红葡萄酒中乙醇含量检测方案(饮用酒检测仪)
检测样品 葡萄酒及果酒
检测项目 理化分析
关联设备 共2种 下载方案
方案详情
数字式酒精度计测定智利红葡萄酒中的乙醇含量 应用资料 这是一个关于智利红葡萄酒(中等酒体类型)中酒精度含量(vol%)、相对密度(t/t)和密度(g/cm3)的测定范例。高精度数字式酒精度计可用于确定葡萄酒酿造过程中的这些应用。技术说明: 酒精样品必须按照当地法规规定的程序蒸馏,然后才能使用数字式酒精计测量乙醇含量。
数字式酒精度计测定智利红葡萄酒中的乙醇含量 应用资料这是一个关于智利红葡萄酒(中等酒体类型)中酒精度含量(vol%)、相对密度(t/t)和密度(g/cm3)的测定范例。高精度数字式酒精度计可用于确定葡萄酒酿造过程中的这些应用。技术说明: 酒精样品必须按照当地法规规定的程序蒸馏,然后才能使用数字式酒精计测量乙醇含量。KGM KYOTO ELECTRONICSMANUFACTURING CO.,LTD.APDA-02070v enLK-MKYOTO ELECTRONICSMANUFACTURING CO.,LTD.1/1 Application Note Determinationof alcohol content inChilean redwine(medium-bodied wine) by Alcohol meter Industry Food and BeverageInstrument Alcohol meterMeasurement method GB 5009.225, Resonant frequency oscillation 1.Scope This is an example about determination of the alcohol content (vol%), specific gravity (t/t) anddensity (g/cm3) in Chilean red wine (medium-bodied type). The alcohol meter can be used enoughfor determination of these applications on the wine making process. Technical note: The alcohol sample must be distilled as per the procedure specified on localregulations before the alcohol content can be measured with this alcohol meter. 2. Apparatus ·Alcohol meter ALM-155 ·Distillation apparatus 3. Sample ·Chilean red wine (medium-bodied wine) 4.Reagent ·Pure water for rinsing 5. Procedure A: Alcohol content (vol%): Take distilled sample solution into beaker Introduce the sampling nozzle into the beaker Press [Meas.] button on the instrument B: Specific gravity (t/t) and Density (g/cm): Take wine sample solution into beaker Introduce the sampling nozzle into the beaker )Press [Meas.] button on the instrument 6.Measurement results Alcohol (vol%) at 20℃ S.G. (t/t) Density (g/cm’) 1 13.13 0.99420 0.99242 2 13.13 0.99420 0.99242 3 13.13 0.99420 0.99242 Mean 13.13 0.99420 0.99242 SD 0.00 0.00 0.00 RSD(%) 0.00 0.00 0.00 京都电子工业株式会社-可睦电子(上海)商贸有限公司 上海市徐汇区宜山路333号1201室电话: 021-54488867 电邮: kemu-kem@163.com 网址: http://www.kem-china.com
关闭
  • 1/1
产品配置单
可睦电子(上海)商贸有限公司-日本京都电子(KEM)为您提供《红葡萄酒中乙醇含量检测方案(饮用酒检测仪)》,该方案主要用于葡萄酒及果酒中理化分析检测,参考标准《暂无》,《红葡萄酒中乙醇含量检测方案(饮用酒检测仪)》用到的仪器有ALM-155高精度酒精度测定仪(GB 5009.225-2023)、DA-850台式U形振动管法数字式密度计。
我要纠错
推荐专场
相关方案
