JIS A 1901:2003(英文版) 挥发性有机化合物 小室法 Determination of the emission of volatile organic compounds and aldehydes for building products-small chamber method
ANSI/BIFMA M 7.1:2007 办公家具体系、家具组成和座椅的VOC释放的检测测试标准 Standard for Formaldehyde & TVOC Emissions From Office Furniture Systems, Components and Seating
ANSI/BIFMA X 7.1:2007 低释放量办公家具和座椅的甲醛和TVOC释放标准 Test Method for Determining VOC Emissions of Low-emitting Office Furniture systems and Seating
DD ENV 13419-1:1999 建筑产品.挥发性有机化合物释放量的测定.释放试验房间法 Building products. Determination of the emission of volatile organic compounds. Emission test chamber method
DD ENV 13419-2:1999 建筑产品.挥发性有机化合物释放量的测定.释放试验槽法 Building products. Determination of the emission of volatile organic compounds. Emission test cell method
DD ENV 13419-3:1999 建筑产品.挥发性有机化合物散发测量.样品的取样、储存和试件制备 Procedure for sampling, storage of samples and preparation of test specimens
