传说中一滴香的秘密
图1 一滴香油香气的总离子色谱图(TIC)
表 一滴香油香气成分表
RT |
No | min | Components Name | |
1 | 3.7 | HEXANE | 3.052 |
2 | 3.998 | METHYLMERCAPTANE | 0.803 |
3 | 4.066 | ACETALDEHYDE | 12.046 |
4 | 4.066 | CARBON DISULPHIDE | 1.606 |
5 | 5.122 | METHYL ACETATE | 1.124 |
6 | 5.653 | FURAN, 2-METHYL,TH- | 0.482 |
7 | 5.711 | FURAN, 2-METHYL- | 0.642 |
8 | 5.976 | ALLYLMERCAPTANE | 16.543 |
9 | 6.128 | Furan, 2,3-dihydro-3-methyl- | 3.694 |
10 | 6.306 | FURAN, 2-METHYL-4,5-DIHYDRO- | 5.622 |
11 | 6.805 | ALCOHOL | 3.212 |
12 | 7.21 | BUTEN-2-ONE, 3- | 0.321 |
13 | 8 | DIACETYL | 1.767 |
14 | 8 | PENTANONE, 2- | 1.124 |
15 | 9.122 | PINENE, ALPHA- | 9.316 |
16 | 9.294 | THUJENE, ALPHA- | 15.258 |
17 | 9.854 | BUTENAL, 2E- | 4.818 |
18 | 10.54 | CAMPHENE | 0.321 |
19 | 11.26 | ALDEHYDE C 6 | 1.606 |
20 | 12.08 | PINENE, BETA- | 7.228 |
21 | 12.23 | ALLYL ALCOHOL | 3.534 |
22 | 12.65 | SABINENE | 157.242 |
23 | 13.81 | DIALLYL SULPHIDE | 5.782 |
24 | 14.4 | MYRCENE | 87.856 |
25 | 15.01 | TERPINENE, ALPHA- | 7.549 |
26 | 15.54 | Acetoin Isomer 1 | 3.534 |
27 | 15.84 | DODECANE | 1.124 |
28 | 15.84 | LIMONENE | 306.935 |
29 | 16.13 | EUCALYPTOL | 21.683 |
30 | 16.21 | PHELLANDRENE BETA | 42.884 |
31 | 16.51 | Acetoin Isomer 2 | 6.585 |
32 | 16.51 | MENTHATRIENE, 1,5,8-P- | 0.161 |
33 | 17.27 | Cyclopropane, isothiocyanato- | 6.103 |
34 | 17.41 | OCIMENE Z-BETA | 13.170 |
35 | 17.41 | ALLYL THIO ACETATE | 1.285 |
36 | 17.84 | TERPINENE, GAMMA- | 15.098 |
37 | 17.84 | Acetoin Isomer 3 | 1.606 |
38 | 18.14 | OCIMENE E-BETA | 13.974 |
39 | 18.73 | METHYLPYRAZINE, 2- | 1.285 |
40 | 18.73 | METHYL TETRAHYDROFURANONE, 2,3- | 71.795 |
41 | 18.96 | CYMENE, P- | 6.103 |
42 | 19.46 | TERPINOLENE | 6.906 |
43 | 19.46 | ALLYL METHYL DISULPHIDE | 0.803 |
44 | 19.58 | THIAZOLE, 4-METHYL- | 3.534 |
45 | 19.58 | ACETYL METHYL CARBINOL | 50.433 |
46 | 20.12 | TRIDECANE | 1.927 |
47 | 20.26 | PROPANOL, 2-OXO- | 0.482 |
48 | 20.4 | Furanthiol, 3-, tetrahydro-2-methyl-, trans | 22.165 |
49 | 20.9 | HEPTANOL, 2 | 0.482 |
50 | 21.1 | DIMETHYLPYRAZINE, 2,5- | 0.482 |
51 | 21.3 | HEPTENAL, 2E- | 4.979 |
52 | 21.3 | DIMETHYLPYRAZINE, 2,6- | 0.321 |
53 | 22.18 | ANISOLE | 0.803 |
54 | 22.59 | HEPTENAL, 2-METHYL-2- | 0.642 |
55 | 23.03 | ALLINATE /ALLYL ISOTHIOCYANATE | 625.756 |
56 | 23.41 | ALLOOCIMENE, 4E,6Z- | 7.067 |
57 | 23.6 | 1,1-ETHANEDIOL DIACETATE | 4.979 |
58 | 23.85 | ACETOIN ACETATE | 3.694 |
59 | 23.98 | Furanthiol, 3-, tetrahydro-2-methyl-, cis- | 75.971 |
60 | 24.07 | NONANONE, 2- | 23.610 |
61 | 24.46 | TETRADECANE | 8.994 |
62 | 24.62 | TRIMETHYLPYRAZINE, 2,3,5- | 196.914 |
63 | 24.73 | HEXADIENALE, 2E,4E- | 18.471 |
64 | 25.23 | OCTANOL, 2- | 9.155 |
65 | 25.5 | THUJONE, ALPHA- | 22.165 |
66 | 25.71 | MENTHATRIENE, 1(7),2,4(8)-P- | 4.337 |
67 | 25.87 | ALLYL PROPYL DISULPHIDE | 8.673 |
68 | 26.21 | FURFURYLMERCAPTANE | 8.513 |
69 | 26.21 | DIMETHYLSTYRENE, P- | 4.337 |
70 | 26.32 | THUJONE, BETA- | 19.595 |
71 | 26.41 | ACETIC ACID | 1013.481 |
72 | 26.41 | COSMENE, TRANS- | 0.642 |
73 | 26.89 | ALLYL THIOCYANATE | 30.838 |
74 | 26.89 | CUBEBENE, ALPHA- | 0.161 |
75 | 27.17 | SABINENE HYDRATE TRANS- | 28.911 |
76 | 27.37 | 2-OXOPROPYL ACETATE | 139.896 |
77 | 27.48 | LINALOOLOXIDE | 6.264 |
78 | 27.73 | OCTYL ACETATE, 1- | 1.124 |
79 | 27.95 | CITRONELLAL | 0.964 |
80 | 28.07 | DIALLYL DISULPHIDE | 88.820 |
81 | 28.29 | ALLYL-1E-PROPENYL DISULFIDE | 0.803 |
82 | 28.41 | COPAENE, ALPHA- | 0.321 |
83 | 28.53 | HEPTADIENAL, 2E,4E- | 0.001 |
84 | 28.75 | CYCLOHEXANOL, 3,3,5-TRIMETHYL- P.1 | 0.161 |
85 | 28.75 | PENTADECANE | 3.694 |
86 | 29.12 | PYRAZINE, 2-ETHYL-3,5,6-TRIMETHYL- | 1.446 |
87 | 29.84 | BENZALDEHYDE | 2.409 |
88 | 30.36 | PROPANOIC ACID | 8.513 |
89 | 30.73 | LINALOOL | 1759.860 |
90 | 30.99 | ALCOHOL C 8 | 1.446 |
91 | 31.14 | LINALYL ACETATE | 27.947 |
92 | 31.65 | DIBUTYL DISULPHIDE | 3.855 |
93 | 31.83 | METHYLFURFURAL, 5- | 0.001 |
94 | 32.09 | BORNYL ACETATE | 0.001 |
95 | 32.27 | PROPYLENE GLYCOL, 1,2- | 0.964 |
96 | 32.48 | ELEMENE, BETA- | 3.052 |
97 | 32.56 | ALLYL METHYL TRISULPHIDE | 2.891 |
98 | 32.78 | HEXADECANE | 2.570 |
99 | 32.78 | CARYOPHYLLENE | 16.222 |
100 | 32.93 | TERPINENOL, 4- | 11.725 |
101 | 33.21 | HOTRIENOL | 2.570 |
102 | 33.56 | 4-TERPINENYL ACETATE | 2.730 |
103 | 34.1 | BUTYRIC ACID | 93.157 |
104 | 34.1 | ACETYLPYRAZINE-2 | 3648.532 |
105 | 34.1 | RUGOSADIENE | 0.161 |
106 | 34.75 | ACETYLTHIAZOLE-2 | 22.486 |
107 | 35.55 | HUMULENE, ALPHA- | 8.673 |
108 | 35.55 | CRYPTONE | 1.285 |
109 | 36.13 | MENTHADIEN-4-OL, 1,8-P- | 0.642 |
110 | 36.48 | TERPINEOL, ALPHA- | 22.325 |
111 | 36.67 | SABINOL, TRANS- | 2.891 |
112 | 37.03 | GERMACRENE D | 6.585 |
113 | 37.23 | FURYL THIOACETATE, 2-METHYL-3-TETRAHYDRO- P.2 | 0.964 |
114 | 37.23 | GERMACRENE D | 0.964 |
115 | 37.41 | ZINGIBERENE | 1.285 |
116 | 37.69 | MUUROLENE, ALPHA- | 0.482 |
117 | 37.69 | PIPERITONE | 6.746 |
118 | 37.84 | BENZYL ACETATE | 0.803 |
119 | 37.96 | CARVONE | 1.767 |
120 | 38.04 | LINALOOLOXIDE (PYRANOIDE), E- | 1.767 |
121 | 38.04 | VALERIC ACID | 0.803 |
122 | 38.28 | PIPERITOL, E- | 1.927 |
123 | 38.44 | FARNESENE, 3E,6E-ALPHA- | 0.000 |
124 | 38.73 | ACETAMIDE | 0.964 |
125 | 38.73 | GERANYL ACETATE | 3.694 |
126 | 38.73 | CADINENE, DELTA | 1.606 |
127 | 38.98 | METHYL PHENYL ACETATE | 1.124 |
128 | 39.42 | CURCUMENE, ALPHA- | 0.321 |
129 | 39.58 | METHYL SALICYLATE | 0.001 |
130 | 39.75 | CUMINIC ALDEHYDE | 0.803 |
131 | 40.06 | MYRTENOL | 3.694 |
132 | 40.06 | DIALLYL TRISULPHIDE | 7.388 |
133 | 40.25 | NEROL | 2.730 |
134 | 40.78 | DECADIENAL, 2E,4E- | 1.606 |
135 | 40.78 | PHENYLETHYL ALCOHOL, 1- | 0.803 |
136 | 40.98 | PHENYLETHYL ACETATE, 2- | 2.570 |
137 | 41.3 | METHYL CYCLOPENTENOLONE, 3,2,2- | 133.311 |
138 | 41.4 | ANETHOLE TRANS- | 6.264 |
139 | 41.51 | CARVEOL L TRANS | 0.000 |
140 | 41.54 | CALAMENENE, CIS- | 0.161 |
141 | 41.91 | CAPRONIC ACID | 4.658 |
142 | 42 | PARA-CYMEN-8-OL | 0.482 |
143 | 42.53 | GUAIACOL | 0.803 |
144 | 42.9 | METHYLTRIDECANAL, 12- | 3.373 |
145 | 43.04 | BENZYLALCOHOL | 0.964 |
146 | 44.29 | PHENYLETHYL ALCOHOL, 2- | 1.124 |
147 | 44.29 | BHT | 0.161 |
148 | 45.18 | IONONE, BETA- | 0.000 |
149 | 45.32 | HOTRIENOL, 7-HYDROXY- | 6.746 |
150 | 45.6 | HEPTANOIC ACID | 2.730 |
151 | 46.17 | CUMINIC ALCOHOL, DIHYDRO- | 1.124 |
152 | 46.3 | ACETYLPYRROLE-2 | 0.161 |
153 | 47.06 | FURANEOL ACETATE | 3885.921 |
154 | 47.77 | ETHYLMALTOL | 925.785 |
155 | 48.23 | PYRROLALDEHYDE, 2- | 0.321 |
156 | 48.23 | FURANEOL | 149.533 |
157 | 48.23 | ETHYLGUAIACOL, 4- | 0.161 |
158 | 48.67 | CINNAMIC ALDEHYDE | 2.891 |
159 | 49.08 | FURANONE, 4-ACETOXY-2-ETHYL-5-METHYL-3(2H)- | 1.446 |
160 | 49.08 | CAPRYLIC ACID | 108.415 |
161 | 49.51 | CYCLOPENTENONE, 2-ACETOXY-3-METHYL-2- | 2.891 |
162 | 49.62 | TRIACETIN | 1.285 |
163 | 49.81 | METHYL CINNAMATE-E- | 4.658 |
164 | 50.44 | NORFURANEOL | 1.446 |
165 | 50.44 | CUMINIC ALCOHOL | 0.161 |
166 | 51.91 | DECALACTONE, GAMMA- | 1.767 |
167 | 52.41 | PELARGONIC ACID | 3.694 |
168 | 53.42 | DECALACTONE, DELTA- | 1.124 |
169 | 53.42 | VINYLGUAIACOL, 4- | 0.321 |
170 | 54.41 | EUDESMOL, BETA- | 0.001 |
171 | 55.6 | CAPRIC ACID | 39.993 |
172 | 58.15 | BIS (2-METHYL-3-TH-FURYL)- DISULPHIDE P.1 | 3.373 |
173 | 59.71 | DODECALACTONE, DELTA- | 2.249 |
174 | 59.9 | BENZOIC ACID | 0.964 |
175 | 60.14 | INDOLE | 0.482 |
176 | 60.23 | BIS (2-METHYL-3-TH-FURYL)- DISULPHIDE P.2 | 27.786 |
177 | 60.33 | TRIETHYL CITRATE | 0.964 |
178 | 60.63 | LAURIC ACID | 2.088 |
179 | 61.64 | VELTYL BUTYRATE | 1.285 |
180 | 61.89 | BIS (2-METHYL-3-TH-FURYL)- DISULPHIDE P.3 | 35.175 |
181 | 62.07 | VANILLIN | 3.373 |
SUM | 14390 |
symmacros
第7楼2018/10/24
不是识别就用谱库检索那么简单。还需要其他方法校对核实。谱库要用标准品来建,保留指数都需要标准品来测定。FID的校正因子需要标准品来测定。这个过程是花费大量功夫和精力的。是一项非常复杂的工作。前期要在很多很多工作。一般人可能只能给出简单的结果,可能是很少一些成分。
没有标准品,先看看谱库里面有没有,库谱里面有,还有仔细利用出峰顺序,保留指数等来核对。如果是不知道新物质,还需要收集做其它方式来进行鉴定。
