There are two energy density to measure the current denisty depending on your requirment. One is specific mass density, typically is ampere/g, the other is specific volume density, typically is ampere/cm2
thanks!howerer,you did not tell me the answer actually.Cause they can be absolutly translated to the other in some way,what is my mind to . thank you all the same!!
