if the monochromator is used, usually, yes, you need a notch filter which rejects the stray light from laser. If double or triple spectrographs are used, the notch filter is not necessary.
second question: yes, for different wavelength laser radiation, you have to use different notch filter. You can check the transmittance curve to make the choice of filter.
