poorlittle
第21楼2008/05/21
No. 2377/90 : Number two three seven seven slash (or stroke) nine zero (or Number two three double seven slash nine zero, Number twenty three hundred and seventy seven slash ninety, Number two thousand three hundred and seventy seven slash ninety……)
(Remark : A slash or stroke, /, is a punctuation mark. It is also called an oblique dash, diagonal, separatrix, virgule, scratch comma, forwardslash, or slant. It appears similar to a solidus or shilling mark, which is a separate character. (Note: not to be confused with the word "virgule" in French, which means "comma"). It is sometimes incorrectly called a backslash.)
