abow0926 2009/04/21
[color=#DC143C][size=5][font=楷体_GB2312]主機板的電池沒電了,所以什麼東西都記不起來^^"[/font][/size][/color]
ciaclin 2009/04/22
[quote]原文由 [B]fengxuemei[/B] 发表: [quote]原文由 [B]abow0926[/B] 发表: [color=#DC143C][size=5][font=楷体_GB2312]主機板的電池沒電了,所以什麼東西都記不起來^^"[/font][/size][/color][/quote] 好像是那样啊,一语中的![/quote] We had similar problems on the 2487 before. Here is the solution we got from Waters technical service. Open the cover -> locate the battery inside in the detector (deuterium lamp.) ( the stored lamp data is invalid) ->After changing the battery, the lamp' data need to be reset, ( you could do it manually by using the input/output diagnostics or use the millennium to perform the diagnostics precess. -> need to re-calibrate again. or power on/off again and press "enter" let the lighting warm up 5 mins. Hope it helps.
soho1107 2009/04/21
时间久了没开机,是否是主板电池没电了,参数都丢了吧.
sulian2008 2009/04/21
[quote]原文由 [B]abow0926[/B] 发表: [color=#DC143C][size=5][font=楷体_GB2312]主機板的電池沒電了,所以什麼東西都記不起來^^"[/font][/size][/color][/quote] 同意!给主板换个新电池试试就知道。
liyunk 2009/04/22
那个是由于电池没电了,市场上修表的地方买个2032纽扣电池换上,手动校正一下就ok了,花不了几块钱,
