KeM Application Note No.TIQ-05321 Platingsolution Concentration of Nickel chloride inNickel plating solution Precipitationtitration 1. Abstract The concentration of Nickel chloride is determined on the acidic mixed sample of Nickel chloride and Nickel sulfate which is prepared for Nickel plating solution.For ordinary Nickel plating solution, it is impossible to determine only Nickelchloride due to the coexistence of Nickel sulfate in the solution. Instead, it isdetermined by measuring the concentration of chloride ion in the sample. Theconcentration of chloride ion in the sample is determined by titrating the samplewith 0.1mol/L Silver nitrate solution to the equivalence point that corresponds tothe maximal inflection point on the titration curve. 2. Reference 3.Tips for measurement 1) In the case that the sample is taken out from Nickel plating bath, carry out anappropriate pretreatment such as filtration. 2) In the case that the sample may be contaminated by chloride ion from othercauses, this measuring method is not applicable. 3) Use the Mercury sulfate reference electrode or the conventional Silver chlorideelectrode the internal solution of which is replaced with 1mol/L Potassiumnitrate solution in order to prevent measurement error caused by the leakageof chloride ion. 4)) The tip of Silver electrode should be polished with special-purpose polishingpaper before the measurements. 5) In this application note, the convenient combined silver electrode is used; thesame measurement results will be obtained by using an ordinary silverelectrode plus the corresponding reference electrode. 上海市漕溪路222号航天大厦北楼902室网址: http://www.kyoto-kem. net. cn 4.Equipment Main unit : Automatic potentiometric titrator AT-510 Detector:: Standard preamplifier STD-510 Combination silver electrode C-372+ Cable #429-0012 (inner filling: 1mol/L Potassium nitrate) 5. Reagent Titration solution :0.1mol/L Silver nitrate solution 6. Analysis Procedure 1) Place 5mL of sample in 200mL beaker. 2) Add pure water to make a total of 100mL solution. 3) Titrate with 0.1mol/L Silver nitrate solution to obtain concentration of Nickelchloride. 7. Calculation Concentration (g/L)=(EP1-BL1)xTFxC1xK1/SIZE EP1 : titrated (mL) BL1 : blank (mL)=0 : titrant factor=0.9806 : concentration conversion coefficient=6.48(1mL of 0.1mol/L AgNO3 corresponds to 6.48mg of NiCl2) K1 : unit conversion coefficient=1 SIZE : sample size=5 (mL) 8. Example of Measurement -Ambient condition- Room temperature: 22.5°℃ Humidity: 47% Weather: Cloudy Date:2005/06/18 11:49 Sample ID : Method No.: 15
还剩2页未读,是否继续阅读?
可睦电子(上海)商贸有限公司-日本京都电子(KEM)为您提供《自动电位滴定仪测定镍电镀液中氯化镍的含量》,该方案主要用于其他中null检测,参考标准《暂无》,《自动电位滴定仪测定镍电镀液中氯化镍的含量》用到的仪器有AT-710B简易实用型自动电位滴定仪、AT-710S豪华型自动电位滴定仪、AT-710M四通道旗舰型自动电位滴定仪。
