Data No.NR08-06193上海市中山西路2366弄1号203室网址: http://www.kem-china.com KEM ApplicationNote No.RAA-06004Refractive index measurement Kyoto Electronics Manufacturing Co.,ltd. Refractive index of perfume -Measuring instrument- Main unit: RA-520N Refractometer -Solvent- Solvent: Acetone -Measurement method- (1))FFactor calibration was performed using pure water. (2)Dropped a few drops of sample using a dropping pipette. (3) Measured R.I.(refractive index) (4)Wiped off the sample by tissue paper, and cleaned prism surface by acetone. Measurement temperature: 20.0℃ -Concentration conversion- ·No conversion for concentration -Ambient condition- Ambient: 26.0 ℃ Humidity: 48 % Weather: Fine -Measurement parameter- -Printout data- Meas.Temp:20.00)Stability : 1Limit Time: 600 sec Sequence:00000 [CALCU.PARA] Date :06/10/30 19:07 Method : 2Result nD [Zero Point Calib.] Model:RA-520NS/N : Date : 06/10/30 14:51Temp : 20.00 Old New 1.33304 ---1.33299 :06/10/30 14:56 : 20.00) C M.Time: 00:00:21 nD :1.49294 No.01-02 Date :06/10/30 15:00 Temp : 20.00 C M.Time : 00:00:41 nD :1.49313 No.01-03 Date :06/10/30 15:03 Temp 20.00 CM.Time : 00:00:38 nD :1.49302 -Measurement results- -Comment- Sample: A B C Measured data: 1.49294 1.49313 1.49302 * Perfume products can easily bequality controlled by combinedmeasurement using density meter andrefractive index. Also, automation ofcontinuous measurement of pluralnumber of sample is possible by CHDMultiple Sample Changer.
关闭产品配置单
可睦电子(上海)商贸有限公司-日本京都电子(KEM)为您提供《香精香料中折光指数检测方案 》,该方案主要用于香精香料中折光指数检测,参考标准《暂无》,《香精香料中折光指数检测方案 》用到的仪器有RA-620/RA-600全自动折光糖度仪、RA-620高精度数字式折光仪、RA-600全自动台式折光仪。
