当前位置:仪器社区 > 试验机/硬度计
高频共振疲劳试验机
  • amsler测试技术
    2021/10/28
试验机/硬度计
  • High frequency pulsators高频疲劳试验机
    标准设备
    POWER SWINGLY 5 kN, 10 kN, 20 kN
    POWER SWING MOT 50 kN, 100 kN, 150 kN, 250 kN, 400 kN, 600 kN,1.000 kN, 1,200kN, 1,500kN 及2,000kN
    POWER SWING MAG 5 kN, 10 kN, 20 kN, 50 kN, 100 kN, 150 kN, 250 kN, 400 kN, 550kN 600 kN
    标准设备的载荷从5kN至2000kN,除了标准的单轴加载外,我们还可以通过夹具向试样夹在弯曲,扭转以及侧向载荷。
    作为高频试验机领域的领导者,我们还将设备分为以下两大类:
    1. 独一无二的针对结构部件的 POWER SWING MOT
    独一无二的12mm位移行程,可以让零部件在更大的动态位移下试验。可以克服额外阻尼并实现间隙配合下的高频疲劳试验。
    2013年的最新设备可以达到200吨载荷的结构件高频疲劳试验机-SincoTec POWER SWING-- Evolution
    OUR TEST RIGS FOR COMPONENT AND MATERIAL TESTING
    Energy-efficient, highly precise, and fast – your best universal tool for quick and cost-efficient testing.
    Attaching test fixtures to universal resonance pulsators allow not only axial but also bending and torsional loads to be tested.
    We offer our universal resonance test systems with two different drive systems: electromotive (MOT) and electromagnetic (MAG).
    An overview of the advantages of resonance test technology:
    • Highest energy efficiency = very low energy costs + short test times
    • Automatic and precise crack detection thanks to the resonance principle which does not require optical detection systems
    • Shorter test times for lifecycle examinations
    • High accuracy of target values leads to scattering of real test results
    • Test costs are approximately 1 % compared to forcibly excited actuator test systems including through low maintenance requirements and the use of low-wear components
    • Low operating costs thanks to the resonance principle and low infrastructure requirements
    • Very low noise profile
    • Low space requirements
    • Proven test technology with over 1,500 test systems in use around the world
  • 沧海青城
    第1楼2021/10/29
    疲劳实验是很多安全件必须要做的试验
  • formtest
    第2楼2021/11/10
    这个是高频共振疲劳试验机
  • formtest
    第3楼2021/11/10
    噪音和振动测试机
    不稳定的轴承部件、轴承套圈和球状滚动体的局部缺陷或轴承中的尘粒都可能引起应用中噪音。 除了刚性、承载能力、极限转速和使用寿命等基本轴承要素对应用产生深远的影响外,低噪音和低振动的需求也变得越来越重要。
    所有这些轴承质量问题都可以使用 SKF 轴承振动设备来测试。
    如频率分析 (FFT) 和更高级的分析等高技术分析与测量方法可精准找到故障所在。 光谱屏蔽有助于在客户的特定应用中优化轴承性能。
    这些设备的测试结果也可被有经验的专家用来查找有缺陷的制造步骤(例如没有进行珩磨)。 采用全球校准系统确保了振动设备均按照国际标准运行。
