云中漫步
第4楼2006/11/23
DigiSim®
4. CV -the MovieTM
There are two possible output displays in DigiSim®. The first is the basic current vs. potential curve, which is generated using Simulation in the Run menu. The other is the dynamic display of the concentration profiles (i.e., the concentration as a function of the distance from the electrode surface) of all the species involved in the proposed mechanism as they change during the potential scan. This is known as CV - the MovieTM.
DigiSim is a registered trademark and CV - the Movie a trademark of Bioanalytical Systems, Inc.
