ASTM E29-22 | 2022/4/1 | Standard Practice for Using Significant Digits in Test Data to Determine Conformance with Specifications |
ASTM E29-13(2019) | 2019/1/1 | Standard Practice for Using Significant Digits in Test Data to Determine Conformance with Specifications |
ASTM E29-13 | 2013/8/1 | Standard Practice for Using Significant Digits in Test Data to Determine Conformance with Specifications |
ASTM E29-08 | 2008/10/1 | Standard Practice for Using Significant Digits in Test Data to Determine Conformance with Specifications |
ASTM E29-06B | 2006/11/1 | Standard Practice for Using Significant Digits in Test Data to Determine Conformance with Specifications |
ASTM E29-06A | 2006/9/1 | Standard Practice for Using Significant Digits in Test Data to Determine Conformance with Specifications |
ASTM E29-06 | 2006/5/1 | Standard Practice for Using Significant Digits in Test Data to Determine Conformance with Specifications |
ASTM E29-04 | 2004/12/1 | Standard Practice for Using Significant Digits in Test Data to Determine Conformance with Specifications |
ASTM E29-02E1 | 2002/5/1 | Standard Practice for Using Significant Digits in Test Data to Determine Conformance with Specifications |
ASTM E29-93A(1999) | 1999/5/1 | Standard Practice for Using Significant Digits in Test Data to Determine Conformance with Specifications |
ASTM E29-93A | 1993/1/1 | Standard Practice for Using Significant Digits in Test Data to Determine Conformance with Specifications |
ASTM E29-90 | 1990/1/1 | Standard Practice for Using Digits in Test Data to Determine Conformance with Specifications |
ASTM E29-67(1980)E1 | 1967/1/1 | Standard Test Method for Indicating Which Places Of Figures Are To Be Considered Significant In Specified Limiting Values |
ASTM E29-67 | 1967/1/1 | Recommended Practice For Indicating Which Places Of Figures Are To Be Considered Significant In Specified Limiting Values |
