http://www.aist.go.jp/RIODB/SDBS/menu-e.html 一个免费图谱数据库,含4.98万张IR图谱 http://www.wpi.edu/Academics/Depts/Chemistry/Courses/CH2670/infrared.html IR光谱基础 http://chipo.chem.uic.edu/web1/ocol/spec/IR.htm 红外基础,有习题解答. http://www.chem.ucalgary.ca/courses/351/Carey5th/Ch13/ch13-ir-4.html 几个IR光谱的解释 http://www.sienahts.edu/~swathen/organic/molecules/IR_oil_2002.html IR Spectra of Fats and Oils——脂类和油的红外图谱 http://www.chem.ucla.edu/~webspectra/ 一个在线解谱题库。适合初学者!有近百道解谱的习题,有答案。 http://www.organic.wsu.edu/chem341/IRProblemSet.pdf IR吸收频率表和习题(PDF) http://www.dq.fct.unl.pt/qoa/jas/ir.html IR网络资源,对大家可能有用. http://wwwchem.csustan.edu/Tutorials/INFRARED.HTM IR光谱解析Interpretation of Infrared Spectra 个人觉得非常不错,官能团的振动全部标出 http://www.sigmaaldrich.com/Brands/Fluka___Riedel_Home/Analytical/Spectroscopy/Solvents.html IR Solvents 红外用的溶剂 The increased sensitivity of modern IR-Spectroscopy demands the highest purity solvents available. Our IR Solvents have undergone rigorous purification processes in order to ensure its suitability for IR-Spectroscopy. All IR-solvents are tested for the absence of foreign band absorption in the IR-spectrum (see Figure 1: IR spectrum of Carbon disulfide). Interpretation of Infrared Spectra, A Practical Approach (PDF file size: 243K) http://www.spectroscopynow.com/Spy/pdfs/eac10815.pdf 红外光谱解析,实践.(PDF文件,243K)有典型的IR图谱,数据. http://chemistry.uah.edu/faculty/vogler/LectureNotes331/CH331Chap12-ir.pdf 一个IR课件(PDF),有图,有峰的简要归属.
