小鸟飞翔
第12楼2008/06/05
大家看看这个附件
label claim
poorlittle
第20楼2008/06/05
From the meanings of the following information obtained from internet:
Not a single product met its label claim—some were close and some ... Label Claim. Per Capsule. Test Result. Per Capsule. Percent of Label ...
ineffective, and is used for label claim only.
to prove beyond doubt that it meets the label claim of a minimum protein ...
Lean Body Mass 60 is lab tested to meet the label claim of potency
According to a Consumer Council test,their actual down content, in many cases, was less than the label claim.
the test came back 4mg under label claim. ...
Knowing what's going into a specific label claim can help you understand the protection that vaccines will provide
