大陆
第31楼2008/04/10
倾力分享!!!
ASTM 2004 共15卷,含目录,文件太大,只提供原始链接:
index: http://www.namipan.com/d/dc3392af2383d44bad366b4c07069aed6d6c78f6988d0d00
vol1 iron: http://www.namipan.com/d/00f581970362f4bcf96e2f6e6349701cc3a5f585a8436b0a
vol2 nonferrous metal: http://www.namipan.com/d/81b78fe9c7e964999a0af8027f3ada7febd8add9f730aa04
vol3 test methods: http://www.namipan.com/d/5b20fcde007e178fc64b718288ea430d94db1744f250fe03
vol4 construction: http://www.namipan.com/d/33b6de2276e17f255a3565bf5cd44da87fc540427d853a15
vol5 petroleum products: http://www.namipan.com/d/b862fb1cf2ce831625a0977f9788e14aea70ea0329c1600b
vol6 paints: http://www.namipan.com/d/b2441187b804f7fa38dedbf12e1dce32e3c839ed74490e04
vol7 textiles: http://www.namipan.com/d/d4d1bd018d73adbe58812f8d2a4cfe7e19440da64eb97202
vol8 plastics: http://www.namipan.com/d/38066308bcb6b00e00ebfe0c7d049b8bfba455cb66feda05
vol9 rubber: http://www.namipan.com/d/aa73dd5a2f41206c5d3cf438005ad7fcdf6cd6b8344bbc02
vol10 electronics: http://www.namipan.com/d/745acbc9d4e6e246b6109f0399c3594832036612b4b3a703
vol11 Water and environmental technology: http://www.namipan.com/d/134a95691061bf1f4841f5f1b7a25d1ea921a2a96a999608
vol12 nuclear solar and geothermal energy: http://www.namipan.com/d/a069952bcfb4fd3e4fc0beab95cc2105e0529c47598b4002
vol13 medicine: http://www.namipan.com/d/d513d94a19763045b4a18821c38d32a91646ea9526026702
vol14 general methods: http://www.namipan.com/d/d6c2f4e18b99ce1bb3e26a4bd8f9057a83e36b76b2cf7c05
vol15 general products: http://www.namipan.com/d/7e520ad0e7476f8d24470d271dab3ca2a30eea71c1f43d0a
(来源:小木虫)
大陆
第38楼2008/04/13
没说,我仔细对照了一下标准内容和index,有一些内容残缺,当然基本上是很全面的。我关注到的残缺的标准有,东山兄或其他版友如果有这些标准,望能帮助补充下,谢谢!:
Vol 03
E0932-89R02 Practice for Describing and Measuring Performance of Dispersive Infrared Spectrometers
E0958-93R05 Practice for Measuring Practical Spectral Bandwidth of Ultraviolet-Visible Spectrophotometers
E1252-98R02 Practice for General Techniques for Obtaining Infrared Spectra for Qualitative Analysis
E1421-99R04 Practice for Describing and Measuring Performance of Fourier Transform Mid-Infrared (FT-MIR) Spectrometers: Level Zero and Level One Tests
E1790-04 Practice for Near Infrared Qualitative Analysis
E1791-96R00 Practice for Transfer Standards for Reflectance Factor for Near-Infrared Instruments Using Hemispherical Geometry
E1840-96R02 Guide for Raman Shift Standards for Spectrometer Calibration
E1866-97R02 Guide for Establishing Spectrophotometer Performance Tests
E1944-98R02 Practice for Describing and Measuring Performance of Laboratory Fourier Transform Near-Infrared (FT-NIR) Spectrometers: Level Zero and Level One Tests
E0995-04 Guide for Background Subtraction Techniques in Auger Electron Spectroscopy and X-ray Photoelectron Spectroscopy
E0996-04 Practice for Reporting Data in Auger Electron Spectroscopy and X-ray Photoelectron Spectroscopy
E1127-03 Guide for Depth Profiling in Auger Electron Spectroscopy
E2382-04 Guide to Scanner and Tip Related Artifacts in Scanning Tunneling Microscopy and Atomic Force Microscopy
Vol 10
D2858 Test Method for Thermal Conductivity of Electrical Grade Magnesium Oxide
D4352 Test Method for Determination of Magnetic Material Impurities in Electrical Grade Magnesium Oxide
F0026 Test Methods for Determining the Orientation of a Semiconductive Single Crystal
F0043 Test Methods for Resistivity of Semiconductor Materials
F0674 Practice for Preparing Silicon for Spreading Resistance Measurements
F1241 Terminology of Silicon Technology
F1529 Test Method for Sheet Resistance Uniformity Evaluation by In-Line Four-Point Probe with the Dual-Configuration Procedure
F1535 Test Method for Carrier Recombination Lifetime in Silicon Wafers by Noncontact Measurement of Photoconductivity Decay by Microwave Reflectance
vol 14
E0548 Guide for General Criteria Used for Evaluating Laboratory Competence
E0175-82R99E01 Terminology of Microscopy
