Column Dimension | Column Volume |
4.6 mm I.D. x 250 mm L | 4.2 mL |
4.6 mm I.D. x 150 mm L | 2.5 mL |
4.6 mm I.D. x 50 mm L | 0.8 mL |
3.0 mm I.D. x 250 mm L | 1.8 mL |
3.0 mm I.D. x 150 mm L | 1.1 mL |
3.0 mm I.D. x 50 mm L | 0.4 mL |
2.1 mm I.D. x 150 mm L | 0.5 mL |
2.1 mm I.D. x 100 mm L | 0.3 mL |
2.1 mm I.D. x 50 mm L | 0.2 mL |
附件:
