典型的定量模型使用单个峰的高度或面积。CLS(经典最小二乘法)定量是一种多变量分析模型,使用整个光谱数据中的面积,这取决于浓度。因此,CLS是一种有效的定量方法,由于多组分的重叠光谱,很难找到用于定量的单个峰,并且需要同时定量多组分。CLS定量的优点如下所示。首先,由于整个波数区域用于定量计算并且降低了残余噪声水平,因此期望更高的精度。其次,使用CLS可以获得每种化合物的纯光谱。因此,更容易准确地分析多个成分。测量:使用光学路径长度为100m的OPEN-PATH FTIR系统反复监测大气中5种气体成分(CH4、N2O、CO、CO2和H2O)的平均浓度。图1显示了使用预先制备的CLS校准曲线获得的定量结果,对于每个成分,在指定的时间段(5分钟)内,这些结果显示为时间过程数据。显示了时间过程中的浓度变化。Application Note230-QU-0175 Simultaneous Monitoring Analysis of MulticomponentGas in the Atmosphere using CLS Quantitation2/2Application Note Simultaneous Monitoring Analysis of Multicomponen t Gas i n the Atmosphere using CLS Quantitation Introdu c tio n Typica l q u a n titat i on model s use eithe r t he heigh t or area of a single peak. CLS (Classical Least Square) quantitation is a m u lt i var i ate ana l ysis model tha t u ses the area in the enti r e spectra l data, which is dependent o n the concent r ation.Therefore, CLS i s an effect i ve quantitation method where it is di f ficu l t to f ind a single peak for q u a n titation because of ove r l a i d spectra of mult i -compone n ts, and simultaneous qu a ntitation of mu l t i -compone n t is requi r ed. The advantages of CLS quantita t ion are shown below. Fi r st, h i g h er accu r acy is expected because the entire wavenumber r egion is used for the quantitation ca l culation and the residua l noise leve l i s reduced. Second, pure spectra of each compound can be obta i ned using CLS. So, it is easier to a n alyze mu lt i-components accu r ate l y. Measu r ement T h e average concent r atio n s of 5 components of gases (CH4, N,O,co, co, a n d H,O) i n the atmosphere were r e p eatedly mo n itored using the OPEN-PATH F T IR system with an optic a l path leng t h of 100m. Figu r e 1 shows t h e quant i ta t ion r esu l ts o b t a ined using CLS cali b rat i on cu r ves prep a red i n advance, for s p ec i f i ed periods (5 m i n ) for each com p o n ent, which are shown as t i me-course data. The conce n tra t i on ch a nge du rin g the ti me -course is s h own. A ccu m ulatio n s: 200Res ol uti on : 1c m-1Ap o di z ati o n: C osin e O p t ica l p a t h le n g th: 100 m (OP E N -PA T H FT-IR )S t a n d a r d gas cel l : 3 m (c a l ib r at io n model ) Figure 1. CLS automatic meas ur eme n t m o n itor scree n Figure 2. Sta n dard gas (uti l izing 3 m cell) R esul t s Figure 2 Results for eac h st an dard gas (100 ppm) i n a sta n da r d gas cell (3m). The absor p tion spectra of t he following g a ses CO, CO, a n d N,O are overlapped. T o d e termine t h e detect i on l i mits, from a concentrat i on of 100 ppm of N,O gas cor r espond i ng to a n absor b ance 0.400, it can be ext r apola t ed t hat a conce n tration of 1 ppm, ha s 0.004 ABS, it i s est i mated th at qu a nt i tatio n to a conc e n trat i on <1 ppm i s possi bl e Figure 3 Calibration models (CH and CO gas) were meas u r ed using a stand a rd gas cell (3m). The calibration c u rves show good l inearity i n the range of 1-120 ppm. The cor r e l at i o n coefficient is better t h an 0.98. Calibration models for CO,,N,O and H,O gas were also created (not shown). The opt i cal path di f ference is cor r ected automat i cal l y in the measurement using the [OPEN-PATH FT-IR]. Figure 3. Cal i br ati on model: CH Figure 4. Cali b r a tion mo del: Co JASCO INC. 28600 Mary's Cour t , E a s to n , M D 21601US A T el : (800) 333-5272, Fa x : (410) 822-7526 A ppli c a tio n Lib r ary: htt p://www.jas co in c .c o m/a pp l icatio n s
关闭产品配置单
佳士科商贸有限公司为您提供《利用CLS定量同时监测大气中多组分气体的分析》,该方案主要用于空气中CLS定量、多组分气体分析检测,参考标准《暂无》,《利用CLS定量同时监测大气中多组分气体的分析》用到的仪器有JASCO傅立叶变换红外光谱仪FT/IR-6000。
