RAZ-99082Kyoto Electronics Manufacturing Co.,Ltd.Data No.: RV09-99064 No.RAZ-99082 KEM Application Note Refractive Index of 20%-Sucrose Solution Summary- As the result of studying the repeatability of the refractive index of 20%-sucrose solution byCHD-500Nattached RA-520, a good result was obtained with 0.00001 of S.D.(n=24) -Measuring instrument- Main unit : Refractometer RA-520 Option: Multiple Sample Changer CHD-500N Connecting kit for Refractometer #434-0104 Rinse solution- Rinse 1: water Rinse 2: acetone Measurement method- Put the sample in vials and set them onto the turntable of CHD-500N. ④ Press [Meas.] key to start measuring the index of refraction of the sample. -Equation- Concentration calculation: converted to Brix values Ambient condition- Temperature: 23.5C Relative Humidity: 52% Weather: Fine -Reference- -Measurement parameter- -Printout data- [Measurement Parameterl Method No. : 0 Method Name : Brix 20 nD Temperature : 20.00℃ Stability : 0 Wait Time 20.01% : 0s Sequence : On Sampling : Auto Samp.Limit : 0 sec O.S. Rate : 10% Drain : Auto Drain Rate : 200% Rinse-1 : Set Rinse-1 Time 20.01% : 10s Rinse-2 : Set Rinse-2 Time : 10 s Purge : Set Purge Time : 240 s Meas. Temp. : 20.05℃ nD 1.36386
产品配置单
可睦电子(上海)商贸有限公司-日本京都电子(KEM)为您提供《糖果/巧克力及制品中理化分析检测方案 》,该方案主要用于糖果中理化分析检测,参考标准《暂无》,《糖果/巧克力及制品中理化分析检测方案 》用到的仪器有RA-620/RA-600全自动折光糖度仪、RA-620高精度数字式折光仪、RA-600全自动台式折光仪。
