【分享】一本关于NMR弛豫的专著 Practical NMR relaxation for chemists [PDF,209p]
核磁共振技术(NMR)
  • 论坛上不少朋友对NMR驰豫的问题感兴趣,现上载一本关于NMR弛豫的专著供有兴趣者研读。
    该书虽然是为化学家所写,但还是需要有一些物理学和NMR背景知识。该书对在实验室工作的NMR工作者是有用的。
    这本书可能是教授化学家NMR驰豫技术的第一本专著。2005年出版,还是比较新的。
    Author: Bakhmutov, Vladimir , I.
    Publisher: John Wiley & Sons, Ltd.
    Format: Adobe (Encrypted PDF)
    Content Language: English
    Contents
    1 How and Why Nuclei Relax 1
    1.1 Nucleus in an External Magnetic Field 4
    1.2 Spin–Lattice and Spin–Spin Nuclear Relaxation 7
    1.2.1 Macroscopic Magnetization: Relaxation
    Times T1 and T2 8
    1.3 Molecular Motions as the Reason
    for Nuclear Relaxation 11
    1.3.1 Correlation Times and Activation Energies
    of Molecular Motions 13
    1.3.2 Isotropic and Anisotropic Molecular Motions 15
    Bibliography 18
    2 How to Measure NMR Relaxation
    Times 19
    2.1 Exponential and Non-exponential
    Nuclear Relaxation 20
    2.2 Measurements of Spin–Lattice
    Relaxation Times 20
    2.3 Measurements of Selective and Biselective
    T1 Times 24
    2.4 Determination of T1ρ and T2 27
    2.5 Preparation of Samples for Relaxation
    Experiments 28
    Bibliography 29
    3 Errors in Determinations
    of Relaxation Times 31
    3.1 Instrumental Errors 32
    3.2 Incorrect Parameters for T1, T2 Measurements
    and T1, T2 Calculations 33
    3.3 Coupled Nuclear Relaxation 34
    3.4 Chemical Exchange 37
    Bibliography 42
    4 NMR Relaxation by Dipole–Dipole
    and Quadrupole Interactions 43
    4.1 Intramolecular Dipole–Dipole Relaxation:
    Homo- and Heteronuclear Dipolar Coupling and
    the Spectral Density Function 44
    4.2 How to Reveal the Presence of the Dipolar
    Mechanism 48
    4.2.1 NOE as a Test for Dipole–Dipole Nuclear
    Relaxation 48
    4.2.2 Evaluations of the Dipolar Contributions from
    Selective and Nonselective T1 Times 52
  • celan
    第1楼2010/06/10
    Contents ...
    Contents vii
    4.3 Intermolecular Dipole–Dipole Interactions 53
    4.4 Electric Field Gradients
    at Quadrupolar Nuclei 53
    4.5 Nuclear Quadrupole Coupling Constant
    as Measure of the Electric Field Gradient 54
    4.6 Quadrupole Relaxation 56
    Bibliography 57
    5 Relaxation by Chemical Shift
    Anisotropy, Spin–Rotation
    Relaxation, Scalar Relaxation
    of the Second Kind
    and Cross-mechanisms 59
    5.1 Relaxation by Chemical Shift Anisotropy 59
    5.2 Spin–Rotation Relaxation 63
    5.3 Interference Mechanisms of Nuclear Relaxation 64
    5.4 Scalar Relaxation of the Second Kind 65
    Bibliography 67
    6 Nuclear Relaxation in Molecular
    Systems with Anisotropic Motions 69
    6.1 Spin–Lattice Nuclear Relaxation in Ellipsoidal
    Molecules: Temperature Dependences
    of T1 Times 70
    6.2 How to Reveal Anisotropic Molecular Motions
    in Solution 74
    viii Contents
    6.3 Nuclear Relaxation in the Presence
    of Correlation Time Distributions 76
    Bibliography 80
    7 1H T1 Relaxation Diagnostics
    in Solution 81
    7.1 Revealing Weak Intermolecular Interactions
    by T1 Time Measurements in Solution 82
    7.2 T1 Studies of Exchange in Simple Molecular
    Systems 87
    7.3 Structural 1H T1 Criterion 89
    7.4 Partially Relaxed NMR Spectra 92
    Bibliography 94
    8 Internuclear Distances from 1H T1
    Relaxation Measurements
    in Solution 97
    8.1 X−H Distances: Metal–Hydride
    Bond Lengths 98
    8.1.1 How to Determine Metal–Hydride Bond Lengths
    by Standard 1H T1 Measurements 101
    8.1.2 Metal–Hydride Bond Lengths by 1H T1sel
    and 1H T1min Measurements 104
    8.2 Proton–Proton Distances by Standard
    1H T1 Measurements 108
    8.3 H−H Distances by T1sel/T1bis Measurements 111
    8.4 H...H Distances in Intermediates 115
  • celan
    第2楼2010/06/10
    11 Relaxation of Nuclei Other Than 1H
    and 2H and Specific Relaxation
    Experiments 155
    11.1 Chemical Shift Anisotropies and Nuclear
    Quadrupole Coupling Constants from T1 Times
    of Heavy Nuclei in Solution 156
    11.2 Multinuclear Relaxation Approaches to
    Complexation, Association and H-bonding 159
    11.3 23Na Relaxation in Solutions of Complex
    Molecular Systems 162
    11.4 Character of Molecular Motions from 17O and 2H
    T1 Relaxation in Solution 165
    11.5 Two-dimensional T1 and T1ρ NMR Experiments 166
    11.6 Chemical Exchange in Complex Molecular
    Systems from 15N Relaxation in Solution 168
    11.7 R1/R2 Method 170
    11.8 Cross-correlation Relaxation Rates
    and Structures of Complex Molecular
    Systems in Solution 172
    11.9 Variable-field Relaxation Experiments 174
    Bibliography 176
    12 Paramagnetic NMR Relaxation 179
    12.1 Theoretical Basis of Paramagnetic Relaxation
    Enhancement 179
    12.2 Paramagnetic Relaxation Rate Enhancements
    in the Presence of Chemical Exchange 185
    12.3 Structural Applications of Paramagnetic
    Relaxation Rate Enhancement 187
    12.4 Kinetics of Ligand Exchange via Paramagnetic
    Relaxation Rate Enhancement 191
    12.5 Longitudinal Electron Relaxation Time
    at Paramagnetic Centers from
    Variable-high-field NMR Experiments 193
    Bibliography 195
  • celan
    第3楼2010/06/10
    化学家实用NMR驰豫
    下载
  • lydia0511
    第4楼2010/06/11
    下来看看。谢谢分享!
  • 熊猫宝宝
    第5楼2010/06/11
    收藏., 不知道有没有中译版本的?
  • chemicalanalyst
    第6楼2010/06/12
    以前对弛豫就不怎么懂,平时也不操作核磁,所以也不要求
    研读研读此书,抑或释解疑惑!
    谢谢!
  • sslin
    第7楼2010/06/13
    弛豫的应用这些年来逐渐广泛流行起来.
    未来可以鼓励每个课题组, 报导与分析所涉及化合物的弛豫情况, 了解其相关理化变化与涵义.
  • It`s me
    第8楼2010/06/14
    下载收藏了,谢了!
  • zhouqj
    第9楼2010/06/15
    收藏了,谢谢楼主分享关于“驰豫”方面的资料!
