2021年5月第42卷第9期食品研究与开发基础研究31— DOI:10.12161/j.issn.1005-6521.2021.09.005 不同部位牦牛肉品质比较分析 徐焕',郝力壮*,刘书杰',牛建章,张晓卫',多吉欧珠 (1.青海大学,青海省高原放牧家畜动物营养与饲料科学重点实验室,省部共建三江源生态与高原农牧业国家重点实验室,青海高原牦牛研究中心,畜牧兽医科学院,青海西宁810016;2.西藏自治区日喀则市亚东县农牧综合服务中务,西藏日喀857600) 摘 要:以18头舍饲育肥牦牛的背阔肌、臂三头肌、腰大肌、背最长肌、臀股二头肌、半腱肌6个部位的肌肉为研究对象,分别对其常规营养成分、矿物质元素及食用品质进行分析,研究牦牛不同肌肉部位的营养品质和食用品质之间的差异。研究结果表明:常规营养成分中,各部位除蛋白不存在显著性差异外(P>0.05),其它指标均存在差异显著(P<0.05),其中背阔肌的脂肪含量显著高于其其部位(P<0.05);从矿物质元素来看,背阔肌的Ca、Na含量较其它部位高,半腱肌的K、Mg含量较高,臂三头肌的微量元素含量较丰富;从肉的食用品质上来看,腰大肌及背最长肌嫩度较好,臀股二头肌和背最长肌的持水力较其它部位强。结果表明,不同部位的肌肉在营养品质和食用品质方面均存在很大差异,综合看来,背最长肌的肉质较好,其次为臀股二头肌,为今后肉块分割增值技术及等级评价体系的建立提供依据。 关键词:牦牛肉;不同部位;营养成分;矿物质;食用品质 Comparison Analysis of Yak Meat Quality in Different Parts of Muscles XU Huan, HAO Li-zhuang, LIU Shu-jie, NIU Jian-zhang, ZHANG Xiao-wei, Duo Ji Ou Zhu² (1. Qinghai University, Key Laboratory of Plateau Grazing Animal Nutrition and Feed Science of QinghaiProvince, State Key Laboratory of Plateau Ecology and Agriculture, Qinghai Plateau Yak Research Center,Academy of Science and Veterinary Medicine, Xining 810016, Qinghai, China; 2. Tibet Autonomous RegionPrefecture, Agriculture and Animal Husbandry Comprehensive Service Center of Yadong County, Xigaze 857600, Tibet, China Abstract: Taking the muscles of six parts of latissimus dorsi, triceps brachii, psoas major, longissimus dorsi,biceps gluteus femoris and semitendinosus of 18 fattening yaks as the research objects, the routine nutritionalcomponents, mineral elements and eating quality of the muscles in different parts of yaks were analyzed, andthe differences between different quality of the muscles were studied. The results showed that there was nosignificant difference in protein (P>0.05), while the other indexes were significant difference, the fat contentof latissimus dorsi was significantly higher than that of other partsS(P<0.05) .From the perspective of mineralelements, the Ca and Na content of latissimus dorsi was higher than that of other parts, the K and Mg content ofsemitendinosus was higher, while the microelement of triceps brachii was higher. In terms of meat eatingquality, the tenderness of psoas major and longissimus dorsi was better, and the water holding capacity ofbiceps gluteus femoris and longissimus dorsi was stronger than that of other parts. The results showed that therewere great differences in the nutritional quality, processing and eating quality of different parts of muscles. Andthe quality of the longissimus dorsi was better, followed by the biceps gluteus femoris, which provided the basisfor the future value-added technology of meat segmentation and the establishment of grading evaluation system. ( 基金项目 : 国家重点研发计划(2016 YFD050 0 5 04);国家自然科学基金项目 (3 1660 6 7 3);国家重点基础研究发展计划(9 73 前期项目) ) ( ( 2012CB7 2 2906 ) ) ( 作者简介:徐焕(1 9 95一 ) ,女(汉),在读硕士,研究方向: 反 刍动物营养 与 生产。 ) Key words: yak meat; different parts of muscles; nutritional components; mineral elements; eating quality 引文格式: 徐焕,郝力壮,刘书杰,等.不同部位牦牛肉品质比较分析[J].食品研究与开发,2021,42(9):31-36. XU Huan, HAO Lizhuang, LIU Shujie,et al. Comparison Analysis of Yak Meat Quality in Different Parts of Muscles[J]. FoodResearch and Development,2021,42(9):31-36. 牦牛主要生活在青藏高原及其毗邻地区,经过长期驯化成为一种耐低温、抗低氧且放牧性能较好的集肉、乳、役用为一体的牛种。牦牛肉作为一种有机天然的绿色食品,在市场上受到越来越多人的喜爱。由于传统放牧饲养模式低效,且随着社会经济的发展,人们生活水平的提高,人们对健康、优质牛肉的追求越来越高,因而对牦牛进行育肥已成为一种必要的趋势图。影响牛肉品质的因素有很多,其中营养成分是一个很大的影响因素。为了满足市场,改善牦牛的生长环境,加快出栏,牦牛的饲养模式从传统的放牧养殖向舍饲育肥养殖过渡15-6。目前国内的研究者对黄牛等其它肉牛的肉品质及放牧牦牛的肉品质进行了广泛的研究,而对于育肥牦牛不同部位肌肉品质差异的详细研究尚未见报道。程婷婷等对新疆褐牛肩肉、辣椒条等10个不同分割部位肉块的营养成分、肉色、pH值等肉品质进行了比较研究,结果显示,不同部位分割肉块间的蛋白质、脂脂、水分、蒸煮损失、剪切力、pH值和肉色均存在差异。李升升等"研究放牧条件下牦牛的里脊、辣椒条、前腱、眼肉等17个部位肉色、蒸煮损失、加压失水率、剪切力等肉品质的差异,结果表明不同牦牛部位肉的肉品质指标均存在显著性差异(P<0.05)。要通过育肥牦牛分割增值技术,实现差异化市场营销,建立牦牛肉等级评价体系的前提是必须了解不同部位牦牛肉肉质特征。本文主要对育肥的牦牛不同部位牦牛肉品质进行详细研究,旨在探索育肥牦牛的肉品质,为不同部位肉块的加工和品质改进提供依据,为建立牦牛肉等级评价体系提供数据支撑。 1材料与方法 1.1 材料与试剂 实验动物的饲养管理:选取3.5岁体况相近、健康发育的大通通牛(去势公牛)60头,于大通县丰聚养殖场进行为期5个月的舍饲育肥,从3.5岁左右开始在大通丰聚种牛养殖专业合作社牦牛育肥场集中饲养。日粮配方参照《牦牛营养研究论文集》和《肉牛饲养标 冰箱(BC/BD-629HL): Haier 公司;电子天平(ME104E):梅特勒-托利多仪器有限公司;凯氏定氮仪(Kjeltec 2100):瑞士FOSS公司;电感耦合等离子发射光谱仪(4100 MP-AES):安捷伦科技有限公司;便携式pH 测定仪(HI 99163N):意大利HANNA;色差计准》日增增600配制u809:00闸喂blishirfWSCuS:上海仪物理光学仪器有限公司,食品物 次,,自由采食全混合日粮(total mixed ration,TMR),TMR 混合日粮粗料和精料比例为3:7,粗料组成及占比:小麦秸杆(9.9%)、玉米青贮(20.1%);精料组成及占比:玉米(35%)、大豆(10.5%)、菜籽饼(7%)、燕麦(7%)、麦麸(7%)、预混料(3.5%)。自由饮水。共饲喂5个月(2018-11-10~2019-04-10),试验结束后称重并屠宰。TMR日粮营养成分含量见表1。 表1 TMR日粮营养成分含量 Table11Dietary nutrient content of TMR 营养成分 含量 营养成分 含量 干物质 79.77% 中性洗涤纤维 36.05% 有机物质 73.88% Ca 1.87% 灰分 6.39% P 0.44% 粗蛋白 15.95% 总能 16.41 MJ/kg 粗脂肪 2.83% 代谢能 9.67 MJ/kg 酸性洗涤纤维 12.15% 肉样采集:在青海省大通县丰聚养殖场选取舍饲育肥后体况相近、健康发育的4岁左右的公牦牛18头,平均体重为(164.58±3.11) kg,于青海裕泰畜产品有限公司进行屠宰,宰后采取牦牛体背阔肌、臂三头肌、腰大肌、背最长肌、臀股二头肌、半腱肌各约1kg,简单去除表面脂肪、结缔组织、污血等杂物,使用真空包装袋进行包装,置于冷藏箱(0℃~4℃)内带回实验室,在0℃~4℃的温度下排酸5d,样品放置于-18℃的冰箱中保存备用。 常量元素校准混标、多元素校准标准样品:安捷伦科技有限公司;盐酸、硫酸、硼酸、氧化镁、硫酸、硫酸钾、无水乙醚等(均为分析纯):国药集团化学试剂有限公司。 1.2 仪器与设备 性分析仪(质构仪)(FTC-TMS-PRO):北京盈盛恒泰有限公司;组织捣碎机(LB20ES):美国 Waring 公司;电热炉(DK-98-ID:天津市泰斯特仪器有限公司;烘箱(BPG-9056A):上海一恒科学仪器有限公司;数显恒温水浴锅(HH-6):国华电器有限公司;超纯水系统(IQ-7000:法国MERCK公司。 1.3 方法 1.3.1 常规营养成分测定 水分、灰分、脂肪、蛋白质分别按照 GB 5009.3—2016《食品安全国家标准食品中水分的测定》、GB5009.4一2016《食品安全国家标准食品中灰分的测定》、GB5009.6—2016《食品安全国家标准食品中脂肪的测定》、GB5009.5—2016《食品安全国家标准食品中蛋白质的测定》进行测定。 1.3.2 矿物质元素的测定 不同部位肉块中矿物质含量按照 GB 5009.268一2016《食品安全国家标准食品中多元素的测定》进行测定。 1.3.3 pH 值测定 分别在宰后45 min 及宰后24h用便携式 pH测定仪测定不同部位肌肉的pH 值;每个部位测定3次,取平均值。 1.3.4 肉色的测定 沿垂直于肌纤维方向切取肉样的新鲜切面,在空气中氧合30 min 后,用校正过的 WSC-S 色差计测定切面的色度值L*、a"和b,取3次测定的平均值。 1.3.5 剪切力 用 1.27 cm 的圆形取样器沿与肌纤维平行的方向钻取肉样,孔样长度不少于2.5 cm,选择燕尾型探头,用 TMS-PRO 食品物性分析仪测定每个肉样的剪切力值(N),每个样品重复测定3次,取平均值。 1.3.6 大理石花纹评分 将牛肉样品在室内自然光下进行大理石花纹评价,大理石纹标准图谱见表2,对照5分制美式大理石纹图谱进行感官目测评分,每个样品评分两次取平均值。 表2大理石纹标准 Table 2Standard of marbled grain 评分 评价标准 1分 无大理石花纹 2分 大理石花纹不明显 3分 有大理石花纹,但不突出 4分 大理石花纹较明显 5分 肌间脂肪适当,大理石花纹明显 注:两极间允许评0.5分。 1.3.7 蒸煮损失 修整去除肉块表面的脂肪和结缔组织,称量记为G,80℃恒温水浴加热。用数显温度计记录加热过程中肉块的中心温度,当中心温度达到75℃时,取出流水冷却至室温(18℃左右),再次称量记为G,通过蒸煮损失计算公式进行计算。 式中:G为蒸煮前样品质量,g;Gz为蒸煮后羊品质量,go 1.3.8 加压失水率 采用加压滤纸法,用取样器截取面积5cm²,厚1cm的肉样,称重记为G,将肉样置于2层医用纱布之间,上下各垫18层滤纸,置于食品物性分析仪上,选择5cm圆形探头,使其匀速加压至35kg,保持5 min,撤除压力后立即称重记为Ga, 每个处理重复测定3次,通过加压损失计算公式进行计算。 式中:Gs为加压前样品质量, g; Ga 为加压后样品质量,g。 1.4 数据处理及分析 试验数据采用 Excel 2016 进行数据整理,用 SPSS19.0统计分析软件对数据进行单因素方差分析,采用最小显著性差异法及 Duncan 法进行多重比较 (N=18),结果均以平均值标准差表示。 2结果与分析 2.1 不同部位牦牛肉常规营养成分结果分析 肉的常规营养成分主要包括水水、脂肪、蛋白质、灰分等,对肉的营养及食用价值有决定性作用。水分含量与肉的加工品质及储藏有重要的影响;灰分在肉中的含量虽然较少,但却反映了肉中矿物质的沉积情况;蛋白质和脂肪的含量影响着肉的营养价值,此外,脂肪含量与肉的风味也密切相关。牦牛肉具有蛋白质高、脂肪低,且氨基酸、脂肪酸含量丰富且比例适宜的特性,满足当今人们对健康食品的要求吗。牦牛不同部位肌肉常规营养成分的结果见表3。 由表3可知,6个不同肌肉部位的水分含量均在72%~75%,背阔肌的水分含量为 72.96%,显著低于其它5个部位(P<0.05);6个部位的灰分含量均在1.0%左右;背阔肌的脂肪含量显著高于其他5个部位(P<0.05),其次分别是腰大肌和背最长肌,脂肪含量最低的为臀股二头肌,仅为1.25%。此外,6个部位的蛋白质含量 表3不同部位肌肉常规营养成分 Table 3 Conventional nutrients in different parts % 肌肉部位 水分 干物质 灰分 脂肪 蛋白质 背阔肌 72.96±0.78 27.04±0.78° 1.12±0.05 3.54±0.61" 20.86±0.58 臂三头肌 73.47±0.43* 26.53±0.43 1.14±0.03" 1.85±0.37 20.77±0.36 腰大肌 73.63±0.66 26.37±0.66 1.07±0.03 2.89±0.47 20.67±0.55 背最长肌 73.15±0.72 26.85±0.72 1.08±0.03 2.14±0.68 22.14±0.54" 臀股二头肌 74.27±0.70" 25.73±0.70 1.12±0.03 1.25±0.33 21.27±0.49" 半腱肌 74.13±0.71" 25.87±0.71 1.08±0.05 1.70±0.40 21.59±0.50" 2.2不同部位牦牛肉矿物质元素含量结果分析 矿物质是指一些无机盐类和元素,根据人体的需要量主要分为常量元素和微量元素两大类。许多矿物质元素对肉质有着重要的影响。比如,铁和铜对肉质的影响主要在两个过程:铁铜组成的酶的抗氧化过程和铁铜催化脂肪氧化过程叫;钙是肌肉收缩和肌原纤维降解酶系的激活剂,对肉的嫩度影响较大。研究表明,钙在宰后牦牛肉的成熟过程中具有重要的作用,且用氯化钙对牛肉进行处理,能够显著改善牛肉的嫩度115-16。镁作为重要的辅酶,参与多种代谢反应。能够通过抑制屠宰前应激所导致的糖原分解反应来改善肉质,且镁含量高低可对肌肉的pH 值产生影响。锌对肉品质产生的作用相对较弱,但作为动物生命活动所必需的元素,锌能够增强人体免疫疫、预防疾病。 本文测定牦牛不同肌肉部位中的常量元素(Ca、K、Mg、Na) 和微量元素(Fe、Cu、Zn、Mn),结果见表4、表5. 表4不同部位肌肉常量元素含量 Table 4 Contents of constant elements in different parts 肌肉部位 Ca K Mg Na 背阔肌 7.64±0.81"2255.17±16.5633.54±4.4791.64±8.36" 臂三头肌 6.77±1.13=232.08±6.92"35.87±2.8280.49±6.39 腰大肌 6.30±1.16286.45±14.76°32.02±3.8375.68±8.68 背最长肌 6.83±0.68296.97±18.16°36.13±3.0773.37±8.89 臀股二头肌 5.35±0.80 308.68±18.8438.18±2.54" 64.51±5.90" 半腱肌 5.41±0.88325.07±13.91"37.72±2.73 77.13±6.07 注:同列肩标不同小写字母表示差异显著(P<0.05)。 由表4、表5可知,就常量元素而言,背阔肌的Ca、Na元素含量较为丰富,显著高于腰大肌、臀股二头肌和半腱肌 (P<0.05);半腱肌的K、Mg元素含量较丰富,其中,K含量显著高于其于5个部位(P<0.05),高达325.07 mg/100g, 臂三头肌为6个部位中K含量最低的部位,为232.08 mg/100 g, 显著低于另5个部位 表5不同部位肌肉微量元素含量 Table 5 Contents of trace elements in different parts 肌肉部位 Zn Fe Cu Mn 背阔肌 3.38±0.40" 2.89±0.31 0.15±0.03 0.06±0.03 臂三头肌 4.68±0.34 3.70±0.52 0.18±0.03" 0.03±0.02 腰大肌 3.10±0.38 3.50±0.38" 0.11±0.05 0.05±0.02° 背最长肌 4.52±0.52" 3.34±0.69 0.12±0.03 0.05±0.02" 臀股二头肌 3.59±0.46 3.47±0.64" 0.09±0.02 0.05±0.02" 半腱肌 3.92±0.48 3.04±0.50 0.04±0.02" 0.04±0.02° 注:同列肩标不同小写字母表示差异显著(P<0.05)。 高,其中Zn、Fe、Cu 含量为6个部位中最高,分别为4.68、3.70、0.18 mg/100 g,腰大肌的Zn 含量最低,背刮肌的 Fe 含量最低,而半腱肌的Cu 含量显著低于其他部位(P<0.05);此外,6个部位的Mn 含量不存在显著性差异(P>0.05)。 2.3不同部位牦牛肉食用品质结果分析 肉的食用、加工品质相互渗透。其中,Bouton 等118和 Purchas 等的研究先后发现肉的最终 pH 值和肉的持水力和嫩度联系紧密。目前,许多国家建立起来的牛肉等级评价体系均是以肉的食用品质为基础120-22)且国内外已有不少研究是关于其它肉牛品种不同部位食用品质的。Anderson 等123发现臀中肌与背最长肌的感官生化特性相似,肉质相对接近,且在宰后24h后,半膜肌的 pH 值显著低于背最长肌 (P<0.05); Hunt等通过消费者评价,也得出了臀中肌与背最长肌肉质相似的结论。 育肥牦牛不同部位肌肉的食用品质如表6所示。 由表6可知,宰后 45 min,腰大肌和半腱肌的pH值显著低于其它4个部位 (P<0.05),宰后24h的pH值中,背阔肌、臂三头肌、腰大肌显著高于另3个部位(P<0.05)。肉色指标的L、a*、b值分别代表了肉的亮度值、红度值和黄度值。试验结果表明:半腱肌的L*值与臂三头肌、腰大肌和臀股二头肌间存在显著性差异 表6不同部位肌肉食用品质的比较 Table 6 Comparison of food quality in different parts 肌肉部位 pHsm pH24. L a b 剪切力/N 大理石花纹评分 蒸煮损失/% 加压失水率/% 背阔肌 6.78±0.17 5.52±0.07 30.30±2.58 14.61±1.83° 15.16±2.2152.57±3.53° 1.94±0.43* 30.24±1.55° 34.58±2.14" 臂三头肌 6.84±0.22" 5.55±0.15" 26.97±3.01 11.42±2.00 14.52±1.9252.41±5.44 1.86±0.28 34.55±2.00 33.48±1.62 腰大肌 6.41±0.18 5.51±0.09" 27.79±2.87 11.04±1.59 13.68±1.7131.27±5.55° 3.42±0.24 33.09±2.20 33.12±1.75 背最长肌 6.85+0.16" 5.43+0.10 30.81±1.64 11.92+2.24 14.90±1.34 25.59±3.92 3.93±0.38 25.42±1.77° 27.82±2.44 臀股二头肌 6.78±0.15" 5.39±0.08 28.12±3.86° 10.26±2.03 11.40±2.072 44.78±4.46 3.06±0.38 26.88±2.12 26.23±2.46 半腱肌 6.63±0.15 5.37±0.04 32.64±3.40 13.21±1.58 15.15±2.992 43.77±2.71 2.14±0.45 32.00±2.36 34.22±2.11" 显著低于其其部位(P<0.05)。大理石花纹评分主要针对的是肉的肌内脂肪,育肥牦牛不同部位的剪切力值表明,大理石花纹评分与剪切力密切相关,其中,大理石花纹评分越高,剪切力值越低,也就表明肉的嫩度越好。背阔肌和臂三头肌的剪切力显著高于其它部位(P<0.05),而背最长肌的剪切力最低,低至25.59N。蒸煮损失和加压失水率主要突出的是肉的持水力,试验结果表明,背最长肌和臀股二头肌的蒸煮损失率和加压失水率显著低于其于部位(P<0.05),表明这两个部位的持水力良好。 3 结论 通过对舍饲育肥牦牛背阔肌、臂三头肌、腰大肌、背最长肌、臀股二头肌、半腱肌6个部位的营养指标和理化指标的研究,结果显示,不同部位牦牛肉之间除蛋白质含量、Mn元素含量以外,其它指标均存在显著性差异(P<0.05)。腰大肌和背最长肌的嫩度较好,臀股二头肌和半腱肌的嫩度其次,背最长肌和臀股二头肌的持水力最好。结果表明,部位是影响牦牛肉品质的重要因素,臀股二头肌和背最长肌具有相似的肉品质特性,可在今后的生产加工中提高其食用和经济价值。 ( 参考文献: ) ( [ 1 ] 姬秋梅.中国牦牛品种资源的研究进展[J].自然资源学报,20 01 ( 6 ): 564 -57 0. J I Qiume i. A d v a n ce s i n r e s ear c h o f y ak r e sour ce s in Ch i n a [ J ]. J o u r- nal of N at ur a l Re so u r ce s.2 0 0 1 ( 6 ): 564 -570 . ) ( [2] J UA R EZ M, L O PE Z CAMP O S O , PRIE T O N, et a l . Car c ass charac - te r is ti cs a n d me at qual it y o f B i son, b u f f al o, and y a k[ M] //M o re th a n b e e f, p or k a n d c h i ck e n -th e p r o duct i o n , p r oce s si n g, a n d q u al it ytraits o f oth er s ource s o f me at f o r h uma n d ie t . Cha m: Sp r in ge r Inte r - na t iona l Publ ish ing , 2 0 19: 9 5- 11 7. ) ( [ 3] N M UCHENJE V , D Z AM A K, C H I MONYO M, e t a l . S o m e bi o -ch e m i cal as p e c ts p e r t ain i ng t o be e f e atin g qu a l ity a nd con su m er ) (C) 199/lts reciwHa adcdhemie 3009.11:2786288 Publishing Hous2-0 rights re ( [ 4 ] ] O DDY V H , HARPER G S. G R E ENW O O D P L . et al . N u t r it i o na l and d e v elo p me nt al effects o n t h e i n tr i nsic p ro p er t i es o f m us cl e s as t he y r e l a t e t o t h e ea t i n g q ua l i ty of b e ef[ J] . Au str al ia n J o u rnal of E x - p eri me nt a l A g ricul tu r e ,2 001, 4 1 ( 7 ) :921 -9 4 2 . ) ( [ 5 ] 5 ] 王鸿泽.日粮能量水平对舍饲育肥牦牛生产性能、瘤胃发酵及肌内脂肪代谢的影响[D] .雅 安:四 川 农业大学,201 5 . W A N G Ho n gz e . E f f e c ts o f d i e t a ry en e rg y co n centration on p e r f or- ma n c e, r u me n f e r men tati o n a n d i n tr a m uscu l a r f a t m et a bo lism i n yaks f ed i n d oo rs [D ].Y a ’an: Sic h ua n A g ricu l tu r a l Un i ve rsity,20 15. ) ( | 6 ] 祁红霞,石红梅,杨勤,等.草原牧区牦牛舍饲育肥试验J .中国 牛业科学,2015 ,4 1( 6):4 6 - 48 . Q I H ongx i a ,S HI H on g m e i, YA N G qi n ,e t al. Fe e di ng a n d f a tten i nge x p e ri men t o f p r airi e a re as ya k ba r n [J]. C hin a C a t tl e S cienc e , 2 0 1 5 , 4 1( 6):46-48. ) ( [7 ] 郝婉名,祝超智,赵改名,等.西门塔尔杂交牛不同部位肉间 的 差 异性[J]. 肉 类研究,2019 ,33 (1 ) : 1 4 - 18 . HA O W anmi ng,Z H U Cha o z hi,ZHA O Gaiming , et al. D i ffe renc es inm eat qua li ty a m o ng dif f ere n t par ts of c r o s s b r e d s i m m e n t a l ca t t le [ J ] .M e at R es e arc h, 2 0 1 9. 3 3( 1 ) : 1 4 -1 8. ) ( [8 ] 牛 蕾,张志胜 , 李海鹏,等.中国西门塔尔牛不同部位肉品质评 定[ ]. 中国 畜牧 兽医,2011, 38( 3):217 - 220. N IU L e i , Z HANG Z h is h e n g . LI H a i peng, e t a l . Q u al it y v a l u a t i o n o f the d if feren t sites o f s i mmen t a l ca t t l e [ J ] . C h in a A ni ma l H us ba n md r y & V e teri n may Me d icine , 2 0 11 , 3 8(3):217-2 2 0. ) ( [9 1 周恒量.九龙牦牛不同部位肉品质对比研究[D ].雅 安:四川农业 大 学,20 16. Z HOU H en gl i a ng . Com p ar at i v e study o n m ea t qu a l i ty of d i f f e r ent p ositi o ns o f J i ul ong y ak[ D]. Y a ’an: Si c hu a n A g r i cult ura l Un i v er s ity,2 0 1 6. ) ( [ 1 0]程婷婷,张文 洁 ,王欢,等.新疆褐牛不同部位分割肉块品质差 异研究[.食 品 工业科技,2014.3 5(2 1 ) : 3 54 -3 5 7. C H EN G Ti n g t ing,Z HANG We n j ie,WAN G Hua n , et al. Di st i nc t io n of b eef q u a li ty i n d i f fer e n t c u t t i ng b e e f o f X in j ia ng b r o w n c att le [ J ].S c i ence an d T e ch n olo gy of Food I ndu stry , 201 4,35 ( 2 1 ):35 4-3 57 . ) ( [1 1 ] 李升升,靳 义 超.基于主成分和聚类分析的牦牛部位肉品质评 价[ .食 品与生物技术学报,2018,37( 2) :159 -164. L I S he n g sh e ng , JI N Y i c ha o . Ev a lu a ti on o f d i f fer en t c u t s o f t h e y ak m e a ts b a s e d on pr i nc i p a l c om pon e n t an d hi erarch i c a l cluster ana l y-sis [J ] . Jo u rn a l o f Fo o d Sc ie nce an d B i otech nolog y, 2018, 3 7 ( 2 ): ) s reserved. http://www.cnki.net ( [12 ] L A RICK D K, T URN ER B E . F l a v o r ch a r a ct e r i sti c s of f o ra ge a nd gra in- fed b ee f as in f l uenc ed b y pho sp ho li pid an d f a t t y aci d c om p o- s iti o na l dif f e r ences[J ] . J o u rna l o f Fo o d S cie nc e, 1 99 0, 55 (2): 31 2 - 317 . ) ( [1 3 ] 拜彬强,郝力 壮 ,柴沙驼 , 等.牦牛肉品质特性研究进展[J].食品 科 学,2014 . 35( 17) :290 -2 9 6. BAI B in qiang,H A O L i z h u a n g , C H A I Sh a tu o , e t a l . Pr og r e s s in u n- der stand ing m eat qua li ty ch a r a c t e r i st i es o f y ak [ J ] . F o o d S ci e nce ,2 0 1 4 ,35(1 7 ):2 90-2 9 6. ) ( [ 1 4]曹满湖,陈清华.维生素和矿物质对猪肉品质的影响[ .肉 类研 究 .20 07, 21 (8) :4 6 -4 9. C AO M a nhu ,C HE N Q ing hu a. T he e ffect o f vi ta mins an d m in e ra l s on p o r k q u a li t y [J ] . M ea t R e s e ar c h , 200 7 , 21 ( 8 ):4 6- 4 9. ) ( [15 ]刘佳东.后后牦牛肉成熟机理及肉用品质变化研究[D ].兰 州:甘肃农业大学,20 11. L I U Ji adong. Re se ar ch o n ya k me a t mat u r ation mec han is m a nd m e a tqualit y af t er slaught e r[ D] . L a n z h ou : G an su A g r icultural U n i vers i t y ,2 011 . ) ( [1 6 ] 邱燕,崔薇,陈韬.氯化钙处理对牛肉嫩化的研究进展[J].肉类 研究,200 9,2 3( 2 ):1 0- 1 3. Q I U Y a n , C UI W e i, CH E N T a o . R es e ar c h pr o g r ess on th e cal c i u m c h lo rid e t r ea tme n t t o t en d e r i ze b e e f J ]. Me at R es ea rch , 2 0 0 9,23 (2) :1 0- 1 3. ) ( [ 1 7 ] B A S S P D, T E E L , B E LK K E,et a l . E f fe c ts o f se x an d sh o rt - term m a gnesium s u p plem e nta t i on o n s t r es s r e sp o n ses a n d l ong is simus mu s c le qua l i ty c h a r acteri s ties of c r os s b r e d c a t t le [J] . J o u r n al o f Ani -m al S cien c e,2 010,8 8(1):34 9- 36 0 . ) ( [ 1 8 ] BOUT O N P E , H A R RIS P V , S H ORTHOSE W R. E ffec t o f u l t i m at e ) ( p H u p on th e wat e r- h o l d i ng capa c i t y an d t end e rnes s o f m u t to n[ J ].Jo urnal o f F o o d S c i ence , 1 97 1, 3 6( 3 ): 435 -43 9. ) ( [ 1 9] PU R CHAS R W, A U N G S U P A KOR N R. F u rth e r i nv es ti g ation s int o t h e rela ti o nshi p b et wee n u l tima t e pH and t end e r ne s s f o r be ef sam-p le s fr om b ul l s an d ste e rs[ J ] . M e at S c i e nce , 19 9 3, 3 4 ( 2 ) : 163 - 1 78. ) ( [20] VERBE K E W . V A N W EZEMA E L L . D E B ARC ELLO S M D . e t a l . E ur o p ea n b e ef c o n sum ers ’ in t e rest i n a b e ef eating-quali ty guara n-tee : In sig ht s fr o m a q u a l i tative st u d y i n f ou r EU c ou ntrie s[J ]. A p-pe ti t e , 2 010 .5 4 ( 2 ): 28 9 - 29 6. ) ( [21] LE GA K O JF, BR OOKS JC, O ' QU INN T G , e t a l . C on su me r pa l a ta - b ilit y sc o r es a n d vol a t i le b eef f l a v or com p oun ds o f fiv e USDA q ual i -ty g r ad e s a nd fou r mu scle s[J ]. Meat S c i e n c e, 2015 , 10 0:2 9 1-3 00. ) ( [22 ] PR O ST E, P EL CZY IS KA E, KO T U LA A W . Q u a l i t y c h ar act er is tics o f b o v i n e m e at. II . b ee f t e n d e rnes s i n re l ation to in d i vidu a l m u s cles . ag e and s e x o f a n imal s a n d ca rc a ss quali t y g r a de [J ]. J o urn a l o f A ni - mal S c i en c e , 19 75,41 ( 2):541- 54 7 . ) ( [23] AN DER S ON M J . L O N E RGA N S M. F E D LER C A. et a l . P rof il e ofb io ch e mi c al t r ait s i nf l u en c i n g t e n d e rnes s o f m u sc l e s f r om t h e b e ef r ou nd[J ] . M e at S c ience , 2 012 , 9 1(3):247 -25 4. ) ( [2 4 ] HU N T M R, GA R MYN A J, O'QUINN T G , e t al. C o n s um er as s e s s -m ent o f be ef p ala t a b ilit y f r o m f o ur b ee f m us c le s f ro m USDA Ch oic e a nd S e l e ct gra de d car ca s s es[ J]. M ea t S c i enc e, 2 0 14 ,98 (1 ) :1 - 8. ) ( [2 5 ]R A M SBOTTOM J M, STRANDINE EJ.C o m p a r ativ e ten der ness andi de n tifi ca tio n of m us c le s i n w ho l esa le b e e f c u t s[ J ] . Jo u rn al of Fo o dS c ie nce , 1 9 4 8 . 1 3( 4 ) :31 5- 330. ) ( 加工 编 辑 :姚 骏 ) ( 收稿日 期: 2019- 1 2- 1 8 ) (C通倩作者郝力粘n·家幕Jurnal Electronic Publishing House. All rights reserved. http://www.cnki.net (C)China Academic Journal Electronic Publishing 均在存在存在曼著性差异Rao.net 以18头舍饲育肥牦牛的背阔肌、臂三头肌、腰大肌、背最长肌、臀股二头肌、半腱肌 6 个部位的肌肉 为研究对象, 分别对其常规营养成分、矿物质元素及食用 品质进行分析, 研究牦牛不同肌肉部位的营养品质和食用品质之间的差异。研究结果表明:常规营养成分中, 各部位除蛋白 不存在显著性差异外(P>0.05) , 其它指标均存在差异显著(P<0.05),其中背阔肌的脂肪含量显著高于其它部位(P<0.05);从矿物质元素来看, 背阔肌的 Ca、Na 含量较其它部位高,半腱肌的 K、Mg 含量较高,臂三头肌的微量元素含量较丰富;从肉的食用品质上来看,腰大肌及背最长肌嫩度较好,臀股二头肌和背最长肌的持水力较其它部位强。结果表明 , 不同 部位的肌肉 在营养品质和食用 品质方面均存在很大差异,综合看来,背最长肌的肉质较好,其次为臀股二头肌, 为今后肉 块分割增值技术及等级评价体系 的建立提供依据。本文主要对育肥的牦牛不同部位牦牛肉品质进行详细研究,旨在探索育肥牦牛的肉品质,为不同部位肉块的加工和品质改进提供依据, 为建立牦牛肉等级评价体系提供数据支撑。主要仪器:物性分析仪-质构仪(美国FTC,TMS-PRO)质构仪剪切力测试:用 1.27 cm 的圆形取样器沿与肌纤维平行的方向钻取肉样,孔样长度不少于 2.5 cm, 选择燕尾型探头,用 TMS-PRO 食品物性分析仪测定每个肉样的剪切力值(N),每个样品重复测定 3 次,取平均值。质构仪结果分析:大理石花纹评分主要针对的是肉的肌内脂肪, 育肥牦牛不同部位的剪切力值表明,大理石花纹评分与剪切力密切相关,其中,大理石花纹评分越高, 剪切力值越低, 也就表明肉的嫩度越好。 背阔肌和臂三头肌的剪切力显著高于其它部分(P<0.05) , 而背最长肌的剪切力最低, 低至 25.59 N。 文献来源:青海大学, 青海省高原放牧家畜动物营养与饲料科学重点实验室
关闭还剩4页未读,是否继续阅读?
继续免费阅读全文北京盈盛恒泰科技有限责任公司为您提供《牦牛肉中品质检测方案(质构分析仪)》,该方案主要用于其他肉制品中理化分析检测,参考标准《暂无》,《牦牛肉中品质检测方案(质构分析仪)》用到的仪器有美国FTC-质构仪、FTC-质构仪TMS-PRO。
