盐酸曲美他嗪欧洲药典杂质
  • smiles2010
    2011/11/24
化学药检测
  • 提供盐酸曲美他嗪欧洲药典杂质标准品
    Trimetazidine for system suitability
    Imp. A (EP) as Dihydrochloride: 1-(3,4,5-
    Trimethoxybenzyl)piperazine Dihydrochloride
    Imp. B (EP): 1,4-Bis(2,3,4-trimethoxy-
    benzyl)piperazine
    Imp. C (EP): 2,3,4-Trimethoxybenzaldehyde
    Imp. D (EP): (2,3,4-Trimethoxyphenyl)methanol
    Imp. E (EP) as Dihydrochloride: 1-(2,4,5-
    Imp. F (EP) as Dihydrochloride: 1-(2,4,6-Tri-
    Imp. G (EP) as Hexahydrate: Piperazine Hexahydrate
    Imp. H (EP): Ethyl 4-(2,3,4-Trimethoxybenzyl)-
    piperazine-1-carboxylate
    1-Formyl-4-(2,3,4-trimethoxybenzyl)piperazine
    Hydrochloride
  • 该帖子已被版主-tangtang加2积分,加2经验;加分理由:鼓励发贴
  • tangtang
    第1楼2011/11/24
    要检这么多的杂质,对照品就要花一大笔钱。
  • xiaowang268
    第2楼2011/11/25
    杂质的对照品,不一定要全买的吧
  • zhaohua8011
    第3楼2011/11/25
    杂质的对照品可以选择一部分,要根据你的质量标准而定!
  • xiaowang268
    第4楼2011/11/25
    楼上说的对头
  • huangyaoshi1026
    第5楼2012/10/15
    有4-(2.3.4-三甲氧苄基)-1-哌嗪醛盐酸盐吗?
