1.Provide the testing and certificate service against standards to clients.(20%) 为客户提供符合标准的检测和认证服务。(20%) 2.Support to Test Engineer / Senior Test Engineer for Physical Testing.(15%) 支持测试工程师/高级测试工程师进行物理测试。(15%) 3.Issue test report and project documentation.(15%) 出具测试报告和项目文档(15%) 4.Perform sample preparation work.(25%) 进行样品准备工作。(25%) 5.Perform ad-hoc assignment as required.(15%) 根据要求执行一些特别的任务。 6.May be required to overtime work.(10%) 可能需要加班。(10%)
Job Requirements:
1.Bachelor degree or above of Textile Technology or related majors. 本科及以上学历,纺织技术或相关专业。 2.Good knowledge of textile and commercial textile standard. 熟悉纺织品和商用纺织品标准。 3.Excellent command of English and Mandarin. 良好的英语和普通话水平。 4.Able to work independently and under time pressure. 能够独立工作,并能承受时间压力。 5.Presentable, self-motivated and organized with proactive working attitudes. 良好的形象,自我激励,有组织,积极主动的工作态度。 公司介绍: 检验检测机构合辑...查看全部
