chengjingbao
第17楼2008/06/03
三级报警栏:一级:黄色;二级:红色;无报警:绿色或者灰色。其它就不解释啦。我才看到这。看来翻译东西,懂不懂,先通读三遍这句话是有道理的。
附英文说明:From this menu, you can also access the alarm historic menu by pressing the Historic Alarms button. This button will turn red when an alarm occurs, turn yellow when the menu was opened but alarms are still active, and turn green if the problem is resolved.
