/9
2/9
北京盈盛恒泰科技有限责任公司为您提供《鹰爪虾中质构检测方案(质构分析仪)》,该方案主要用于水产品中营养成分检测,参考标准《暂无》,《鹰爪虾中质构检测方案(质构分析仪)》用到的仪器有FTC-质构仪TMS-PRO、PILOT-物性分析仪质构仪。
我要纠错
