shilei810924
第6楼2010/06/14
你可以试验一个不锈钢,我把Cr,Fe,Ni的参数给你吧
谱线分数:0.8821 0.8929 0.8771
跃迁因子 0.881 0.876 0.872
荧光产额 0.275 0.34 0.406
质量吸收系数 83018*power(E,-2.757) Cr
10112*power(E,-2.652),82058*power(E,-2.682) Fe E为激发限的分界点
12372*power(E,-2.615),101164*power(E,-2.682) Ni E为激发限的分界点
我拟合好的公式,计算不锈钢的话,Cr,Fe,Ni的相对强度和测量强度的R2都在0.999以上。
原级谱图:Rh,125Be,25Angle,15kV的电压,Ag,200Be,不会差很多
条件应该都够了,可以试验了,计算过程和最后的回归分析应该会吧,不过现有的回归都不会收敛的。
5.995 4.20E-02
6.065 4.14E-02
6.134 4.08E-02
6.204 4.02E-02
6.274 3.96E-02
6.344 3.90E-02
6.414 3.84E-02
6.484 3.78E-02
6.553 3.72E-02
6.623 3.66E-02
6.693 3.60E-02
6.763 3.54E-02
6.833 3.49E-02
6.902 3.43E-02
6.972 3.38E-02
7.042 3.32E-02
7.112 3.27E-02
7.182 3.21E-02
7.251 3.16E-02
7.321 3.10E-02
7.391 3.05E-02
7.461 3.00E-02
7.531 2.95E-02
7.6 2.90E-02
7.67 2.85E-02
7.74 2.80E-02
7.81 2.75E-02
7.88 2.70E-02
7.949 2.65E-02
8.019 2.61E-02
8.089 2.56E-02
8.159 2.52E-02
8.229 2.47E-02
8.299 2.43E-02
8.368 2.38E-02
8.438 2.34E-02
8.508 2.29E-02
8.578 2.25E-02
8.648 2.21E-02
8.717 2.17E-02
8.787 2.13E-02
8.857 2.09E-02
8.927 2.05E-02
8.997 2.01E-02
9.066 1.97E-02
9.136 1.93E-02
9.206 1.90E-02
9.276 1.86E-02
9.346 1.82E-02
9.415 1.78E-02
9.485 1.75E-02
9.555 1.71E-02
9.625 1.68E-02
9.695 1.64E-02
9.764 1.61E-02
9.834 1.58E-02
9.904 1.54E-02
9.974 1.51E-02
10.044 1.48E-02
10.113 1.45E-02
10.183 1.42E-02
10.253 1.38E-02
10.323 1.35E-02
10.393 1.32E-02
10.463 1.29E-02
10.532 1.26E-02
10.602 1.24E-02
10.672 1.21E-02
10.742 1.18E-02
10.812 1.15E-02
10.881 1.12E-02
10.951 1.09E-02
11.021 1.07E-02
11.091 1.04E-02
11.161 1.01E-02
11.23 9.89E-03
11.3 9.63E-03
11.37 9.37E-03
11.44 9.12E-03
11.51 8.87E-03
11.579 8.63E-03
11.649 8.38E-03
11.719 8.14E-03
11.789 7.91E-03
11.859 7.67E-03
11.928 7.44E-03
11.998 7.21E-03
12.068 6.99E-03
12.138 6.76E-03
12.208 6.54E-03
12.278 6.33E-03
12.347 6.11E-03
12.417 5.90E-03
12.487 5.69E-03
12.557 5.48E-03
12.627 5.28E-03
12.696 5.08E-03
12.766 4.88E-03
12.836 4.68E-03
12.906 4.49E-03
12.976 4.29E-03
13.045 4.10E-03
13.115 3.92E-03
13.185 3.73E-03
13.255 3.55E-03
13.325 3.37E-03
13.394 3.20E-03
13.464 3.02E-03
13.534 2.85E-03
13.604 2.68E-03
13.674 2.52E-03
13.743 2.35E-03
13.813 2.19E-03
13.883 2.03E-03
13.953 1.88E-03
14.023 1.72E-03
14.093 1.57E-03
14.162 1.43E-03
14.232 1.28E-03
14.302 1.14E-03
14.372 1.01E-03
14.442 8.73E-04
14.511 7.43E-04
14.581 6.17E-04
14.651 4.96E-04
14.721 3.80E-04
14.791 2.70E-04
14.86 1.67E-04
14.93 7.33E-05
15 0.0 0E+00
