砂锅粥
第1楼2020/08/20
这个其实在仪器帮助有说明的,楼主不妨看看软件的帮助文件。
o Replicate signal overrange
QC--- QC test failed
S--- Standard addition failure
e--- Edited result
C--- Fitted background error seen on replicates, due to non-convergence
D ---Fitted background error seen on replicates, unable to be modelled due to insufficient spectral data
uncal Uncalibrated results
i--- No internal standard correction applied
n--- Interference correction not applied (line has a related interferent that was not successfully calculated)
a ----Solution overrange and automatically diluted
u--- Under-range (< blank)
v--- Under valid range (< minimum concentration)
x---- Extended calibration range (> maximum concentration)
b---- Line has a related interferent that is above the extended calibration range (IEC correction still applied)
Insm_d2f9c757
第2楼2020/08/22
好的,谢谢
