ztdocument
第8楼2007/06/28
我公司刚买的AGILENT1200配制,其它还有ELSD检测器等。差不多5万美元.(可以减价的,看你的口才罗)
G1354A
四元梯度泵,含在线真空脱气机
1200 Quaternary Pump with Degasser Includes quaternary pump, solvent cabinet, 4 solvent bottles, vacuum degasser and CAN cable.
G1354A # 030
在线柱塞清洗装置
Active seal wash option For use with highly concentrated salt solution to extend seal lifetime - includes peristaltic pump, necessary hoses and various other parts.
01018-22707
过滤小白头
PTFE Frits 5PK
G1329A
自动进样器
1200 Series Standard Autosampler
G1328B
手动进样架
1200 Series Manual Injector .
G1316A
智能柱温箱(可降温)
1200 Thermostatted Column Compartment Includes column compartment with two heat exchangers for solvent pre-heating, column identification module and CAN cable.
G1314B
VWD检测器
1200 Series Variable Wavelength Det. 1200 Series sensitive, reliable and cost- effective variable wavelength detector.
G1314B # 018
VWD流通池
Standard Flow cell
G2170BA
二维色谱软件
HPLC 2D ChemStation Software 32bit For data acquisition, control and evaluation of chromatographic data from one liquid chromatograph.
993967-902
色谱柱, SB-C18 4.6×150
SB-C18 Analytical HPLC Col4.6×150
5182-9628
手动进样针,25uL
Syringe LC, 25ul, FN
0100-1922
定量环,20uL
Sample Loop, 20ul
5063-6589
密封圈
Plunger seal for 1200 and 1050 2/PK
01080-68702
标准测试样品
Isocratic and gradient test sample
5042-6462
连接管线
PEEK Tubing 1/16", 0.007/0.18mm id, 5m
5063-6591
连接接头
PEEK finger-tight 1/16 in, 10PK
5064-8211
工具包
Tool Kit Hex Keys,Rheotool
35900E
数模转换连接配件
Dual-channel A/D interface box
5182-0553
样品瓶,蓝盖,100只
Screw vials,blue caps,PTFE/red septa
5063-6589
密封圈
5182-9613
手动进样针,100uL
0100-1924
定量环,50uL
Sample Loop, 50ul
5182-9619
手动进样针,50uL
