Data analysis any net CDF or .d compatible software Memory on-board compact flash (1GB) LTM column (typical) MXT-5.5m*0.1mm*0.4umdf Resolution less than unit mass to 230amu,nominal unit mass to 500amu
Chemical libraries
Target analysis IFD deconvolution software ,automated on K(产品名): User defined using gc retention times and spectral data
